ovi730
Активные пользователи-
56 -
Весь контент ovi730
Ktag 7.020 firmware crp 0 - working: https://mega.nz/#!rUdDnYDA!RrHb5a8CcksLq22Yl9r-sjwZ-FUfAZV44odW-1N62xQ CID: 035344535330344780399b1368010300 SD card image : https://mega.nz/#!7FVwVbjK!HPNbm12Bb4nuYtOoSFmTJQDL--LejDRixGT_0ytmpSw https://mega.nz/#!7FVwVbjK!HPNbm12Bb4nuYtOoSFmTJQDL--LejDRixGT_0ytmpSw
cleaned Папки личных сообщений заполнены на: 0% от лимита (10 сообщения)
resset for kess and ktaf - 750 soved. pm for details
trauka how many cfg's you have for kess ?
not ok - just it is a spam
http://hitoksupvt.6te.net/new+cfg+no+limitation+of+tokens/ - not tested yet
this is not free solution. we need the license generator. otherwise we fuck the nxp i already killed one with this. this is wrong
link not working
so in this case you can help us to solve kess resset pack ?
svagg2000 please post the full pack as you have ktag from me. you remember that you asked help for ktag full solution and i helped you. now post the full kes resset and we will finish once and forever
exact. update ktag to 6.070. this pack has 10 tokens and will give all of you 300 tokens ( 10 cfg x 30 tkens) . This files must be placed inside update folder only when you need to resset the tool form the 1 to 10 one by one. if you are using cfg no 9 than the only possibility is remaining cfg10. those tokens are codded incremental. this is already tested and i confirm that is working.The update procedure is the same and update pack have been already posted. i share this solution of sw resset free. does someone has the same files pack for kess ? Up to now it seems that i am the only one that is giving free solutions here :( Next time is better to not blaim me.
Привет друзья. Я отправляю здесь CFG resset сайты для ktag / Transdata. CFG является voba 10 х 30 сайтов токенов. Ожидание Kess решения resset CFG's 10x30 ktag.rar
i have ktag resset solution for 6.070. I need kess 4.036 resset solution. pm me.
I have ktag 6.070 resset solution - in exchange for kess 4.036 - anyone ?
clean hello, i have tester this , and it is ok :https://yadi.sk/d/4jhBkef1gZ2uj how many tokens it have ? also is commpletly different - more adress are changed
we need the cfg's in order to create tokens. to be clear 1cfg =1 token. same token or same cfg can not be ussed more than 1 time.
2.08 needed
after ktag 60 writings i have te cfg pack
Из России с любовью :) анонимному Инструкция вселяет: 1. флэш nxp2478 с файловой fwnx.bin 2. заменить обновления forlder с одной из архива и переименовать его "Обновление" 3. Начало ksuite и нажмите кнопку Пропустить (Cut интернет !!!!) Наслаждайтесь !!!!!!
Обновление k tag 6,070 - проверено в порядке https://mega.co.nz/#F!NpgTgSrZ!UIPXVuuAQyhWYkbMp8yyuQ
did some of you tried to modify device.fmw ? in order to empiminate crp3 protection ? we need an old device.fmw file in order to compare
error . can not access it
also truck and agro ?????????
