alexanca1
Информация о alexanca1
    NIVA 1.7 MPI BOSCH MP7.0 EURO 3
Достижения alexanca1
  1. I apologize for a question. I have a curiosity. You are informatic experts or experts of engines? Because the program is quite complex and I have not yet figured out if it is intended for an ordinary public or expert engineers. For example, many people do not know what is the Фактор влияния отклон. фпуска возд. на адаптацию смеси (мс). This parameter describes the variation of the offset of the injection time to a minimum to compensate for unintended ingress of air. Which in normal conditions is the same whether the motor is rotating at 800 RPM or it rotates at 3000 RPM. Certain imperfections in the translation does not bother when read by an expert of engines. But also translated well mean nothing to an inexperienced person in mechanics.
  2. The abbreviation DTC means problems and therefore error does not seem wrong. In any case I will replace the word error with DTC. Given that there is someone who knows the Russian and English I invite him to correct any translation and correct errors due to my lack of knowledge of the Russian language. Any contribution will be welcome. P.S. The troubles are often due to errors
  3. DTC means Diagnostic Trouble Codes. Many people do not know well what it means. Everyone understands the concept of error. However it is true the right definition is DTC.
  4. A curiosity. Many errors (DTC) in the program are special codes type P2XXX, Bxxxx, Uxxxx and not standard codes P0XXX. These codes are there in Soviet cars? I found them always in MERCEDES, BMW, Alfa Romeo and other European cars. Never in the LADA.
  5. I apologize for any translation errors. I know quite well English. But I do not know a word of Russian. Slowly I will try to do better. I based my translation on my original manual LADA in English which is not always perfectly translated from Russian. In the sense that some concepts are described differently from Russian to English. Often I used GOOGLE translator but he also commits approximations. P.S. I'm Italian and I'm an old mechanic FIAT and I like the LADA because it reminds me of the old FIAT cars. And the LADA comes in many things from FIAT. The LADA especially NIVA is a great car. I've had three. I have traveled at least 400,000 kilometers between all three. Unfortunately, some components might be of poor quality. Replaced with Italian or German components becomes much more reliable.
  6. Hi! I did a lot of testing with latest version of OpenDiagMobile-2.02.13. Not good. Reads the name of the controller, read errors on OBDII, but does not read the parameters of the controller. Shows the parameter names but not the values. I sent you an email with attached the log file. Sorry if I'm writing to e-mail but I can not put the log file on the forum. When I try to attach the file freezes everything. Maybe because I use Fedora Linux and the program of the forum does not read the file system. Or Fedora Linux does not support the program of the forum. Best regards. Alex
  7. Thanks for the info !! I do the tests then I know the results. Happy New Year !!!!
  8. I've updated the program to the latest version, OpenDiagMobile-2.02.12. It does not read the parameters. Reads only the version of the control unit then loses the connection. I went back to version 2.02.07 that works very fine. My car is a NIVA euro 3, Bosch MP 7.0. My adapter is an ELM 327 Bluetooth 1.5.
  9. A curiosity. Will be developed a paid version with the functions of the Windows version? With the ability to change the parameters? Thanks.
  10. I tried to send the log file but my pc will not let me. It is probably a language problem of my pc. However, I ask your system administrator or moderator of the forum to delete my post. I sent sidrva the log file by mail. thanks
  11. Wow!!!! It connects with the ECU without error. It reads the ECU version and read OBD error!! But it don't reads the parameter. I try with the engine not running because at my house all are sleeping ;-) I try tomorrow with the engine running. Question. I need the engine running or not ? Because the windows version reads the parameter also if the engine is not running. How many time it takes to read the parameter? I don't be able to send you the log file, so i write it to you: AppVersion: 2.02.6.test6 EBU: BOSCH MP7.0 E3 Connect: Bluetooth Receive: ATE0 OK Time: 21:55:41,025 Send: ATAL Receive: OK Time: 21:55:41,064 Send: ATS1 Receive: OK Time: 21:55:41,103 Send: ATSP5 Receive: OK Time: 21:55:41,117 Send: ATAT0 Receive: OK Time: 21:55:41,153 Send: ATIB10 Receive: OK Time: 21:55:41,190 Send: ATWM3E01 Receive: OK Time: 21:55:41,225 Send: ATSW00 Receive: OK Time: 21:55:41,262 Send: ATSH8111F1 Receive: OK Time: 21:55:41,361 Send: ATFI Receive: BUS INIT: OK Time: 21:55:42,643 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 68 90 00 00 00 00 01 17 60 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5E 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:55:44,004 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 68 90 00 00 00 00 01 17 60 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5E 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:55:45,343 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 68 90 00 00 00 00 01 17 60 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5E 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:55:46,686 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 68 90 00 00 00 00 01 17 60 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5E 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:55:48,037 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 68 90 00 00 00 00 01 17 60 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5E 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:55:49,384 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 68 90 00 00 00 00 01 17 60 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5E 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:55:50,735 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 68 90 00 00 00 00 01 17 60 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5E 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:55:52,069 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 68 90 00 00 00 00 01 17 60 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5E 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:55:53,448 Send: 2340000001 Receive: 63 81 Time: 21:55:53,944 Send: 2340000201 Receive: 63 83 Time: 21:55:54,450 Send: 2340000301 Receive: 63 35 Time: 21:55:54,934 Send: 2340000401 Receive: 63 19 Time: 21:55:55,438 Send: 2340000501 Receive: 63 60 Time: 21:55:55,925 Send: 2340000601 Receive: 63 60 Time: 21:55:56,411 Send: 2340000701 Receive: 63 14 Time: 21:55:56,907 Send: 2340000D01 Receive: 63 7F Time: 21:55:57,393 Send: 2340000001 Receive: 63 81 Time: 21:55:57,877 Send: 2340000201 Receive: 63 83 Time: 21:55:58,366 Send: 2340000301 Receive: 63 35 Time: 21:55:58,851 Send: 2340000401 Receive: 63 19 Time: 21:55:59,331 Send: 2340000501 Receive: 63 60 Time: 21:55:59,817 Send: 2340000601 Receive: 63 60 Time: 21:56:00,302 Send: 2340000701 Receive: 63 14 Time: 21:56:00,795 Send: 2340000D01 Receive: 63 80 Time: 21:56:01,281 Send: 2340000001 Receive: 63 81 Time: 21:56:01,766 Send: 2340000201 Receive: 63 83 Time: 21:56:02,261 Send: 2340000301 Receive: 63 35 Time: 21:56:02,746 Send: 2340000401 Receive: 63 19 Time: 21:56:03,230 Send: 2340000501 Receive: 63 60 Time: 21:56:03,712 Send: 2340000601 Receive: 63 60 Time: 21:56:04,225 Send: 2340000701 Receive: 63 14 Time: 21:56:04,710 Send: 2340000D01 Receive: 63 7F Time: 21:56:05,197 Send: 2340000001 Receive: 63 81 Time: 21:56:05,680 Send: 2340000201 Receive: 63 84 Time: 21:56:06,171 Send: 2340000301 Receive: 63 35 Time: 21:56:06,655 Send: 2340000401 Receive: 63 19 Time: 21:56:07,145 Send: 2340000501 Receive: 63 60 Time: 21:56:07,630 Send: 2340000601 Receive: 63 60 Time: 21:56:08,119 Send: 2340000701 Receive: 63 14 Time: 21:56:08,606 Send: 2340000D01 Receive: 63 7F Time: 21:56:09,090 Send: 2340000001 Receive: 63 81 Time: 21:56:09,573 Send: 2340000201 Receive: 63 84 Time: 21:56:10,064 Send: 2340000301 Receive: 63 35 Time: 21:56:10,549 Send: 2340000401 Receive: 63 19 Time: 21:56:11,026 Send: 2340000501 Receive: 63 60 Time: 21:56:11,505 Send: 2340000601 Receive: 63 60 Time: 21:56:12,008 Send: 2340000701 Receive: 63 14 Time: 21:56:12,491 Send: 2340000D01 Receive: 63 80 Time: 21:56:13,000 Send: 2340000001 Receive: 63 81 Time: 21:56:13,498 Send: 2340000201 Receive: 63 84 Time: 21:56:13,983 Send: 2340000301 Receive: 63 35 Time: 21:56:14,470 Send: 2340000401 Receive: 63 19 Time: 21:56:14,955 Send: 2340000501 Receive: 63 60 Time: 21:56:15,440 Send: 2340000601 Receive: 63 60 Time: 21:56:15,949 Send: 2340000701 Receive: 63 14 Time: 21:56:16,443 Send: 2340000D01 Receive: 63 7F Time: 21:56:16,929 Send: 2340000001 Receive: 63 81 Time: 21:56:17,414 Send: 2340000201 Receive: 63 84 Time: 21:56:17,897 Send: 2340000301 Receive: 63 35 Time: 21:56:18,412 Send: 2340000401 Receive: 63 19 Time: 21:56:18,898 Send: 2340000501 Receive: 63 60 Time: 21:56:19,383 Send: 2340000601 Receive: 63 60 Time: 21:56:19,869 Send: 2340000701 Receive: 63 14 Time: 21:56:20,357 Send: 2340000D01 Receive: 63 80 Time: 21:56:20,843 Send: 2340000001 Receive: 63 81 Time: 21:56:21,353 Send: 2340000201 Receive: 63 84 Time: 21:56:21,832 Send: 2340000301 Receive: 63 35 Time: 21:56:22,327 Send: 2340000401 Receive: 63 19 Time: 21:56:22,812 Send: 2340000501 Receive: 63 60 Time: 21:56:23,300 Send: 2340000601 Receive: 63 60 Time: 21:56:23,790 Send: 2340000701 Receive: 63 14 Time: 21:56:24,276 Send: 2340000D01 Receive: 63 7F Time: 21:56:24,763 Send: 2340000001 Receive: 63 81 Time: 21:56:25,247 Send: 2340000201 Receive: 63 84 Time: 21:56:25,731 Send: 2340000301 Receive: 63 35 Time: 21:56:26,220 Send: 2340000401 Receive: 63 19 Time: 21:56:26,705 Send: 2340000501 Receive: 63 60 Time: 21:56:27,190 Send: 2340000601 Receive: 63 60 Time: 21:56:27,682 Send: 2340000701 Receive: 63 14 Time: 21:56:28,167 Send: 2340000D01 Receive: 63 80 Time: 21:56:28,655 Send: 2340000001 Receive: 63 81 Time: 21:56:29,143 Send: 2340000201 Receive: 63 84 Time: 21:56:29,627 Send: 2340000301 Receive: 63 35 Time: 21:56:30,112 Send: 2340000401 Receive: 63 19 Time: 21:56:30,590 Send: 2340000501 Receive: 63 60 Time: 21:56:31,082 Send: 2340000601 Receive: 63 60 Time: 21:56:31,561 Send: 2340000701 Receive: 63 14 Time: 21:56:32,059 Send: 2340000D01 Receive: 63 80 Time: 21:56:32,545 Send: 2340000001 Receive: 63 81 Time: 21:56:33,030 Send: 2340000201 Receive: 63 84 Time: 21:56:33,518 Send: 2340000301 Receive: 63 35 Time: 21:56:34,009 Send: 2340000401 Receive: 63 19 Time: 21:56:34,490 Send: 2340000501 Receive: 63 60 Time: 21:56:34,977 Send: 2340000601 Receive: 63 60 Time: 21:56:35,907 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:56:37,261 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:56:38,598 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:56:39,973 Send: 1A90 Receive: 5A 90 56 41 5A 32 31 32 31 33 5F 45 33 5F 31 5F 37 4C FF Time: 21:56:40,609 Send: 1A91 Receive: 5A 91 4D 37 4E 32 31 56 31 34 FF FF FF FF Time: 21:56:41,210 Send: 1A97 Receive: 5A 97 4D 59 32 30 30 30 Time: 21:56:41,734 Send: 1A9A Receive: 5A 9A 30 Time: 21:56:42,209 Send: 21A0 Receive: 7F 21 12 Time: 21:56:43,562 Send: 1800FF00 Receive: 58 01 01 37 82 Time: 21:56:45,816 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:56:47,180 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:56:48,528 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:56:49,878 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:56:51,227 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:56:52,574 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:56:53,927 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:56:55,290 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:56:56,646 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:56:57,988 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:56:59,332 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:00,686 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:02,050 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:03,397 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:04,728 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:06,075 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:07,405 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:08,763 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:10,116 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:11,487 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:12,830 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:14,174 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:15,521 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:16,858 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:18,283 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:19,703 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:21,122 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:22,473 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:23,827 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:25,168 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:26,502 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:27,850 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:29,210 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:30,571 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:31,927 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:33,263 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:34,608 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:35,953 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:37,292 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:38,633 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:39,971 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:41,335 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:42,685 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 81 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:44,044 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 80 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:45,403 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 80 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:46,745 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 80 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:48,100 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 80 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:49,457 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 80 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:50,802 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 80 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:52,162 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 80 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:53,514 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 80 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:54,854 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 80 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:56,196 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 80 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:57,550 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 80 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:57:58,899 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 80 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:58:00,249 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 80 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:58:01,586 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 80 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:58:02,945 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 80 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:58:04,307 Send: 1800FF00 Receive: 58 01 01 37 82 Time: 21:58:06,274 Send: 3E01 Receive: 7E Time: 21:58:06,732 Send: 1A90 Receive: 5A 90 56 41 5A 32 31 32 31 33 5F 45 33 5F 31 5F 37 4C FF Time: 21:58:07,389 Send: 1A91 Receive: 5A 91 4D 37 4E 32 31 56 31 34 FF FF FF FF Time: 21:58:07,980 Send: 1A97 Receive: 5A 97 4D 59 32 30 30 30 Time: 21:58:08,510 Send: 1A9A Receive: 5A 9A 30 Time: 21:58:08,983 Send: 21A0 Receive: 7F 21 12 Time: 21:58:10,893 Send: 3E01 Receive: 7E Time: 21:58:13,895 Send: 3E01 Receive: 7E Time: 21:58:16,572 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 80 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:58:17,907 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 80 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:58:19,255 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 80 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:58:20,600 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 80 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:58:21,953 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 80 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:58:23,313 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 80 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:58:24,657 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 80 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:58:25,999 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 80 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:58:27,342 Send: 2101 Receive: 61 01 01 01 37 82 00 00 00 35 00 80 67 90 00 00 00 00 01 17 61 00 89 81 00 8A 50 60 80 EE 7A 00 00 01 08 60 00 04 00 4B D4 00 48 00 00 5F 5A 80 00 7A 14 14 00 00 00 00 C5 C5 C5 C5 90 90 90 90 89 FC 40 00 00 00 00 03 0A 26 80 00 07 F5 80 76 80 32 00 00 09 00 00 80 3C Time: 21:58:28,679 Send: 1800FF00 Receive: 58 01 01 37 82 Time: 21:58:30,648 Send: 3E01 Receive: 7E Time: 21:58:33,650 Send: 3E01 Receive: 7E Time: 21:58:36,650 Send: 3E01 Receive: 7E Logs: off
  12. OK. I make the test. Laptop ACER. Windows 7. OPENDIAG 1.4 FREE. ELM 327 bluetooth( the same that i use with android). It works PERFECTLY. Why it don't works on Android?
  13. OK. I do a test and let you know
  14. With my Windows laptop I use opendiag 1.3.9 free and I use a K-L line adaptor because the free version do not allow me to use the ELM 327 adapter. I use a connector KL-line bought on ebay cheap and everything works fine. Its works very fast. Obviously, with the free version does not allow me to change the settings. With opendiag Android use an adapter ELM 327 Bluetooth and gives me the errors I reported above. My ELM 327 Bluetooth adapter works fine with TORQUE for Android and I do not understand why not work with OPENDIAG for Android. It always stops at the point Send: ATFI Receive: BUS INIT: ERROR My ECU is an BOSCH MP7.0 euro 3 My tablet is an ASUS Fonepad 7 with android 4.4.2. I do not understand Russian, but I understand the words of the program. Now I've gotten to know the words parameters, the OBD errors, etc. etc
  15. Я техническое LADA NIVA итальянский пенсию. LaНива мне нравится это, потому что я работал в жизни на автомобилях FIAT перед сборочные линии были проданы россиянам. Я уже использовать версию Windows, opendiag но так как есть версия для Android, я хотел бы использовать это. LaНива напоминает мне, когда я работал на Fiat 124, 128 132 127 и т.д. и т.п. Сообщение сценарий. Я также неплохой пользователь системы Linux. И Android является производным от Linux
