manueldord
Информация о manueldord
    bmw 530
    spain
619 просмотров профиля
Достижения manueldord
  1. Hello, partner, they have tried to install an emulator and they have done something wrong, and many DTCs appear here. I have attached DTCs. If someone can guide me, what is happening? Mercedes e350 cdi coupe year 2010 you may have to read the ecu to reset or crash thanks and regards Mercedes-Benz No. : 2079010100 ECU Origin : DCX Supplier : Continental Hardware Version : 07 / 49 Software Version : 09 / 03 Fault Codes ============================================ A280 The configuration of the steering variant is faulty. 9CFB The belt buckles are incorrectly coded. 9BA5 There is a fault in the squib configuration. 9CD9 The squib for the right rear sidebag has an excessively high resistance. 9CD5 The squib for the left rear sidebag has an excessively high resistance. 9B72 There is an internal fault in crash sensor 'Left front door'. A705 Pedestrian Detection Sensor Middle Configuration Mismatch 9B75 There is an internal fault in crash sensor 'Right front door'. C154 Communication with control unit 'Weight sensing system' has a malfunction. 9C16 NECK-PRO head restraint 'Driver' is incorrectly coded. U1008 LIN 1 Bus -
  2. Hello mate, I need to place a new ecu for this car since it was stolen I already have a new ecu from the scrapyard that I need to do to be able to start the car, it can be done immo off or how can I synchronize thanks and regards
  3. how can i read this nec chip
  4. Hello fellow need to pinout of this ezs the pinout that tool r270 has is not the same, someone can help me how does this ezs need to read eeprom for km change chip:NEC
  5. Hello colleagues, I need someone who can help me with this car, I need to know what modules the immo and keyless have to buy a kit in the scrapyard. Can someone help me with what modules does the keyless immo system have, etc. ecu:--------- which more If you leave me skype, we can talk about the doubts I have It is a car that has been removed from the keyless system and I want to put it back in and I need to buy a kit at the scrapyard Just what modules to buy so that everything becomes keyless again someone with nissan experience? thanks and regards
  6. партнер У меня повреждены файлы, и мне нужен полный бдм новый eeprom и прошивка той же ссылки для OBD
  7. это коллеги нужны полный BDM для KTAG здесь прикрепленные данные от ECU спасибо и приветствия VW Scirocco 1,4 TFSI год 2009 ecu: 0261S06704 MED 17.5.5 160hp sw: 1037515354 03C9060227BS 0888
  8. масса земли до шасси и аккумулятора в идеальном состоянии
  9. где я могу получить схему подключения и экю, чтобы знать все земли
  10. Привет, коллеги, и я проверил, что тесто достигает 4-го контакта и прибывает отлично но я поместил прямую массу в корпус экю и машина отлично заводится что могут случиться товарищи спасибо и привет
  11. https://www.auto-chips.com/repair-kit-for-vag-04l907309b-edc17c64-0281018510-ecu-p2191.html его можно починить, но я понятия не имею, что кто-то из вас может что-то знать о том, что может быть, если у меня открыт ЕС, но ничего не сгорело
  12. Здравствуйте коллеги, мне нужно починить эту смену терминала ecu edc17c64 vag golf 7 и коммутатор не имеет связи и не запускается И поскольку они продают ремонтный комплект, это означает, что его можно починить, это транзистор или какой-то компонент, кто-то может мне помочь, какой это компонент, спасибо и с уважением
  13. Hello colleagues I need to repair this ecu edc17c64 vag golf 7 terminal change and switchboard has no communication and does not startAnd since they sell a repair kit, it means that it can be repaired, is it a transistor or some component, can someone help me on what component it is, thanks and regards
  14. companion in the folder this file cas2 and ecu dme eeprom 95640 bmw 118d original------------------ecu DME 2K79X-0924(58)EEP(PU70880_BMW).BIN-----------cas2
  15. Hello colleagues I have problem with this car the car does not start and synchronized but does not start dtc: A0AD The file is corrupt, can you help me with this issue? I also have a file from another car as I can configure it to start thanks and regards bmw 118d edc16 cas2.rar
