MoDiag.professional.v2.0.119
#1
Отправлено 01 Октябрь 2010 - 11:23
modiag программа для OBD диагностики работающая с ELM 327адаптером.
Удобная для тех кто устанавливает газ
Letitbit
Shareflare
#2
Отправлено 01 Октябрь 2010 - 17:13
tikhon (01 Октябрь 2010 - 11:23) писал:
Letitbit
Shareflare
#3
Отправлено 01 Октябрь 2010 - 17:44
#4
Отправлено 03 Октябрь 2010 - 10:42
modiag_update_pro.exe from
www.mobydiag.de/software/update_pro.exe 10.x MB
If you want to install modiag, but the licence file for activation dosn't
work... i can't test it but i want to test it...so i have searched and
found
another way to activate and test it ...now i will show you how I did it...
1. install modiag (but not the Update)
2. install Numega Smartcheck
3. connect the Interface to the car
4. start modiag and affilate it with the car that the Interface take the
SN to Modiag. (required for activation) <---chooese right com
port, com port speed
5. start Numega Smartcheck
-----> 1. open SMARTCHECK
2. open modiag in SMARTCHECK (CTRL+O)
3. press F5 or the "Play"Button
4. modiag starts -> Autorize /Activate -> chose Interface boundet -> press
next button
5. type 11111-22222-33333-44444-55555-66666-77777-88888 as aktivatecode ->
press next button
6. it depense a error message "Error during activation", dont close it
7. back to SMARTCHECK and press the end-button (red quadrat) and affirm
8. in SMARTCHECK under "View"press "Expand All" <----select the right
window before that to enable "Expand all"
9. in the left window of SMARTCHECK scroll completly down <---item named
Mid(VARIANT:ByRef String:"DB3A7-EF...
10. the entry over txtActivationKey.Text (Mid or Len returns long 4 click)
in the right window appears a long character string (the key), enter it
into modiag without the last sign (-) , restart modiag , Key accept? then
close
11. install update version 2.8.500
12. modiag start>setting>lizencedata>export
13. now we have got the lizence data and the activation.
if you plesure this SW please buy it...
http://rapidshare.co...eck_6.2_rc2.rar 20.6 MB
passwd: 123456
serial:5102-3133F7-7D
fill out company name!
Информацию не проверял
#6
Отправлено 03 Октябрь 2010 - 20:10
grig43777 (03 Октябрь 2010 - 12:30) писал:
http://torrents.thep...535.TPB.torrent
#7
Отправлено 04 Октябрь 2010 - 00:25
А пока,попробуйте сделать апдейт
http://www.mobydiag....h/downloads.htm
и заменить эти файлы,всё так же,как для предидущих версий,должна активироваться,минимум со 2 раза.
#8
Отправлено 04 Октябрь 2010 - 02:11
#9
Отправлено 04 Октябрь 2010 - 09:52
tikhon (04 Октябрь 2010 - 02:11) писал:
http://shareflare.ne...moDiag.rar.html
Извините за неудобства,прошу ответить,что получилось.
#10
Отправлено 04 Октябрь 2010 - 17:17
Устанавлеваем MoDiag.professional.v2.0.110,можно здесь:
http://letitbit.net/....0.110.rar.html
http://shareflare.ne....0.110.rar.html
Качаем Winhex,можно здесь
http://shareflare.ne...x_14.5.zip.html
Запускаем Winhex
Запускаем MoDiag,жмём Order/Activate,галочку computer bound,Next;
Username: Vasja Pupkin
Company: Team Pupkin
Adress1: Moskow
Email: vasja@mail
Жмём Next;
Нам дали,например, Product ID:322BD-696F4-8A446-1B85A-3E84B-3C49A-01B69-1408A
В Please enter key:вводим например:
11111-22222-33333-44444-55555-66666-77777-88888 т.е.
В формате:XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX-XXXXX 8 по 5 знаков
Жмём NEXT: и выскакивает окно: Error during activation !!!!!!
Стоп в moDiag больше ничего не трогаем
В Winhex Инструменты->Открыть RAM->в конце ищем modiag->Первичная память:
Поиск:вставляем Username: Vasja Pupkin только имя,т.е Vasja Pupkin Ок
Мы перешли к коду Vasja Pupkin Team Pupkin Moskow vasja@mail и ID который нам дали
Смотрим строчек 20-30 выше и видим:
3.2.2.B.D.-.6.9.6.F.4.-. и.д. то-есть наш ID.а далее видим код тоже через точку,который и
есть наш key: что-то вроде 9.0.A.B.9.8.F.0.0. и т.д.,разбиваем на 8 по 5 знаков и получаем:
90AB9-8F00B-EE794-C31E0-29AE0-67C83-BF367-A702C
Идём в moDiag,жмём ок в наге и по новой вводим выдранный key,жмём Next и мы обладатели
про-версии MoDiag.professional.v2.0.110
КЛАСС!!!!!!
Далее качаем апдейт с сайта производителя:
http://www.mobydiag..../update_pro.exe
или апдейтимся прямо из программы,я качал 10Mb
Запускаем апдейт и "чудес не бывает" мы обладатели про-версии MoDiag.professional.v2.8.500
Всем спасибо за внимательость.
#12
Отправлено 05 Октябрь 2010 - 09:00
#13
Отправлено 18 Октябрь 2010 - 17:48
#14
Отправлено 16 Январь 2011 - 21:04
Сообщение отредактировал oleg88462008: 16 Январь 2011 - 21:14
#15
Отправлено 10 Март 2011 - 14:05
#16
Отправлено 10 Март 2011 - 18:45
#17
Отправлено 18 Июль 2011 - 00:35
#18
Отправлено 24 Июль 2011 - 20:53
#19
Отправлено 25 Июль 2011 - 13:36
Seriy80 (24 Июль 2011 - 20:53) писал:
Делаем всё как в инструкции. То есть запускаем ВинХекс, оставляем на столе, запускаем прогу (обновлённую уже, ессно), вводим какой-нибудь код. ОНО пишет, что "фиг вам". Заходим в ВинХекс и по тому же сценарию рисуем в поиске Васю Пупкина. Находит оно эту Васю. Но теперь не вверх на 20-30 строчек, а вниз строчек на 80-100-200. Там оно будет. Причём уже разделённое через точки и тире. 40 символов подряд в виде Е.3.4.5.2.0.-6.5.А.5.1.-...... и так далее. Точки убираем, тире оставляем и вводим в модиаг. Всё заработает. Набираемся терпения и внимания и находим. Я устал читать по всему инету "типа чудес не бывает и всё обновляется и работает". Какая-то падла растиражировала по всей сети это описалово, и теперь ни один нормальный чел не может найти реального решения. Написал я это всё в западляк тем чертям, которые у себя запустили, а для других молчат, мол, пусть парятся и другие. А я хочу, что б у всех работала обновлённая версия.
Примечание: если не пашет один вариант ВинХекса, скачайте себе другой, следующей версии или предыдущей.
Сообщение отредактировал aikonss: 25 Июль 2011 - 13:38
#20
Отправлено 27 Июль 2011 - 09:35
Да тут пути разные....я на 7 - 64битку впервый раз раскатал минут за 5,на ХР тоже влёт....а потом на 7-32 битку мучил дня 3...причём как ни странно номер нашёл в винхексе по первым 5 цифрам ID и с последним винхексом)))
А до этого ни один вариант не срабатывал))))
Вобщем если очень хочется пользоваться этой хорошей прогой,то или сиди кури Винхекс или айда покупать на офф.сайт.Думаю 100% инструкции по активации нет,но очень хорошо,что есть пинок в нужную сторону))))
Удачи!
