Autoscanner Opel 1065
o717ka
  • Upvote 1
  • Downvote 1
OPEL Scanner v1.0.1.71
пароль: sdjdbhkhg
Русский присутствует
скачать
New version of software AutoscannerOpel (1.0.1.71).
Corrected:
- updated the ECU selection list
- fixed R-N parameter on AT13/20 KWP
Added:
- HeadLampLevelling system to OAG
- ODO correction on OAG after MY2000
- ECU ID on ABS8, Meriva
- ECU ID on SAB6b
- ECU ID on OCC BCM
- ECU ID on Instrument OVB
- ECU ID on ME7.6.1
- ECU ID on Multec H, Z16YNG
- ECU ID on MultiJet
- actuator tests on EDC15C7
- actuator tests on PSG16
- EGR parameters on Simtec71
- Control ECU on Instrument OOB
GM OPEL / VAUXHALL SCANNER
The AutoScanner Opel program is designed for OPEL cars diagnostics. The program supports majority of electronic control units (ECU), installed on Opel cars in 1987-2008 years. Using this interface you can fully maintain and diagnose vehicules OPEL vehicules.
Advanced version features:
Main features - provides diagnostics + immo1 key registering/erasing using valid Security Code + eeprom/eprom/ram reading from selected modules + odometer correction for some Opel Instruments (Vectra B up to MY99 and Astra G with VDO instrument in the current version)
Supported cars:
Antara (2007-),
Agila (1998-2006)
Ascona (1987-1989)
Astra-F (1992-2002)
Astra-G (1998-2006)
Astra-H (2004-)
Calibra (1990-1997)
Corsa-A/Combo (1987-1993)
Corsa (Vita)-B (1993-2000)
Corsa (Vita)-C (2001-2006)
Corsa-D (2007-)
Frontera-A (1992-1998)
Frontera-B (1999-2005)
Kadett-E (1987-1991)
Meriva (2003-2006)
Omega-A (1987-1994)
Omega-B (1994-2003)
Senator-B (1987-1993)
Sintra (1997-2000)
Speedster/VX220 (2001-2006)
Tigra A (1995-2000)
Tigra B (2005-)
Vectra-A (1989-1995)
Vectra-B (1996-2001)
Vectra-C/Signum (2002-)
Zafira A (1999-2005)
Zafira B (2006-)
Supported modules are:
Engine Control Unit;
Automatic Transmission Control;
ABS - Anti-Lock Brake System
ESP - Electronic Stability Program
AirBags;
Immobilizer;
Distributor Transmission 4WD;
Traction Control;
Body Control System
ATWS - Anti-Theft Warning System
Central Door Locking System
Multi/Color/Triple Info Displays
Instrument;
Power Steering;
Audio System;
Electronic Climate Control;
Sliding Roof;
Electronic Seat Memory;
Add-On Heater;
Headlamp Leveling Device,
and more...
The AutoscannerOpel supports following features:
Reading Identification info from ECU. Depending on the ECU, the ID can contain VIN, hardware number, software number, manufacturing date, etc.
Reading/Erasing Trouble Codes. Provides information about trouble codes, their description, status and conditions, when the code registered in ECU’s memory.
Live data display. In this mode the live data value is displayed in two ways – digital and graphical. For many parameters the information on “ideal” values for the given parameter is provided.
Advanced Graphic Mode for Live Data Display. This mode allows watching simultaneously up to 4 live data parameter charts with recoding feature.
Actuator Control. is capable to control actuators (fuel pumps, injectors, ignition coils, fans, telltales, etc) on the most of the Opel ECUs. At the same time the actual values can be observed.
Reading firmware on selected ECU.
Odometer correction on some models - Vectra B all, Astra G VDO all, Zafira A VDO all.
Key registering/erasing on Immo1 and Immo2 (valid login required)
Some coding functions, Airbag deployment record reset on Astra H / Vectra C / Corsa D, SAS adjustment, etc.
Advantages of the program, comparing to other similar scanners:the best capabilities on Opel cars diagnostics among non-official diagnostic devices;
simple, user-friendly and powerful interface;
information on trouble codes and parameters allows to conduct car diagnostic in more efficient way;
updates released every 2 months and include new features and bug fixes.
only scanner available on the market that enables to scan with success cars older then 97
System requirements:
Windows 2000/XP/VISTA, available USB or COM-port.
Includes:
USB or serial COM OPEL SCANNER Interface (inside obd2)
ALDL 10pin ADAPTER
OBD2 cable
software v1.0.1.70 advanced
  • Upvote 1
пробуй с шнуром от 1065, должен работать
прога работает только со своей прошивой. номеру проги соответствует только своя прошива. другие шнурки блокируются.
так что осторожней.
Autoscanner Opel 1065 прошива от 1014 A92. прога будет блокироватся по дате . нужен откат.
OPEL Scanner v1.0.1.71 кто опробует отпишитесь, должна работать
Не пробуйте! Просто помрёт и 65 не останется! А 1014 очень ерундовая там много чего нет , даже АБС на Астре 98г не видит
от одной попытки не помрёт,а выдаст прредупреждение,что возможен кирдык
Я покупал шнурок и эта прога была на диске. Так что работаю с ней уже давно, а версией прошивки и не заморачивался.
это говорит о том, что версия прошивки в твоем шнурке и версия проги на диске друг дружке соответствуют. в остальных случаях - шнурку придет кирдык.
Вообще-то это версия не 71ая,а 70ая переделанная для определённых серийников,в конкретном случае это А265.
С прошивой а ля А92 работать не будет даже с ид А92 из этой серии.
Кто успешно собрал интерфейс, подскажите какую конфигурацию при записи 2313 надо выставить?
Вот но только на апельсин но по аналогии выставить можно и на понике
Мне нужна рабочая программа для ver.1065 или прошивка на 2313 для ver.10171.
Если кто-нибудь может помочь я был бы признателен.
Скачал порога от первом посте но выбирая ЕКУ дает ошибка.
У меня есть самодельный кабель с прошивкой под 1065 которой работает с 1014.
Изменено пользователем ivan_pop
