shadab
  1. I have seen a new software called Jadoogar Smartkeyprog. for Toyota and Lexus. The Company claims that it can Add key, Reset Immobilizer and Reset Smart key ECU. You can also try it out.
  2. Error Code: P0753 Description: Solenoid Valve 1 - Open or Short to Earth or B+ Causes: Wiring/Connectors from/to Solenoid Valve 1 (N88) Open or Short to earth. Solenoid Valve 1 faulty. Engine control module (ECM)/Powertrain control module (PCM)/Transmission control module (TCM) (J217). Possible Solutions: - Check/Repair Wiring/Connectors from/to Solenoid Valve 1 (N88). - Check/Replace Solenoid Valve 1. - See Measuring Value Blocks (MVB). Error Code: P0758 Description: Solenoid Valve 2 (N89) B - Open or Short to Earth or B+ Causes: Wiring/Connectors from/to Solenoid Valve 2 (N89) Open or Short to earth. Solenoid Valve 2 faulty. Engine control module (ECM)/Powertrain control module (PCM)/Transmission control module (TCM) (J217). Possible Solutions: Check/Repair Wiring/Connectors from/to Solenoid Valve 2 (N89). Check/Replace Solenoid Valve 2. See Measuring Value Blocks (MVB). Perform Output Test.
  3. TP Sensor reading is 9.8% at idle.
  4. Error Code: P0920 Description: Gear Shift Forward Actuator - Open Circuit Possible Causes: - Wiring. - Gear shift forward actuator. - Engine control module (ECM)/Powertrain control module (PCM)/Transmission control module (TCM).
  5. Error Code: P0336 Description: Crankshaft Position (CKP) Sensor - Circuit Malfunction, Range/Performance Problem Possible Cause: - Insecure sensor/rotor. - Air gap. - Wiring. - Crankshaft position (CKP) sensorr/Engine speed (RPM) sensor).
  6. shadab опубликовал тема в Обсуждение форума
    Hello. I am new to this Honorable Forum. I am running my automotive workshop in Rawalpindi, Pakistan. I have Joined the Forum to glaze my Eyes with the new Automotive Technologies Which are Discussed in this prestigious Forum and to share my Knowledge with the members here. I Wish All to the Management and as well as to every Member of this Forum. Regards, Shadab
