miki4
  1. hi ,, the name is regfile is wrong. it works without the "a" from BAYRAKA ( BAYRAK is okay ,, BAYRARA is wrong ) correct code: finger print: 86F3-135B name: BARBAROS BAYRAK key: 01DUVE-EGZVT7-UPXEX2-030V1H-THYW3W-KNB613-VD6962-JAW1EN-PC18E5-CVEGX0 fingerprint is generated by loader. if loader not work you must kill armadillo keys using the programm "trailreset".
  2. my english is bad. i need only the dump. The code i can scan. code off or on i can activate or disable. the dump is only for test on radio after modification. thanks
  3. hello , my vito have starting problems. the battery is okay. The engine have a little fuel in the filter. the tank is full and have no electrical fumpump. only tankgauge. i have a leak in the fuelhoses. Have anybody an idea with this cammon rail injectionsystem? how much pressure is needed that the injectors are working? i mean it is not enough pressure in cammonrail highpressuretank.
  4. Hello ,, i search a eeprom dump for car radio seat alana 1 mp3 . it is the standard din radio. i need no code from dump. can anybody help me ? thanks
