vladgsm1
Весь контент vladgsm1
  1. How to program virgin dump in to vp44 pump? thanks
  2. english please
  3. vladgsm1 опубликовал тема в Иммобилайзеры
    Please help with immo off for peugeot 307 year 2002 engine 1,4l 16v ecu bosch 0 261 206 943 ME7.4.4 eprom 95160 thanks peugeot_original.rar
  4. english please
  5. vladgsm1 опубликовал тема в Иммобилайзеры
    Please remove immo for renault master 2003 engine 2.2l ecu bosch edc 15c3 immokiller and renault immo not work eprom sp08 and flash 29f400 Thanks master.rar
  6. dump tested car not start, dump not work
  7. pass: immo
  8. test and report thanks
  9. vladgsm1 опубликовал тема в Иммобилайзеры
    please help with immo off for dacia solenza 1.4MPI Ecu siemens 3132 immokiller and renault immo not work. thanks solenza_siemens.rar
  10. write dump in eprom and writw dump in flash 29f400 dump work 100% tested pass : immo immooff.rar
  11. No work for sirius 32 N, no work supernova
  12. Merсedes Vito 109cdi 2003 edc 16c2 Customer had problems opening vehicle with remote key, had key battery changed. Spare key worked fine. After 2 weeks both keys failed to open vehicle Now both keys will not open vehicle - access through passenger door with emergency key Local fast fit told customer that vehicle battery was faulty and required replacing? Battery replaced yesterday without success. Insert key - will not turn - no warning lamps Plug in using X431 get access to body, panel but no engine - loads of power and comms related codes. Obviously some systems can be accessed without ign on to read and clear codes but not DAS. To me the key is not being recognised BUT How would you be able to turn on ignition to start fault interrogation if for example you had a reader fault or ignition switch fault if it cannot recognise key?
  13. remove eeprom and try 100% working
  14. dacia supernova, 6F8Q
  15. vladgsm1 опубликовал тема в Иммобилайзеры
    please help me give me schematic and dump for emulator renault sirius32 Thanks
