jipis
Новичок
  1. Diagnostic trouble code (DTC) information SRS-U300000 Condition The Supplemental restraint system module (SRS) checks internal components in the control module. The diagnostic trouble code (DTC) is stored if the control module detects that: ■ Internal components do not work. ■ Incorrect value runs longer than 2.5 seconds. The control module's test for the diagnostic trouble code (DTC) starts in the event of: ■ Ignition position II and III. Only during start-up of the supplemental restraint system. Note! The control module can only detect the fault once the test has been started and the diagnostic trouble code (DTC) is stored when the conditions are met. Substitute value ■ None. Possible source ■ Damaged supplemental restraint system module (SRS). Fault symptom ■ SRS warning light on ■ SRS warning message displayed
