Опубликовано 21 мая, 201015 г. Hello. I need the assistance of immo-off, the key was lost renault clio II and three days I have been trying to cancel immo box ... the light was extinguished but the scanner says this immo active, ask if anyone had made this car to advise me where to put my hands in front of a renault clio gracias.Es hand ll 1.2i safir2
Опубликовано 22 мая, 201015 г. Автор If .. before I throw it already of this form, This goes 27C512 ... I and well-read and turned To burden the overturned one to 29FXXX, mount again to the car I gave contact 1minuto despues and burdened his originally. The light of picture I extinguish it seems as the key recognizes ... the scanner does not give me ningun mistake, nevertheless I enter the values of immo and it gives me that "I" "activate" this one I put the dumps of this ecu that and used.
Опубликовано 23 мая, 201015 г. Автор Not, probe this dump that I order now ... but I need one that this verified. Thank you.
Опубликовано 24 мая, 201015 г. This dump(clear) must work, you immo has disconnected? Unless works signifies needs the emulator.
Опубликовано 24 мая, 201015 г. Автор Thank you friend, Voy to try to do again ... possible slightly not done well, like always with the hurry. Of all it forms thank you very much, as that I make again you dire since it was the thing. Regards.
Опубликовано 1 июня, 201015 г. Hola: Mi experiencia con la Zafir 2 es con Twingo, debe ser lo mismo, lo que yo hice es meter el codigo de arranque de emergencia con el scanner, una vez que arranco sin quitar contacto desconectas en modulo del immo y listo El pincode esta en el Trans Plaf ó Trans Car en una 93C46 Si necesitas diagramas tengo Santiago
Опубликовано 15 июня, 201015 г. Автор Hola: Mi experiencia con la Zafir 2 es con Twingo, debe ser lo mismo, lo que yo hice es meter el codigo de arranque de emergencia con el scanner, una vez que arranco sin quitar contacto desconectas en modulo del immo y listo El pincode esta en el Trans Plaf ó Trans Car en una 93C46 Si necesitas diagramas tengo Santiago Gracias amigo, ya e arrancado..lo que pasa que tuve cortar el cable de immo_pin 30, por esto mismo lo e montado tanto lio....por no ser atento de las cosas(esto todo con prisa) De toda forma muchas gracias.
