нужна подсказка
Здраствуйте не кто не сталкивался лачетти 1.6 при переключении передач подбрасывает сама обороты до 500 подсоса воздуха нет эбу новый дросель новый на холостом ходу ведёт себя одыкватно ?
ммммм до 500? подкидывает, а хх скока ваще?
холостой 850 -870 но когда стою на месте делаю перегазовку всё ок нормально набирает сбрасывет только в ходу и только с переключением передач такой цырк!(
Hello,
If you have already replaced the ECU and the Throttle Body without any vacuum leaks, you are likely looking in the wrong place.
On manual transmission cars like the Lacetti, the most common cause of RPM flaring (or rev hang) when shifting gears is a faulty Clutch Pedal Position Switch.
When you press the clutch to shift, the engine loses its mechanical load. If the clutch switch is broken or disconnected, the ECU does not know you are shifting. It fails to cut the fuel in time, causing the RPM to suddenly spike by about 500 RPM.
Connect your scanner, go to Live Data, and check if the state of the Clutch Switch changes from OFF to ON when you press the pedal.
Good luck!
Hello again,
Since I am a new member, the forum does not allow me to attach pictures yet. However, what you are looking for is the Clutch Pedal Position Sensor (GM Part Number: 10366474).
It is a rotary sensor with a forked arm. You will NOT find it in the engine bay. You must look inside the cabin, deep under the dashboard, directly attached to the clutch pedal bracket.
If this sensor is missing, unplugged, or physically broken, the ECU will not know when you press the clutch to shift. This is exactly what causes the 500 RPM flare.
You can search Google for that GM part number to see what it looks like. Good luck!
В 10.10.2026 в 01:04, лазер сказал:
Thanks a lot, but there is no such sensor!
o yes😉
