Skoda Oktavia 2007
Парни подскажите как активировать ц/з на Шкоде ключи привязал а активировать ц/з по мануалу T-300 не получается может есть какието нюансы.
Думаю - все так же, как и на всех вагах этой серии. Берем ВАГ-КОМ или Лаунч или ему подобный и - далее по инструкции:
[select]
[46 - Cent. Conv.] or [35 - Cent. Locking]
[Adaptation - 10]
Enter channel "01" (May be channel "21" in some Audi models).
[Read]
This will display the number of currently stored remotes in "Stored Value".
Enter your total number of keys up to a maximum of 4(including any existing keys) in "New Value"
[Test]
Verify that the number in "Test Value" is correct.
[save]
Then press and hold (for at least one second) the UNLOCK button on the fob, at which time it will be learned. If you're programming more than one fob press and hold the UNLOCK button on the second fob for one second, press and hold the UNLOCK button on the third fob for one second, etc. You have a total of 15 seconds to do them all.
The car may give you some sort of acknowledgement as each key is learned (lights flash, horn beep, etc.)
jevgensolo спасибо за инфу . жаль что машинка уехала .
