Мануалы Launch X-431, GX3, Diagun, Master
  • Ответов 142
  • Просмотры 68,2 тыс
  • Инструкции Launch X-431, GX3, Diagun, Master Toyota Diesel Injector Reprogramming.pdf Introduction of Toyota Transponder code Registration (II).pdf TOYOTA Accumulator Pressure Down to Zero Drive.pd
  • Инструкции Launch X-431, GX3, Diagun, Master Mercedes Sensotronic Brake Control Adaptation.pdf How to Match Mercedes-Benz W220 Instrument (ICM).pdf ISUZU(Thailand) Diesel Injectors Programming.pdf
  • Инструкции Launch X-431, GX3, Diagun, Master ECU Code for VW Model.pdf Guide for VWspecial function operation.pdf Audi A6L Service lamp Reset & Service Interval Set.pdf
нет, не лучше, никто не будет 100 мегабайт качать, по маркам какую нужно - выберут сами. кстати, ты зачем дублируешь файлы ALEXа ?
Seat_24.80.pdf
Skoda_24.80.pdf
Ssangyong_17.10.pdf
SUBARU_21.00.pdf
SUZUKI_28.10.pdf
Volvo
volvo (3).TCM_Resetting the adaptation.pdf
volvo (4).TCM_Calibration of position sensor.pdf
volvo (16).DIM_Programming the unit for temperature.pdf
volvo (45).ABS_Reading off the configuration.pdf
volvo (47).ABS_Calibration.pdf
volvo (5).SRS_Checking the PAD-light.pdf
volvo (11).ECM_Adaptation of the throttle unit.pdf
volvo (29).DDM_Initialize the window.pdf
volvo (1).UEM_Configuration of the siren.pdf
volvo (2).TCM_Resetting the counter for Transmission oil, change.pdf
volvo (6).SRS_Calibrating the occupant weight sensor _OWS.pdf
volvo (7).REM_Calibrating the position sensor for Bi-Xenon lamps.pdf
volvo (8).PDM_Initialize the window.pdf
volvo (10).ECM_Resetting the adaptation values.pdf
volvo (12).DIM_Testing all displays and lamps in instrument.pdf
volvo (15).DIM_Programming the units for the trip computer.pdf
volvo (18).DIM_Programming the engine time conditions for service.pdf
volvo (20).DIM_Programming text message,seatbelt reminder.pdf
volvo (21).DIM_Programming parking brake warning.pdf
volvo (22).DIM_Programming instrument lighting.pdf
volvo (23).DIM_Programming distance conditions for service.pdf
volvo (24).DIM_Display of DSTC message.pdf
volvo (30).CPM_Programming the additional and parking heater.pdf
volvo (31).CI_Resetting the service reminder indicator _SRI.pdf
volvo (43).CCM_Self-adjustment of damper motor end stops.pdf
volvo (44).CCM_Reading-out programmed parameters.pdf
volvo (46).ABS_Checking brake light switch adjustment.pdf
voplvo (14).DIM_Read out programmed values.pdf
Стараюсь без дубляжа!
Найдете что выкладывайте не стесняйтесь!
Изменено пользователем cfljdybr
ещё немного
а почему при попытке скачать получаю сообщение
[#10171] У вас не достаточно прав для загрузки данного прикрепленного файла.
но ведб зашел как зарегистрированный пользователь
Операции по Коррекции Одометров EUROFORD
How to read out Ford flashing code with X-431
Жаль , что только в бОльшую сторону ... Нельзя ли его сначала "обнулить" как нибудь без разборки )))
ЗЫ Интересно , а алгоритм "только в большую сторону" заложен в щитке или в программе ? Если в программе - можно попробовать обмануть .
Hola , amigos soy de Chile , ¿ como puedo participar en este foro ?...
¡Hola
Abrí un nuevo foro para Inglés oradores. http://www.auto-technology.pro/
tiene que escribir tres mensajes en el foro
entonces usted puede descargar los archivos.
Alex
TOYOTA Linear Valve Learn Value Initialization.pdf
перезалей плиз, скачивает но при открытии говорит файл поврежден
Изменено пользователем vbv
а есть VW-Audi каналы адаптации и данные начальных установок
что они обозначают???
В версии 25.90 В основном меню в самом низу появилась дополнительное подменю Chanel information, вот как раз таки там весьма подробно надо отдать должное расписано что где да как можно адаптировать и проверить в базовых установках.
а есть инструкция по адаптации дросселя?
Тоже интересует вопрос про адаптации которые может Diagun.
инструкции не какие не нужны, все инструкции описаны в сканере, на примере NiSSAN X-TREIL входишь в меню адаптации - сканер напишет что нужно сделать, прогреть двигатель предварительно до 90градусов, выключить все электро потребители (печку, кондишен, свет и т.д.) почистить дроссель) после этого только делать адаптацию, думаю не чего сложного если хотя бы минимально знать технический английский, если нет то делаете скрин правил адаптации и сидите переводите.
Друзья, а может кто-нибудь выложить все эти мануалы на каком-нибудь торренте? Например rutracker.org, как самый популярный.
А где взять технические термины на английском языке?
чтоб их выучить.
Изменено пользователем Aleksey_1
Всем привет.
Где бы почитать про диагун подробно о его работе, этакий обучающий курс. Есть желание взять, но сначала хотелось бы узнать о нем побольше.
Зарегилась на форуме, но скачать файлы прав пока нет.
А хртелось бы узнать подробности по диагностике, привязке ключей, работе с иммо и другими системами.
И почему дилеры не делают обучающего видео курса по оборудованию-лучше продажи бы шли.
