Мануалы Launch X-431, GX3, Diagun, Master
  • Ответов 142
  • Просмотры 66,9 тыс
  • Инструкции Launch X-431, GX3, Diagun, Master Toyota Diesel Injector Reprogramming.pdf Introduction of Toyota Transponder code Registration (II).pdf TOYOTA Accumulator Pressure Down to Zero Drive.pd
  • Инструкции Launch X-431, GX3, Diagun, Master Mercedes Sensotronic Brake Control Adaptation.pdf How to Match Mercedes-Benz W220 Instrument (ICM).pdf ISUZU(Thailand) Diesel Injectors Programming.pdf
  • Инструкции Launch X-431, GX3, Diagun, Master ECU Code for VW Model.pdf Guide for VWspecial function operation.pdf Audi A6L Service lamp Reset & Service Interval Set.pdf
нет, не лучше, никто не будет 100 мегабайт качать, по маркам какую нужно - выберут сами. кстати, ты зачем дублируешь файлы ALEXа ?
Seat_24.80.pdf
Skoda_24.80.pdf
Ssangyong_17.10.pdf
SUBARU_21.00.pdf
SUZUKI_28.10.pdf
https://www.auto-bk.ru/forum/topic/16790-%D0%BC%D0%B0%D0%BD%D1%83%D0%B0%D0%BB%D1%8B-launch-x-431-gx3-diagun-master/page/2/#findComment-191726
Volvo
volvo (3).TCM_Resetting the adaptation.pdf
volvo (4).TCM_Calibration of position sensor.pdf
volvo (16).DIM_Programming the unit for temperature.pdf
volvo (45).ABS_Reading off the configuration.pdf
volvo (47).ABS_Calibration.pdf
volvo (5).SRS_Checking the PAD-light.pdf
volvo (11).ECM_Adaptation of the throttle unit.pdf
volvo (29).DDM_Initialize the window.pdf
volvo (1).UEM_Configuration of the siren.pdf
volvo (2).TCM_Resetting the counter for Transmission oil, change.pdf
volvo (6).SRS_Calibrating the occupant weight sensor _OWS.pdf
volvo (7).REM_Calibrating the position sensor for Bi-Xenon lamps.pdf
volvo (8).PDM_Initialize the window.pdf
volvo (10).ECM_Resetting the adaptation values.pdf
volvo (12).DIM_Testing all displays and lamps in instrument.pdf
volvo (15).DIM_Programming the units for the trip computer.pdf
volvo (18).DIM_Programming the engine time conditions for service.pdf
volvo (20).DIM_Programming text message,seatbelt reminder.pdf
volvo (21).DIM_Programming parking brake warning.pdf
volvo (22).DIM_Programming instrument lighting.pdf
volvo (23).DIM_Programming distance conditions for service.pdf
volvo (24).DIM_Display of DSTC message.pdf
volvo (30).CPM_Programming the additional and parking heater.pdf
volvo (31).CI_Resetting the service reminder indicator _SRI.pdf
volvo (43).CCM_Self-adjustment of damper motor end stops.pdf
volvo (44).CCM_Reading-out programmed parameters.pdf
volvo (46).ABS_Checking brake light switch adjustment.pdf
voplvo (14).DIM_Read out programmed values.pdf
https://www.auto-bk.ru/forum/topic/16790-%D0%BC%D0%B0%D0%BD%D1%83%D0%B0%D0%BB%D1%8B-launch-x-431-gx3-diagun-master/page/2/#findComment-191729
Стараюсь без дубляжа!
Найдете что выкладывайте не стесняйтесь!
Изменено пользователем cfljdybr
https://www.auto-bk.ru/forum/topic/16790-%D0%BC%D0%B0%D0%BD%D1%83%D0%B0%D0%BB%D1%8B-launch-x-431-gx3-diagun-master/page/2/#findComment-191730
ещё немного
а почему при попытке скачать получаю сообщение
[#10171] У вас не достаточно прав для загрузки данного прикрепленного файла.
но ведб зашел как зарегистрированный пользователь
https://www.auto-bk.ru/forum/topic/16790-%D0%BC%D0%B0%D0%BD%D1%83%D0%B0%D0%BB%D1%8B-launch-x-431-gx3-diagun-master/page/2/#findComment-195657
Операции по Коррекции Одометров EUROFORD
How to read out Ford flashing code with X-431
Жаль , что только в бОльшую сторону ... Нельзя ли его сначала "обнулить" как нибудь без разборки )))
ЗЫ Интересно , а алгоритм "только в большую сторону" заложен в щитке или в программе ? Если в программе - можно попробовать обмануть .
https://www.auto-bk.ru/forum/topic/16790-%D0%BC%D0%B0%D0%BD%D1%83%D0%B0%D0%BB%D1%8B-launch-x-431-gx3-diagun-master/page/2/#findComment-200824
volvo DIM Programming the time conditions for service.
volvo (17).DIM_Programming the time conditions for service.pdf
https://www.auto-bk.ru/forum/topic/16790-%D0%BC%D0%B0%D0%BD%D1%83%D0%B0%D0%BB%D1%8B-launch-x-431-gx3-diagun-master/page/2/#findComment-201661
Hola , amigos soy de Chile , ¿ como puedo participar en este foro ?...
https://www.auto-bk.ru/forum/topic/16790-%D0%BC%D0%B0%D0%BD%D1%83%D0%B0%D0%BB%D1%8B-launch-x-431-gx3-diagun-master/page/2/#findComment-203036
¡Hola
Abrí un nuevo foro para Inglés oradores. http://www.auto-technology.pro/
tiene que escribir tres mensajes en el foro
entonces usted puede descargar los archivos.
https://www.auto-bk.ru/forum/topic/16790-%D0%BC%D0%B0%D0%BD%D1%83%D0%B0%D0%BB%D1%8B-launch-x-431-gx3-diagun-master/page/2/#findComment-203040
Alex
TOYOTA Linear Valve Learn Value Initialization.pdf
перезалей плиз, скачивает но при открытии говорит файл поврежден
Изменено пользователем vbv
https://www.auto-bk.ru/forum/topic/16790-%D0%BC%D0%B0%D0%BD%D1%83%D0%B0%D0%BB%D1%8B-launch-x-431-gx3-diagun-master/page/2/#findComment-203424
а есть VW-Audi каналы адаптации и данные начальных установок
что они обозначают???
В версии 25.90 В основном меню в самом низу появилась дополнительное подменю Chanel information, вот как раз таки там весьма подробно надо отдать должное расписано что где да как можно адаптировать и проверить в базовых установках.
https://www.auto-bk.ru/forum/topic/16790-%D0%BC%D0%B0%D0%BD%D1%83%D0%B0%D0%BB%D1%8B-launch-x-431-gx3-diagun-master/page/2/#findComment-205819
а есть инструкция по адаптации дросселя?
https://www.auto-bk.ru/forum/topic/16790-%D0%BC%D0%B0%D0%BD%D1%83%D0%B0%D0%BB%D1%8B-launch-x-431-gx3-diagun-master/page/2/#findComment-230490
Тоже интересует вопрос про адаптации которые может Diagun.
https://www.auto-bk.ru/forum/topic/16790-%D0%BC%D0%B0%D0%BD%D1%83%D0%B0%D0%BB%D1%8B-launch-x-431-gx3-diagun-master/page/2/#findComment-235030
инструкции не какие не нужны, все инструкции описаны в сканере, на примере NiSSAN X-TREIL входишь в меню адаптации - сканер напишет что нужно сделать, прогреть двигатель предварительно до 90градусов, выключить все электро потребители (печку, кондишен, свет и т.д.) почистить дроссель) после этого только делать адаптацию, думаю не чего сложного если хотя бы минимально знать технический английский, если нет то делаете скрин правил адаптации и сидите переводите.
https://www.auto-bk.ru/forum/topic/16790-%D0%BC%D0%B0%D0%BD%D1%83%D0%B0%D0%BB%D1%8B-launch-x-431-gx3-diagun-master/page/2/#findComment-235034
Друзья, а может кто-нибудь выложить все эти мануалы на каком-нибудь торренте? Например rutracker.org, как самый популярный.
https://www.auto-bk.ru/forum/topic/16790-%D0%BC%D0%B0%D0%BD%D1%83%D0%B0%D0%BB%D1%8B-launch-x-431-gx3-diagun-master/page/2/#findComment-237614
А где взять технические термины на английском языке?
чтоб их выучить.
Изменено пользователем Aleksey_1
https://www.auto-bk.ru/forum/topic/16790-%D0%BC%D0%B0%D0%BD%D1%83%D0%B0%D0%BB%D1%8B-launch-x-431-gx3-diagun-master/page/2/#findComment-237832
Всем привет.
Где бы почитать про диагун подробно о его работе, этакий обучающий курс. Есть желание взять, но сначала хотелось бы узнать о нем побольше.
Зарегилась на форуме, но скачать файлы прав пока нет.
А хртелось бы узнать подробности по диагностике, привязке ключей, работе с иммо и другими системами.
И почему дилеры не делают обучающего видео курса по оборудованию-лучше продажи бы шли.
https://www.auto-bk.ru/forum/topic/16790-%D0%BC%D0%B0%D0%BD%D1%83%D0%B0%D0%BB%D1%8B-launch-x-431-gx3-diagun-master/page/2/#findComment-241858
