Pin code uch sagem 93c66 clio 2004 1.5dci
well I need to know what kind of chip is in the IMMO
https://www.auto-bk.ru/forum/topic/24155-pin-code-uch-sagem-93c66-clio-2004-15dci/page/2/#findComment-228573
What ?? I need from Vin....
https://www.auto-bk.ru/forum/topic/24155-pin-code-uch-sagem-93c66-clio-2004-15dci/page/2/#findComment-228578
Jenea , он прав , для пина надо вин , а не "chip "что в имо стоит ( надо , правда еще быть дилером ) .
https://www.auto-bk.ru/forum/topic/24155-pin-code-uch-sagem-93c66-clio-2004-15dci/page/2/#findComment-228588
я спросил какой микроконтроллер стоит значит надо отвечать на вопрос если не будет ответа то и результата не будет
https://www.auto-bk.ru/forum/topic/24155-pin-code-uch-sagem-93c66-clio-2004-15dci/page/2/#findComment-228600
I don't understand what you want..
https://www.auto-bk.ru/forum/topic/24155-pin-code-uch-sagem-93c66-clio-2004-15dci/page/2/#findComment-228607
than read the dump and just tell me what is a microcontroller IMMO
https://www.auto-bk.ru/forum/topic/24155-pin-code-uch-sagem-93c66-clio-2004-15dci/page/2/#findComment-228608
I have virgine BSI dump and there isn't pin, so i need to generate from vin ...
https://www.auto-bk.ru/forum/topic/24155-pin-code-uch-sagem-93c66-clio-2004-15dci/page/2/#findComment-228609
куда пишешь дамп какая микросхема если не ответишь то и я не дам пин
https://www.auto-bk.ru/forum/topic/24155-pin-code-uch-sagem-93c66-clio-2004-15dci/page/2/#findComment-228611
In the thread you have number of chip 93c66
https://www.auto-bk.ru/forum/topic/24155-pin-code-uch-sagem-93c66-clio-2004-15dci/page/2/#findComment-228612
Tomorrow I will give the pin but not for free
Изменено пользователем Jenea
https://www.auto-bk.ru/forum/topic/24155-pin-code-uch-sagem-93c66-clio-2004-15dci/page/2/#findComment-228618
I have question
Can i read and reprogram the transponder in the key ?? I think there is a ID46 Transponder (16pin)..
https://www.auto-bk.ru/forum/topic/24155-pin-code-uch-sagem-93c66-clio-2004-15dci/page/2/#findComment-229036
нет, нужен новый чип PCF7946
https://www.auto-bk.ru/forum/topic/24155-pin-code-uch-sagem-93c66-clio-2004-15dci/page/2/#findComment-229811
если честно то он не спец все в рот положил , могу скинуть и чистый дамп микрухи но все иавно ни чего у него не получится
https://www.auto-bk.ru/forum/topic/24155-pin-code-uch-sagem-93c66-clio-2004-15dci/page/2/#findComment-229865
deluss, no problems, give vin number.
https://www.auto-bk.ru/forum/topic/24155-pin-code-uch-sagem-93c66-clio-2004-15dci/page/2/#findComment-230012
KIMI у них там есть адванчед диагностик кроме того что они продают одно из лучших оборудований они и считают пин по вину и там все на месте , просто данный человек деллетант
https://www.auto-bk.ru/forum/topic/24155-pin-code-uch-sagem-93c66-clio-2004-15dci/page/2/#findComment-230018
