VAG K + CAN COMMANDER V2. 5
Обсуждение VAG K + CAN COMMANDER V2.5, принцип работы, у кого что получилось им сделать какую марку, какие засады с каким автомобилем и т.д.
Diagnostic via CAN and Special functions via K-line.
Covers all electronic control units in vehicles (diagnostic addresses from 0x01 to 0x80). This can allow of user to investigate and diagnosis some new units untouchable for remaining diagnostic tools. Functions are under CAN-TP2.0.
Manual definition of running diagnostic session ¡¡?¬C not like remaining diagnostic tools always standard diagnostic session 0x89. Function is under CAN-TP2.0.
Broadcast diagnostic request ¡¡?¬C disable normal communication, clear DTCs, Logistic (transport) mode,.... Functions are under CAN-TP2.0.
Allows managing of brand new units (and immobilizer units) where is allowed programming of PIN, SKC, BGW, MAC. Functions are under CAN-TP2.0.
Most of popular diagnostic requests ¡¡?¬C identifications, coding, adaptations, DTCs and s.o. Functions are under CAN-TP2.0.
Special function - odometer correction in instrument clusters and EDC15x.
Special function - read Security Access Code/Login WFS.
Special function - read/program immobilizer data.
Special function - read/write EEPROM from instrument cluster/immobilizer. All supported clusters CAN/K.
Special function - VAG MMI TV Activation.
Special function - Read/Write EEPROM of Engine Control Units BOSCH VAG-EDC15x, VAG-ME7.1.1, VAG-Cartronic ME7.8,Porsche.
Special function - Key learning buttons for easy usage (not needed security code). Can do component security authorization.
Special function - Key learning Porsche CAYENNE (not needed security code) K+CAN.
Special function - Custom memory reading from different units like ECUs, EZS-Kessy and s.o..
Special function - Reading flash memories EDC16x, EDC15x, ME7x, MED951, MED751 (with next update will be possible programming of flash memories
Special function - Crash data clear in airbag units
List of vehicles covered from function odometer change via OBDII:
Audi Q7 (CAN)
Audi A2 (K)
Audi A3 (CAN) up to 2007 !!!
Audi A3 VDO/M73 up to 2003 (K)
Audi A4 VDO/M73 (K)
Audi A4 BOSCH - RB4 clusters (CRYPTO eeproms R/W by OBDII)
Audi A6 VDO (K)
Audi A6 (CAN)
Audi Allroud (K) up to 2004
Audi A8 (K) VDO93xx
Audi A8 (CAN) up to 2007 !!!
Audi TT (K)
Seat Alhambra (K)
Seat Altea (CAN)
Seat Arosa (K)
Seat Cordoba after 1999 (K)
Seat Ibiza VDO after 1999 (K)
Seat Leon (K+CAN)
Seat Toledo (K+CAN)
Skoda Octavia (K)
Skoda Octavia II (CAN)
Skoda Superb (K)
Skoda Roomster (K)
Skoda Scout (CAN)
Skoda Fabia (K)
VW Bora (K)
VW Beetle (K)
VW Caddy (CAN)
VW EOS (CAN)
VW Golf4 VDO/Motometer/BOSCH RB
VW Golf5 VDO (CAN)
VW Golf5 VISETEON
VW Crossgolf (CAN)
VW Individual (CAN)
VW Jetta (K+CAN)
VW Passat B5/B6 (K+CAN)
VW Polo VDO/Motometer (K)
VW Sharan (K)
VW T4/T5 VDO (K)
VW Touaran VDO (CAN)
List of vehicles covered from function security access code/login reading via OBDII:
Audi A2
Audi A4 VDO (K)
Audi A4 BOSCH (K) up to 2001
Audi A4 after 2000 - petrol engines >= 1.8
Audi A6 VDO (K)
Audi A6 (CAN) petrol engines
Audi Allroad (K) up to 2004
Audi Allroad (CAN) petrol engines
Audi A8 up to 2001
Audi A8 from 2001 to 2002 2.5TDI
Audi A8 (CAN) 2003+ petrol
Audi TT (K)
Audi Q7 petrol engines
Seat Altea (CAN)
Seat Ibiza (VDO) after 1999 (K)
Seat Leon (K+CAN)
Seat Toledo (K+CAN)
Skoda Octavia
Skoda Superb
Skoda Roomster
Skoda Scout (CAN)
Skoda Fabia
VW Bora
VW Beetle
VW Caddy (CAN)
VW EOS (CAN)
VW Golf5 VDO (CAN)
VW Crossgolf (CAN)
VW Individual (CAN)
VW Jetta (K+CAN)
VW Passat B5 (K) B6(CAN)
VW Polo5
VW Sharan after year 2000
VW T5
VW Phaeton petrol
VW Touareg petrol
PORSCHE Cayenne (CAN/K)
VAGCAN_K_V2.5.rar
https://www.auto-bk.ru/forum/topic/2423-vag-k-can-commander-v2-5/
  • Ответов 362
  • Просмотры 190,8 тыс
  • Из тех что я пользовал это vag k can commander 2.5 ,по цене вполне себя оправдывает.А так доплати не много и купи нев супер ваг командер версия 4.8.Она охватывает все приборы которые ты описал по фун
  • народ у меня 1.4 кЕтай, читает панель ауди а8 2006г, пишет что изменило.. но на панели ничего не меняется... проблема версии или софта ? vag K-can full 1.4
  • софт vag k+can commander 1.4(CHINA)
Thank you.
This one works with VagCan Commander v.1.4 chinese interface?
Thank you.
C version 2.0 tried works, with 1.4 did not try.
Точно работает с китайским 2.0 ?
Потому как слыхал что она валит их...
Изменено пользователем x61080
Точно работате с китайским 2.0 ?
у меня не умер, а за твой естественно не могу не чего гарантировать., на крайнях могу свой продать. :heresmile: , п.с. шутка.
Какой из них с усб ключём 2.0 или 2.5?
2.0 дороже 2.5го.Про 2.0 народ говорил,что не особо лучше 1.4.
они все с ключем идут, 2.0, 2.5.
разницы большой не заметил с версией 1.4
Насколько я понял, попытка работы интерфейсом v.1.4 с версией 2.5 может привести к фатфльному исходу. Так ли это, или же в связи с отсутствием ключа просто не будет работать? И еще вопрос, кто-нибудь пробовал эмулировать USB ключ, с целью работы адаптером от v.1.4?
With vers.1.4 not work. Also the sw says anyway "dog init failed".
The sw needs a key.
Вопрос больше по железу, но не нашел более подходящей ветки ( на усмотрение модератора, может надо в другую тему). Имеется китайский шнурок Vag K+Can 2.5 и USB ключ. Присланная прога совпадает с выложенной выше. Программа пишет "init dog filed". Нашел прогу VAG_K+CAN_Check (идет в комплекте при официальной покупке) для проверки и адаптера и донгла, адаптер определяется, ок, при проверке донгла сразу выскакивает с ошибкой Error 0xD00002 (наверное или глюк, или может есть разные типы донгов, не знаю). Вроде донгл должен быть собран на основе Matrix (китайцы корпус запилили), на сайте Matrix нашел утилиту mxcheck, которая должна проверять донглы, построенные на их базе. Запускаю - ключей 0, хотя сам донгл моргает лампочкой исправно. У китайцев с поддержкой глухо, пишут что что-то не то у меня с драйверами, но система видит и адаптер и ключ (как USB HID устройство, для него дрова не нужны). Может кто-нибудь проверить с работающим шнурком, должны ли эти проги видеть ключ или нет? Сами проги взяты с офсайтов и вроде ничего завалить не должны :) (с меня пиво за риск :))
VAG_K_CAN_Check.rar
mxcheck.rar
я проверял на своем видит, пишет init dog, обнавлял с версии 2.0 до 2.5, не умер пашет,
Хочу уточнить: Какая именно программа пишет init dog - сам командер или Ваг_чек или мх_чек? Хочу определить, что именно в моей связке не работает: программа, ключ, адаптер. Программа у других работает, значит не она. Адаптер Ваг_чек ом определяется как интерфейс c0xx V01.00:7 и он вроде работает с программой v1.4 (вчера проверил на туареге, правда пока только по к линии), с 2.5 отказывается, но ведь и не должен, пока ключ не обнаружен. Остается ключ, так вот в этом и вопрос, как его проверить? Хотя может и сам интерфейс версии 1.4. Продолжаю искать: Кто виноват чтобы было понятно Что делать :)
ИНИТ ДОГ пишет сам коммандер. Без этого ДОГА (он же донгл) версия 2.5 не работает. Купил у китаез командер версии 3.0, но софт они мне дали 2.5, скорее всего легкое "дурилово", не видел нигде версии 3.0 софта. Чтобы ДОГ нормально работал ему нужны дрова, может в этом причина? Еще посмотри в свойствах компа, на какой порт сел этот ДОГ и сам шнурок, может тут засада.
Делал недавно этой приблудой А4 2003 года - ключики вязал. Все прекрасно прошло. Панель была крипто, но пин выдрал из ИСИЮ. Пару пассатов 05 года омолодил. Облом получился на гольфе 2005 года - щиток и моторник читает исправно, но честно пишет - править дамп не могу. И пин прочитать не может. Там пин вроде в Кесси сидит, некогда было разбираться, машина будет на неделе в гараже.
Гольф VDO 24с32 не возьмет, там только в ручную делать или приблудой от росфара.
Вот тут возник вопрос по 2.5
Это что так плохо отломанная версия весом всего 672 кб ?
В тоже время у китайца в версии 1.4 вес 1.4 мб и у него из заявленного половина не работает
Что будет работать в версии 2.5 непонятно !
аирбэги трет, одометры тож работают, остальное не требовалось.
Было актуально пин, а не отмотка. Но тем не менее - можно слить дамп этим шнурком, поправить и залить обратно. А разве Росфаровская приблуда не для крипто щитков после 06 года?
на гольфе 5 панель пападалась вдо уже конец 2005 года, так же попадалась панель шкода 2 2006 года начало года с вдо 24с32., хотя по идее везде написано что с 2007 года они идут.
А Какие блоки именно трёт?
Чет какие я пробывал не работает
Ну а если помоголо кому то буду рад
по большей части народ не умеет их готовить, по этому и говорят что не сьедобно.
мануал где то видел, скачайте почитайте, там все процедуры с блоками описаны.
