Подарили мне UPA USB,пока полностью не разобрался,поставил на пробу 24С04,прочитать не могу,пробывал еще 93С46,результат тот же.
Питание пробывал не через ЮСБ,шнур ЮСБ тоже менял,не читает.
Вот результат теста.
UPA-USB Device Programmer v12113
Licensed to: zhan jie yao*
System: Microsoft Windows XP Professional Service Pack 3 (build2600)
Detecting UUSP...Pease wailt!
Device Description: ELRASOFT UPA-USB Driver (3.4.1.20)
USB Driver Name: UPAUSB.sys, HS Mode
5V Tests. Close J1 and press a key to continue
Test1: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=0,00V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Test2: P1=8V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=7,83V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Test3: P1=9V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=8,93V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Test4: P1=10V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=9,83V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Test5: P1=11V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=10,73V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Test6: P1=12V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=11,84V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Test7: P1=13V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=12,70V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
P1(12,70V ) not in 12,70V - 13,30V
Test Failed
Test20: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=5V
Result: P1=0,00V, P2=3,93V (L), P3=0,56V (L), P4=0,00V (L),P6=3,72V (L), P7=0,69V (L), P8=0,02V (L), P9=4,91V
P3(0,56V ) not in 0,00V - 0,25V
P7(0,69V ) not in 0,00V - 0,25V
Test Failed
Test21: P1=0V, P2=L, P3=L, P4=L, P6=L, P7=L, P8=L, P9=5V
Result: P1=0,00V, P2=0,05V (L), P3=0,00V (L), P4=0,00V (L),P6=0,05V (L), P7=0,00V (L), P8=0,00V (L), P9=4,91V
Test Passed
Test22: P1=0V, P2=H, P3=H, P4=H, P6=H, P7=H, P8=H, P9=5V
Result: P1=0,00V, P2=4,93V (H), P3=4,88V (H), P4=4,87V (H),P6=4,80V (H), P7=4,87V (H), P8=4,93V (H), P9=4,91V
Test Passed
3.3V Tests. Open J1 and press a key to continue
Test40: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=3.3V
Result: P1=0,00V, P2=2,96V (H), P3=0,45V (H), P4=0,00V (H),P6=2,79V (H), P7=0,48V (H), P8=0,02V (H), P9=3,56V
P3(0,45V ) not in 0,00V - 0,25V
P7(0,48V ) not in 0,00V - 0,25V
Test Failed
Test41: P1=0V, P2=L, P3=L, P4=L, P6=L, P7=L, P8=L, P9=3.3V
Result: P1=0,00V, P2=0,03V (L), P3=0,00V (L), P4=0,00V (L),P6=0,03V (L), P7=0,00V (L), P8=0,00V (L), P9=3,54V
Test Passed
Test42: P1=0V, P2=H, P3=H, P4=H, P6=H, P7=H, P8=H, P9=3.3V
Result: P1=0,00V, P2=3,58V (H), P3=3,56V (H), P4=3,53V (H),P6=3,50V (H), P7=3,53V (H), P8=3,59V (H), P9=3,56V
Test Passed
Test60
95420AB08089EAC6
Test Passed
3 Tests failed
Звонил продавцам,говорят привози посмотрим,но ехать далеко,да и Москва сейчас одна сплошная пробка.
А ты тест проводил с микрухой подключенной или просто с голым прогером?
Если прогер был без ничего тогда косяк в сборке, бери пропаивай помогает в 80% случаев остальное нужно смотреть!
И с микрухами и без и вообще без адаптера,постоянно ошибки теста и все время разные,то одна то две то три.
Test Passed
Result: P1=7,85V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Result: P1=8,91V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Test Passed
Result: P1=10,70V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
P1(10,70V ) not in 10,70V - 11,30V
Test Failed
Result: P1=11,81V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Result: P1=12,75V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Result: P1=0,00V, P2=4,01V (L), P3=0,13V (L), P4=0,00V (L),P6=3,85V (L), P7=0,21V (L), P8=0,00V (L), P9=4,93V
P2(4,01V ) not in 3,00V - 4,00V
Test Failed
Result: P1=0,00V, P2=0,05V (L), P3=0,00V (L), P4=0,00V (L),P6=0,05V (L), P7=0,00V (L), P8=0,00V (L), P9=4,93V
Test Passed
Result: P1=0,00V, P2=4,95V (H), P3=4,91V (H), P4=4,88V (H),P6=4,82V (H), P7=4,88V (H), P8=4,95V (H), P9=4,93V
Test Passed
Result: P1=0,00V, P2=3,03V (H), P3=0,13V (H), P4=0,00V (H),P6=2,92V (H), P7=0,16V (H), P8=0,00V (H), P9=3,58V
Test Passed
Result: P1=0,00V, P2=0,03V (L), P3=0,00V (L), P4=0,00V (L),P6=0,05V (L), P7=0,00V (L), P8=0,00V (L), P9=3,58V
Test Passed
Result: P1=0,00V, P2=3,59V (H), P3=3,58V (H), P4=3,54V (H),P6=3,51V (H), P7=3,54V (H), P8=3,59V (H), P9=3,58V
Test Passed
Test60
95420AB08089EAC6
Test Passed
2 Tests failed
Я так понимаю пока тест не будет проходить и никакого чтения не будет?
Правильно понимаеш, пока у тебя не будет верно заданных констант он не будет читать!
Именно это я и хотел услышать.
Придется ехать менять или ремонтировать,звонил они говорят -без вопросов,вези,она заклеена и на гарантии,попандос,но даренному коню кулаками не машут :heresmile:
Так вот вчера и скатался,со своим ноутом, да нетбук еще взял,корче на их ноуте с чистой виндой он работает как часы,на моем ноуте сборка зверь,они сказали что упа с ней отродясь никогда не работала,удивился что у меня на нем Лексия стоит и работает,на нетбуке непонятная сборка XP HOME тоже не работает.
Спросил будет ли работать на Виндос 7 на стационаре,сказали не факт,но скорей всего не будет.
Попробую поставить пару винд XP-PROF с правами администратора(все равно пора переустанавливать)тогда отпишусь.
Во всяком случае я убедился сам что УПА работает,впаивали несколько микросхем что я привозил,все читает на ура,короче зря только 5 часов в пробках простоял.
блин,у меня упа китаец на Звере ХР без проблем работает,зверь,тот что DVD сборка с софтом
Бред сивой кобылы у меня на всех компах и ноуте стоит XP зверинная всё работает.
(они сказали что упа с ней отродясь никогда не работала,)
всё работает без проблем
Ну да,так и есть, поставил чистый ХР,даже проверку подлиности проходит,ни хрена не работает,а на ихнем ноуте работает,после праздников поеду опять со своим ноутом,или они мне обьяснят в чем дело или пусть ее забирают и вернут деньги,я в другом месте куплю.
P.S.Они увидили у меня РР и Лексия стоит,и говорят что не может она работать на этой сборке,я говорю все у меня работает,помоему мне там в уши нассать пытаются.
Уже и я проверил - пашет УПА на звере. Пусть не свистят. Попробуй банально сменить шнур ЮСБ. Хотя вероятность мала.
И шнуры менял и питание отдельно подключал,не помогает,видать здесь другая сборка упы,они и говорили что без прав администратора она работать не будет,теперь у меня есть эти права и если я открываю ее от админа она пишет-failed to create key и комп виснет,после нескольких попыток закрыть програму выскакивает- failed to create key HEX EDITOR.
Какой нахрен ключ она не может создать,лицензия лежит в корне как и положено.
После установки программы , скопироваить из папки license файл uuprog.lic в корень установленной программы, и из папки RUS файл uuprog.RUS.lng >>>>>>>>>>> туда-же.
Вообщем такие дела,со всеми пятью програмами которые на диске с упой она не работала.Нашел случайно,думаю откачусь попробую на 12070,а диска никак найти не могу(к счастью)скачал с нета,поставил(дрова не трогал) и все заработало,потом снес поставил 12170,тоже все работает,снес,нашел диск поставил с него,НИ ХРЕНА,вот так!
