Vw Passat 1999, Bosch No. 0 261 206 044 Flash Dump Needed
Hi. Maybe one of you has flash dump for vw passat 1.8, 20v, 1999, ecu bosh nr: 0 261 206 044, vw nr: 8d0 906 018 g . i am getting error 16989 - internal rom error. and sometimes I can not start the car (then epc lamp on the dash is not on). so i think that this dump could be damaged.
thanks.
p.s. power supplies are ok.
Original 8D0 906 018 R
passat b5 1,8 atm
thanks, mate, but mine is with letter G at the end. and the engine code is PTU - passat 1.8, 20 valves version. thanks.
