Опубликовано 3 июля, 200916 г. Did someone changed the mileage BMW 730 from 1989 year.I'm not work older than 1992.Where is the recorder mileage. I have not noticed properly,except the old NEC procesor.
Опубликовано 3 июля, 200916 г. Did someone changed the mileage BMW 730 from 1989 year.I'm not work older than 1992.Where is the recorder mileage.I have not noticed properly,except the old NEC procesor. NEC в BMW ни разу не встречал!
Опубликовано 6 июля, 200916 г. Did someone changed the mileage BMW 730 from 1989 year.I'm not work older than 1992.Where is the recorder mileage.I have not noticed properly,except the old NEC procesor. Where the dash number ?
Опубликовано 6 июля, 200916 г. ODO is stored in small blackbox inside lightbrown connectíng connector. You need special equipment for it, or make simulator for them....
Опубликовано 7 июля, 200916 г. Автор ODO is stored in small blackbox inside lightbrown connectíng connector. You need special equipment for it, or make simulator for them.... Thanks a lot.
