Software WinOLS 2.24
Программа WinOLS 2.24
Мощный редактор прошивок ЭБУ автомобилей
включают в себя контрольки по EDC17, MED17, Mitsubishi L200, PajeroIV, Pajero SportII и установленными ЭБУ Denso с процессором SH7058
Download software http://letitbit.net/...S_2.26.rar.html
Скачать софт http://depositfiles....files/qpafveodi
WinOLS is an application, which is written especially to modify the memory contents of ECUs.
It makes it easier to search and find maps, which can be named, displayed in several ways and be modified. All data and maps are stored in project files. These project files contain all information, which are gathered during the modification of the ECU. Additional data like customer name, license plate and pictures can be added.
Modifications of maps can be stored as 'versions' and can be commented. Up to 200 versions of one original file are possible.
All modified projects are shown in a list, which can be filtered and sorted. So it is easy to find an already modified project again. Overview:
  • The display of raw data takes place in 2D graphic or hex/decimal dump. Automatic processor detection to decide between code and data areas.
  • Functions to search for maps and to put them down on the map list makes efficient working a lot easier.
  • A 3D preview window makes it easier to find maps
  • Maps can be shown as 3D/2D chart or as a table.
  • Automatic search of ECU and software numbers.
  • You can select either English or German as the interface language and switch between these.
  • The concept of the integrated checksum correction has been kept up. By using DLL files the algorithms were moved out of the main program and thus are independent of the version used.
  • Im- and export of binary files, Intel and Motorola-Hexfiles. All types can be zipped, coded and have swapped lines or be sent directly by mail.
The automatic map search finds maps and shows them in a list and also directly
Preview-Window:
The preview window can be freely moved and sized and shows the selection as 3d-map:
Automatic checksums:
Every checksum module (purchase separately) automatically recognises if it can be used and corrects the checksums immediately after every change. Even in real-time while the car is running. If you don't have the right module yet, the push of a button is enough and online all existing checksum modules will be tested for your project. This way you know for sure which module is the right one. Modules can be purchase online around the clock. You will receive your module within minutes.
Free choice of colour:
WinOLS has 3 predefined colour schemes and you can configure your own individual colours, of course.
More features
  • Original and version: For every project the original is stored permanently. Changes will be stored as version (the number of versions is not limited). Changes are displayed in colour and you can restore the original values any time.
  • Multilevel undo: Up to 50 editing steps can be undone.
  • Scripts for pros: If you work with similar cars, you can store the changes as scripts. This allows you to apply the changes for every new car within seconds.
  • Automatic comments: You can enter comments for every project and every version. Further more they are automatically commented when you import or create new versions.
  • Online project search: Our online-database can automatically fill in the fields like producer, chassis, etc. Several other fields, like Bosch number will even be filled in automatically when you're offline.
  • Complete overview: The project overview shows all your projects in a configurable and searchable list. Within the fraction of a second, even if you have hundreds of projects.
  • Versions: For every project you can create as many versions as like. The version over shows which maps are changed in which version.
  • Open for other projects: WinOLS can import and export binary data, Intel- and Motorola-Hexfiles. Entire maps and the map list can be exported to Microsoft Excel. Maps can be ex and imported from a project.
  • Accept changes: Copy the best changes from old projects. Even if the maps were moved to a different position, they will still be automatically recognized.
  • Extensive help: Texts in the status bar, tool tips for the icons, Instructions for every dialog. WinOLS keeps you informed which every step. Furthermore you can download the entire documentation as PDF here.
  • Many other features. Too many to list all of them here...
Здравствуйте Вячеслав!, подскажите надо прошить мотроник 2.7 fiat punto gt первопунто 176 платформа, говорят что карты она не видит , что адреса самому надо искать а есть прога которая
видит карты? или как их искать? посоветуйте только начинаю и некому помочь поэтому скребу сам! закозал себе программатор TL866a чтобы чип рошить! спасибо за любую инфу!!
  • Ответов 295
  • Просмотры 198,3 тыс
  • вот дамосы , http://depositfiles....lr5sbr?redirect     и ещё   http://depositfiles.com/files/2wi6pfvb1?redirect
  • Да как , либо распознать самому или найти человека , который сделает вам описание . Только вопрос в том , что не кому не интересно продавать карты , потому что их можно будет передавать друг другу . Н
  • что за детсад ? может на флешку залить и вам отправить ? научитесь интернетом пользоваться полноценно и перезаливать не надо будет   под 100 скачавших ....
да крнечно интересная прога но ...
сейчас есть кто нибудь на форуме?
подскажите почему антивир ругается на архив в 1 посту?
ребята кому нужен winols rus пишите
нужен soflexx@rambler.ru заранее благодарю.
Писать в личку нужно
Внезапно перестал работать 2.24, ругается на ошибку загрузки библиотеки. Переустановка не помогает. В чём может быть причина?
Заработало. Причина была в том, что при включении DEP в системе, загрузчик необходимо добавить в список исключений.
почему-то неактивна функция импорта Damos & ASAP2. в чем может быть дело?
сам себе отвечаю. чистка реестра + переустановка помогло
умеет хоть кто-то ей пользоваться ? хочу всего лишь научиться удалять ошибки. интересуют автомобили МВ ,БМВ и ваги. некоторые олс есть-а толку от них ?
Ты хотел наверно написать "удалять маски ошибок" .
да-именно это имел ввиду-сможете помочь ?
нужен 222lahta@mail.ru заранее благодарю.
Здравствуйте! Мне нужен винолс рус.
Спасибо...
Изменено пользователем Cam76
И мне нужен wer_alex@tut.by заранее благодарю.
Коллеги, помогите дамосом под вольво ME9, мотор 2.5 турбо. Не могу найти адреса таблиц органичителей момента и форсунок.
В идеале нужно на ford kuga, но для анализа подойдет и дамос для ford focus st mk2, ford focus rs mk2, ford s-max, ford mondeo, volvo s40II/v50, volvo S80, volvo S60 с мотором 2.5турбо и блоком управления Bosch ME9.
Почта korkin@nm.ru
Изменено пользователем 2112tun
Здравствуйте поделитесь winols rus, буду очень благодарен sbs.63@mail.ru
Аналогично. Кто нить скрин выложите у кого эта функция работает.
пытался чистить реестр переустанавливать систему ставить на другой комп.
толку ноль.
Расжуйте кто может.В чем проблема может быть
Ау. никого нет штоли
Impot Damos&ASAP2.rar
Изменено пользователем Loki_7
Тут чел... мне предлагает Winols + дамосы и т.д. размар на 7 Гб..Хочет 500 долл. всё рабочее проверен..(БРАТЬ!!!)
