After flash P1187
I have a problem FOCUS. Problem after flahs NOFAP P1187.(I am not flash) Read and did everything but P1187 remains. IDS refuses to reflash. Have MPPS GALLETO XPROG,5 Focus 05r 1.6 TDCI 110Ps Bosch 0 281 012 487 7M51-12A650-UA 7EFA . HELP
Flash M58BW016xB.rar
https://www.auto-bk.ru/forum/topic/38404-after-flash-p1187/
Сongratulate, apparently at first mpps connected and he rubbed out everything?, problem not in flesh' and eproom, IDS and ability to govern configuration is needed. or search eproom(95160) from the same ecu and attach him on new. ecu in a bumper before a left front wheel.
Изменено пользователем megaw
https://www.auto-bk.ru/forum/topic/38404-after-flash-p1187/#findComment-393129
Can I manually corrected sinhronizacion dumps 95160 (no IDS)
https://www.auto-bk.ru/forum/topic/38404-after-flash-p1187/#findComment-393144
dump 95160 in attach,(it is necessary dump from the donor(other car)) to configure with a help IDS, or to send to diler
Eeprom 95c160.rar
https://www.auto-bk.ru/forum/topic/38404-after-flash-p1187/#findComment-393407
Thanks! megaw
https://www.auto-bk.ru/forum/topic/38404-after-flash-p1187/#findComment-393532
I'm looking for flash M58BW016xB DPF_off
https://www.auto-bk.ru/forum/topic/38404-after-flash-p1187/#findComment-393630
Fill out a profile, keep the forum rules :36_1_37:
Use the program ' volta ' (lays here at a forum) the truth a mask of mistakes too will injure or to pay for tuning.
https://www.auto-bk.ru/forum/topic/38404-after-flash-p1187/#findComment-393632
https://www.auto-bk.ru/forum/topic/38404-after-flash-p1187/#findComment-394065
Pass in PM. No FAP, no error P1187
ошибка двигателя всё равно вылезет на щитке, тока теперь диагностикой ее не увидишь, уже было такое.
https://www.auto-bk.ru/forum/topic/38404-after-flash-p1187/#findComment-394101
Человек тему не продолжил, значит все ок.
https://www.auto-bk.ru/forum/topic/38404-after-flash-p1187/#findComment-395310
ошибка двигателя всё равно вылезет на щитке.HELP!
https://www.auto-bk.ru/forum/topic/38404-after-flash-p1187/#findComment-395370
Вот и не всё
Ошибка лезет из eeprom править нужно её. доставать ECU, заливать прогером 95160(она там сверху стоит) от такого же блока и привязывать IDS.
ps а ты че по нашему сразу не написал? и профиль заполни однако!
https://www.auto-bk.ru/forum/topic/38404-after-flash-p1187/#findComment-395378
  • 11 месяцев спустя...
Happy!
After removing ecu ford focus 1.6 tdci and fap to eliminate "volta" will not start!
Even with the original map.
Any information?
Thank you all.
Изменено пользователем ezekiel
https://www.auto-bk.ru/forum/topic/38404-after-flash-p1187/#findComment-529006
