Прошивки Toyota
Кто-нибудь делал такого?
LC Prado 120 2005 2.7
ID CALIB DATA: 36059000
SW: 89663-60590
HW: 89661-60C10
Во флешере не заявлен, инфы ни где нет.
ММС-2 сможет записать?
Сток есть у кого?
Без проблем запишет :
03.05.2016 10:47:33 Message SELECTED DEVICE: CHIPSOFT J2534 ISO/CAN
03.05.2016 10:47:33 Message API VERSION: 04.04
03.05.2016 10:47:33 Message DLL VERSION: CHIPSOFT J2534 Library FW: 0.993 Oct 21 2015 12:36:42
03.05.2016 10:47:33 Message FIRMWARE VERSION: CHIPSOFT adapter v. 0.996 HW: FFFFFFFF SN: AD6E164CB584EE76
03.05.2016 10:47:33 Message SELECTED ECU: ECU/Toyota/Prado/3.0 V6/DENSO 32BH384K 76F0040GD 368kb K-LINE
03.05.2016 10:47:38 Message API VERSION: 04.04
03.05.2016 10:47:38 Message DLL VERSION: CHIPSOFT J2534 Library FW: 0.993 Oct 21 2015 12:36:42
03.05.2016 10:47:38 Message FIRMWARE VERSION: CHIPSOFT adapter v. 0.996 HW: FFFFFFFF SN: AD6E164CB584EE76
03.05.2016 10:47:38 Message INITIALIZATION
03.05.2016 10:47:39 Message READ ECU INFO:
03.05.2016 10:47:40 Message ID CALIB DATA: 36059000
03.05.2016 10:47:40 Message SW: 89663-60590
03.05.2016 10:47:40 Message HW: 89661-60C10
10.05.2016 17:46:58 Message WRITE FIRMWARE FILE NAME = C:\Documents and Settings\Admin\Рабочий стол\89663-60590.bin
10.05.2016 17:47:02 Message INITIALIZATION
10.05.2016 17:47:02 Message API VERSION: 04.04
10.05.2016 17:47:02 Message DLL VERSION: CHIPSOFT J2534 Library FW: 0.993 Oct 21 2015 12:36:42
10.05.2016 17:47:02 Message FIRMWARE VERSION: CHIPSOFT adapter v. 0.996 HW: FFFFFFFF SN: AD6E164CB584EE76
10.05.2016 17:47:37 Message AUTHENTICATION
10.05.2016 17:47:38 Message SW: 89663-60590-A
10.05.2016 17:47:38 Message CHECK PASSWORD
10.05.2016 17:47:56 Message MCU TYPE: 40
10.05.2016 17:47:56 Message ALGORITHM ID № 0x03
10.05.2016 17:47:56 Message PROGRAMMING SESSION START
10.05.2016 17:47:56 Message START ADDRESS: 0x000000
10.05.2016 17:47:56 Message FINISH ADDRESS: 0x07BFFF
10.05.2016 17:47:56 Message CHECK BLOCK № 01
10.05.2016 17:47:56 Message ERASE BLOCK № 01
10.05.2016 17:47:56 Message WRITE BLOCK № 01
10.05.2016 17:49:18 Message VERIFY BLOCK № 01
10.05.2016 17:50:59 Message CHECK BLOCK № 02
10.05.2016 17:50:59 Message ERASE BLOCK № 02
10.05.2016 17:51:00 Message WRITE BLOCK № 02
10.05.2016 18:00:11 Message VERIFY BLOCK № 02
10.05.2016 18:11:33 Message TOTAL WRITE BLOCK № 02
10.05.2016 18:11:33 Message FIRMWARE WRITE SUCCESSFULLY
Изменено пользователем al-31f
  • Ответов 684
  • Просмотры 329,9 тыс
Всем доброго коллеги
Ищу сток
Авто RAV4_2.0l_2013г_азиатский рынок-ближний восток, руль слева.
Идентификация
Калибровка: 342K2000 A0C01000
Файл калибровки: 89663-42K20 8966A-0C010
Аппаратный номер: ZSA4# 3ZRFE
Каталожный номер: 89661-42S00
CVN номер: EB252B18-2C411C65
VIN-JTMDDREV005001361
Можно и за разумные деньги :noflood:
Доброго вечера!
Может кто подскажет в каком направлении нужно двигаться: приехал Lexus GX460 на удаление системы вторичного воздуха.
В блоке висела ошибка по низкому давлению датчика вторичного воздуха P2432
Прислали файл, записал все штатно. Сняли два клапана вторичного воздуха и вырезали под них прокладки.
На тест драйве машина не едет. Так же как и с горящим чеком, есп, антизанос.
Контрольная диагностика проблем не выявила, ошибок нет.
Читал на соседнем форуме, что отключение косвенное и иногда требуется обманка. Соорудил резистор 5 ом 0,25 вт  в 1 и 5 контакт разъема клапана, но результатов не принесло. Кто сталкивался, как решать?
разъемы наместо  воткните в клапана
Пробовали с ними и без.
Надо прошивку смотреть наверное...хотя не правильно это.
К автору сего творчества Вам нам писать.
есть ли возможность отключить повышение оборотов при вкл кондиционера на 200крузере дизель?
Такие вопросы нужно непосредственно калибровщикам задавать.
Нужна серийка на Touota RAV4 2012 есть подозрение что кто-то наблудил в блоке.
Калибровка: 342M1000 A0C01000
Файл калибровки: 89663-42M10 8966A-0C010
Аппаратный номер: ZSA3# 3ZRFAE
Каталожный номер: 89661-42T90
CVN номер: 7DB37672-2C411C65
Удалось найти прошивку ? Просится такой же RAV4.
Ищется сток или тюн. Toyota Rav4_2.0 16V_2001г.в.
ECU: ECU/Toyota/Rav4/2.0 16V/DENSO 32B320K 76F0004 320kb K-LINE
ID CALIB DATA: 34208200
SW: 89663-42082
Коллеги удалось кому найти фалы для обновления CUW 89663-42083 или 89663-42084????
отвечу сам себе. Файл 89663-42083 обновления для CUW прилагаю
34208300-T01_CUW.rar
Изменено пользователем kerixi
Нет, к сожалению.
Доброго вечера!
Чем закончилось? Удалось победить?
Да, все сделал. Прошивка + обманки на датчики давления
У меня такой же просится. В ММС2 флешере не заявлен. Чем шили?
Если авто нет в списках, это не значит что его нельзя прошить)))
Выбираете любой кановый модуль тойота/лексус GEN1 и все.
Делал Алекса флешером.
Ишу сток на LX470
Калибровка: 36042100 56020000
Файл калибровки: 89663-60421 89665-60200
Каталожный номер: 89661-60A01
Ищу сток для Lexus GS 430 с мотором 4.3 бензин
89663-30592
можно не бесплатно
