Всем доброго вечера
Резко перестала работать UPA, версия 1.3, зеленый текстолит.
С софтом все в порядке, пробовал знакомого прогер - работает
Диагностика выдает следующее:
Сталкивался кто нибудь с таким?
Заранее спасибо
UPA-USB Device Programmer v13014
Licensed to: Xinbo Zhang*
System: Microsoft Windows XP Professional Service Pack 3 (build2600)
Detecting UUSP...Pease wailt!
Device Description: ELRASOFT UPA-USB3.0 Driver (1.1.0.00, 03/28/2012)
USB Driver Name: UPAUSB.sys, HS Mode
5V Tests. Close J1 and press a key to continue
Test1:  P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=0,00V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
Test Passed
Test2:  P1=8V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=6,94V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
P1(6,94V ) not in 7,70V - 8,30V
Test Failed
Test3:  P1=9V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=7,90V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
P1(7,90V ) not in 8,70V - 9,30V
Test Failed
Test4:  P1=10V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=8,67V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
P1(8,67V ) not in 9,70V - 10,30V
Test Failed
Test5:  P1=11V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=9,46V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
P1(9,46V ) not in 10,70V - 11,30V
Test Failed
Test6:  P1=12V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=10,43V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
P1(10,43V ) not in 11,70V - 12,30V
Test Failed
Test7:  P1=13V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=11,18V, P2=0,00V (L), P3=0,00V (L), P4=0,00V (L),P6=0,00V (L), P7=0,00V (L), P8=0,00V (L), P9=0,00V
P1(11,18V ) not in 12,70V - 13,30V
Test Failed
Test20: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=5V
Result: P1=0,00V, P2=3,72V (L), P3=0,00V (L), P4=0,00V (L),P6=3,69V (L), P7=0,00V (L), P8=0,00V (L), P9=4,91V
Test Passed
Test21: P1=0V, P2=L, P3=L, P4=L, P6=L, P7=L, P8=L, P9=5V
Result: P1=0,00V, P2=0,05V (L), P3=0,00V (L), P4=0,00V (L),P6=0,05V (L), P7=0,00V (L), P8=0,00V (L), P9=4,91V
Test Passed
Test22: P1=0V, P2=H, P3=H, P4=H, P6=H, P7=H, P8=H, P9=5V
Result: P1=0,00V, P2=4,85V (H), P3=4,85V (H), P4=4,87V (H),P6=4,82V (H), P7=4,83V (H), P8=4,83V (H), P9=4,91V
Test Passed
3.3V Tests. Open J1 and press a key to continue
Test40: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=3.3V
Result: P1=0,00V, P2=2,98V (H), P3=0,00V (H), P4=0,00V (H),P6=2,96V (H), P7=0,00V (H), P8=0,00V (H), P9=3,54V
Test Passed
Test41: P1=0V, P2=L, P3=L, P4=L, P6=L, P7=L, P8=L, P9=3.3V
Result: P1=0,00V, P2=0,03V (L), P3=0,00V (L), P4=0,00V (L),P6=0,03V (L), P7=0,00V (L), P8=0,00V (L), P9=3,54V
Test Passed
Test42: P1=0V, P2=H, P3=H, P4=H, P6=H, P7=H, P8=H, P9=3.3V
Result: P1=0,00V, P2=3,56V (H), P3=3,56V (H), P4=3,56V (H),P6=3,54V (H), P7=3,54V (H), P8=3,54V (H), P9=3,54V
Test Passed
Test60
9544961E2F4EABEA
Test Passed
6 Tests failed
Предохранитель в порядке?
было такое,глюк прошивки UPA  если оригинал обратитесь к Пенко
Пред в правом верхнем углу, похож на кренку, только двуногий?
Или еще есть на плате?
Есть схемка?
К сожалению не оригинал
Есть схемка?
да он самый с маркировкой N15. Часто про него забывают а проблема бывает в нем.
живой
Пока не чего не помогает, UPA избирательно не читает не еепром не моторолы.
В програме SN видит, пинтест работает нормально.
Заработала!
Спасибо
alex.ki
Помог разобраться!
Что было расскажи пожалуйста.
