How to repair the BMW electronic handbrake parking EMF control unit?
Hello everyone
BMW X5 X6 E70 E71 electronic hand brake EMF control unit module
We often encounter, EMF control unit, internal failure
This failure, we can successfully repair
First, let's look at the location and appearance of the EMF, as follows:
Shell number is this, as follows:
Open EMF is the case, as follows:
Open the PCB of the control unit as follows:
We need to do is:
1: Replace the motor
2: Check the motor behind the two wiring, to ensure good
3: Replace the blue relay
4:Check the other side of the motor gear (not the motor's own gear, please note), because it is colloid, long working wear, deformation, if the deformation is serious, need to replace the processing
Because my English is not good, there are many details can not be more clearly expressed, please understand that if you have a better maintenance methods, you can reply to this post below the discussion.
Здорово,китайский брат-ремонтник починил модуль электроручника,чем и поделился с аудиторией в подробном отчете с фото и описанием.Все бы так делали!Но...Смущают красные буквы внизу...
Thanks for the detailed report,but the debate is unlikely to succeed, because the Russian-speaking forum
Or is advertising your site ?
By the way, your English is good
Изменено пользователем dimaelectrik
thank you, friend
I am not advertising, just share an experience, can help to everyone
My English is not good, please understand
