Опубликовано 16 февраля, 20188 г. Здравствуйте,была утеря ключей,ключ записал,авто запускается,не могу привязать радиоканал.Процедуру привязки именно для jimny может кто подскажет,делал как на Vitara,через концевик вод.двери не получилось.
Опубликовано 16 февраля, 20188 г. 1) Confirm that the vehicle is the following conditions. • All doors are closed. • Ignition key is out of ignition switch. • Driver side door is unlocked. 2) Disconnect negative (-) cable from battery. 3) After 30 seconds, perform the following procedure within 60 seconds. a) Connect negative (-) cable to battery. b) Operate driver side door knob switch from lock to unlock. c) Push “LOCK” button on transmitter and confirm that are operated from lock to unlock. d) Push driver side door knob switch to lock position. e) Push “LOCK” button on transmitter twice and confirm that all doors are operated from unlock to lock. With this, code registration is completed.
