Прошивки AUDI
  • Ответов 2,2 тыс
  • Просмотры 660,1 тыс
год авто ? если до 2007 примерно там там флешка простая нужна панелька !
можно паспорт в диагнозе сюда выложить
VIN: WAUZZZ4E37N005582 License Plate:
Mileage: 132760km-82493mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 11 31 15 16 17 19 1D 1E 25 28 34 36
37 38 42 46 47 4F 52 53 55 56 57 61 62 65 66 69 72 76 77
VIN: WAUZZZ4E37N005582 Mileage: 132760km/82493miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1D-Driver Ident. -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
28-HVAC, Rear -- Status: Malfunction 0010
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
66-Seat, Rear -- Status: Cannot be reached 1100
69-Trailer -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E0 910 552 HW: 4E0 907 552
Component: 5.2L V10/4V FSI Є0060
Revision: 5AH11--- Serial number: AUX3Z0F6399963
Coding: 01060003190F0160
Shop #: WSC 05460 995 89693
VCID: DFCDC5FE0E9D11E64D9-808A
6 Faults Found:
008212 - Intake Manifold Flap Position Sensor (Bank 1)
P2014 - 002 - Electrical Malfunction
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.22
Time: 00:06:21
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 68.0°C
Temperature: 30.0°C
Absolute Pres.: 980.0 mbar
Voltage: 12.446 V
000275 - Intake Air Temp. Sensor (G42)
P0113 - 002 - Signal too High - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.22
Time: 00:00:14
Freeze Frame:
RPM: 1067 /min
Load: 19.2 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: -40.0°C
Voltage: 11.557 V
000258 - Mass Air Flow Sensor (G70)
P0102 - 002 - Signal too Low - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 132768 km
Time Indication: 0
Freeze Frame:
RPM: 1237 /min
Load: 24.3 %
Speed: 0.0 km/h
Temperature: 90.0°C
Voltage: 11.811 V
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.22
Time: 00:00:37
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 68.0°C
Temperature: 30.0°C
Voltage: 12.446 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.22
Time: 00:00:37
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 68.0°C
Temperature: 30.0°C
Voltage: 12.446 V
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 K HW: 09E 927 156 B
Component: AG6 09E 5,2 FSI RdW 0020
Revision: --H01--- Serial number: 0089229
Coding: 0000001
Shop #: WSC 02313 785 00200
VCID: 2B55E12E8AA53D46111-807E
1 Fault Found:
006231 - Load Signal
P1857 - 001 - Error Message from ECU - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.22
Time: 00:00:19
Freeze Frame:
RPM: 800 /min
RPM: 768 /min
RPM: 0 /min
(no units): 30.0
(no units): 36.0
Temperature: 47.0°C
T.B. Angle: 0.0°
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 D HW: 4E0 614 517 AB
Component: ESP 5.7 allrad H46 0500
Coding: 0001627
Shop #: WSC 05460 000 00000
VCID: 24470A12E77BF23ED0B-8071
2 Faults Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 K
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0F6399963
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: D8BFEEE26BB3E6DE0C3-808D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
No fault code found.
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 731 G HW: 4E0 035 729 A
Component: Interfacebox H43 2830
Revision: 00000000 Serial number: 300GU067569816
Coding: 0000012
VCID: 25411716EC410B36C75-8070
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH03 0040
Subsystem 2 - Serial number: 00000000015198
Subsystem 3 - Serial number: 0113.07.060000000100010211я
Subsystem 4 - Serial number: 010211я
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000102428
Coding: 0041081
VCID: 1C3732F2DF0BCAFE68B-8049
4 Faults Found:
00819 - High Pressure Sensor (G65)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 191
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.21
Time: 13:12:05
02095 - Component Protection Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 191
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.22
Time: 00:00:13
Freeze Frame:
Bin. Bits: 00011111
00066 - Rear Right Footwell Heater (Z43)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 191
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.22
Time: 00:00:52
Freeze Frame:
Voltage: 12.90 V
01206 - Signal for Duration of Ignition Off Time
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 191
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.22
Time: 00:00:52
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H15 0230
Coding: 0133121
VCID: 3663C05A41E770AE7EF-8063
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000035
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00141886
Shop #: WSC 02313
5 Faults Found:
00908 - Control Module for Wiper Motor
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 30
Reset counter: 192
Mileage: 0 km
Time Indication: 0
01494 - Bulb for Parking Lamps; Left (M1)
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.22
Time: 00:00:36
01498 - Bulb for Parking Lamps; Right (M3)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.22
Time: 00:00:37
01496 - Bulb for Fog-Lamps; Left (L22)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.22
Time: 00:00:38
01500 - Bulb for Fog-Lamps; Right (L23)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.22
Time: 00:00:38
Address 11: Engine II Labels: Redir Fail!
4 Faults Found:
P1653 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.22
Time: 00:05:24
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 68.0°C
Temperature: 30.0°C
Voltage: 12.319 V
008199 - Intake Manifold Flap; Bank 2
P2007 - 008 - Stuck Closed - Intermittent
Freeze Frame:
Fault Status: 00111000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.22
Time: 00:05:27
Freeze Frame:
RPM: 647 /min
Load: 16.1 %
Speed: 0.0 km/h
Temperature: 74.0°C
Temperature: 28.0°C
Voltage: 14.097 V
008197 - Intake Manifold Flap; Bank 2
P2005 - 002 - Stuck Open - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.22
Time: 00:05:29
Freeze Frame:
RPM: 646 /min
Load: 16.1 %
Speed: 0.0 km/h
Temperature: 74.0°C
Temperature: 28.0°C
Voltage: 13.970 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 D HW: 4E0 959 655 H
Component: Airbag 9.41 H13 3710
Revision: 91H13371 Serial number: 0037P000P6K0
Coding: 0431707
VCID: 275D1D1E964D1926F59-8072
Subsystem 1 - Serial number: 63328RB401641D39F
Subsystem 2 - Serial number: 63428RB401641D65F
Subsystem 3 - Serial number: 63528RB401641D95J
Subsystem 4 - Serial number: 63628RB401641DBFW
Subsystem 5 - Serial number: 63729RB40079030AC
Subsystem 6 - Serial number: 63829RB4016B796BZ
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksдulenmodul H14 0040
Coding: 0012141
VCID: E5C1D7162CC14B36875-80B0
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 901 D HW: 4E0 920 901 D
Component: KOMBIINSTR. VDO H82 0520
Revision: D03 Serial number: AUDID3F6000148
Coding: 0048103
Shop #: WSC 02680 995 194823
VCID: 21490306F869E716BBD-8074
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H11 0090
Revision: 11 Serial number: 20003066238091
Coding: FDFFFFFD2B3504
Shop #: WSC 00012 123 12345
1 Fault Found:
00462 - Control Module for Seat Memory; Rear (J522)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.22
Time: 00:00:03
Address 1D: Driver Ident. Labels: 4E0-910-218.lbl
Part No SW: 4E0 910 218 A HW: 4E1 905 218 B
Component: FPI_1 H01 0020
Revision: 01000102 Serial number: 26072006192631
Shop #: WSC 00000 000 00000
VCID: 1F4D05FECE1DD1E68D9-804A
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBF8162089
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 C
Component: KLIMA-STG. FOND 017 0230
Revision: 00000019 Serial number: 00000000043879
Coding: 0000000
VCID: E1C9C30638E927167BD-80B4
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
VCID: 2A5BE42A855F244EEA7-807F
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4063342
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 Q HW: 4E0 919 887 D
Component: MNS ECE H48 0850
Revision: 00000000 Serial number: 364GT067580380
Shop #: WSC 05460 995 65361
VCID: 3B75D16E7AC5ADC6811-806E
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H05 0090
Serial number: 00000620000015
Coding: 0003284
VCID: 1D313FF6C411C3F69F5-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Tьrsteuer.FS BRM003 0100
Coding: 0028461
VCID: 204F0602F363EE1EB43-8075
5 Faults Found:
01308 - Control Module for Roof Electronics (J528)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 192
Mileage: 0 km
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 192
Mileage: 0 km
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
00461 - Control Module for Seat Memory; Passenger (J521)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 192
Mileage: 0 km
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
02111 - Motor for Window Regulator
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 192
Mileage: 132768 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 192
Mileage: 132768 km
Time Indication: 0
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H07 0010
Revision: 00100007 Serial number: W040607240188
Coding: 0004712
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Address 47: Sound System Labels: None
Part No SW: 4E0 910 466 A HW: 4E0 035 466
Component: BO_D3 H06 0170
Revision: 12S00002 Serial number: 02106060003677
Coding: 0000016
Subsystem 1 - Part No: 4E0 910 465 A
Component: BO_D3_SLAVE H31 0100
Subsystem 2 - Serial number: 01107060001919
Subsystem 3 - Serial number: 0211.07.060000000100030011я
Subsystem 4 - Serial number: 030011я
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 B
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000001058
Coding: 0010101
VCID: 1E3338FAC917D8EE86F-804B
2 Faults Found:
02269 - No Acknowledgment from Limit-Shut Off at Display Unit Retraction
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 152
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.22
Time: 00:00:00
02270 - No Acknowledgment from Limit-Shut Off at Display Unit Deployment
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 152
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.22
Time: 00:16:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Tьrsteuer.BF BRM003 0100
Coding: 0028461
5 Faults Found:
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 192
Mileage: 132768 km
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 192
Mileage: 0 km
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 192
Mileage: 0 km
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 192
Mileage: 132768 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 192
Mileage: 132768 km
Time Indication: 0
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000731
Shop #: WSC 08660 995 103799
2 Faults Found:
00576 - Terminal 15
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 192
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Voltage: 12.21 V
Count: 41
02432 - Supply Voltage for Left Parking Brake Motor (V282)
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11111100
Fault Priority: 1
Fault Frequency: 2
Reset counter: 152
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.22
Time: 00:00:12
Freeze Frame:
Voltage: 12.42 V
Count: 86
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000018
VCID: 29591B2680592F56E3D-807C
Subsystem 1 - Part No: NOSUBSYSTEM
Component: AFS-Modul links
Subsystem 2 - Part No: NOSUBSYSTEM
Component: AFS-Modul rechts
1 Fault Found:
02071 - Local Databus
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 152
Mileage: 132776 km
Time Indication: 0
Date: 2014.04.22
Time: 00:09:28
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 M HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0570
Revision: 00000000 Serial number: 396G%067543596
Coding: 0000001
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 251
Reset counter: 192
Mileage: 122831 km
Time Indication: 0
Date: 2013.07.05
Time: 15:44:18
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 A HW: 4E0 919 148
Component: R0078 TVhybridTuner 0280
Revision: R0H05000 Serial number: 76300700458101
Coding: 0000005
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000013893
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 2607200420
Coding: 344530393135313035412056413032363037323030343230
Shop #: WSC 00000 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Tьrsteuer.HL BRM003 0100
Coding: 0028461
5 Faults Found:
02126 - Central Locking Button; Exterior Door Handle
008 - Implausible Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 152
Mileage: 132768 km
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 192
Mileage: 132768 km
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 192
Mileage: 0 km
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 192
Mileage: 132768 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 192
Mileage: 132768 km
Time Indication: 0
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000900046836
Coding: 0212428
1 Fault Found:
01521 - Sensor for Tire Pressure
Freeze Frame:
Fault Priority: 3
Fault Frequency: 12
Reset counter: 0
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.22
Time: 00:08:59
Freeze Frame:
(no units): 0.0
Temperature: 25.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 66: Seat, Rear
Cannot be reached
Address 69: Trailer Labels: 4E0-910-383.lbl
Part No SW: 4E0 910 383 C HW: 4E0 907 383 C
Component: ANHAENGERELEKTR 004 0060
Coding: 0001001
5 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 192
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.22
Time: 02:48:00
02564 - Trailer; Left Tail Lamps (M60)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 152
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.22
Time: 00:00:00
02566 - Trailer; Left Turn Signals (M62)
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 152
Mileage: 0 km
Time Indication: 0
Date: 2014.04.22
Time: 00:00:00
02565 - Trailer; Right Turn Signals (M63)
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 152
Mileage: 0 km
Time Indication: 0
Date: 2014.04.22
Time: 00:00:00
02562 - Trailer; Brake Lamps
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 152
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.22
Time: 00:00:00
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Tьrsteuer.HR BRM003 0100
Coding: 0028461
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08720619401503
Coding: 0301008
VCID: 2345090EE275F506A91-8076
1 Fault Found:
02069 - Front Parking Aid Sensors
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 153
Mileage: 132768 km
Time Indication: 0
Date: 2014.04.22
Time: 00:12:03
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 F HW: 4E0 862 333 C
Component: TELEFONMODUL EU 0770
Revision: 00000008 Serial number: T2AUDX0806JNMT
Coding: 0000004
VCID: 224B0C0AFD6FFC0EA27-8077
End ---------------------------------------------------------------------
лог старый,снимал как толко приехала битая,тепер ошибок нет,пару осталось совсем не актуалных
Помогите нужна прошивка стоковая А4 2002г амв 170л механика 8Е0909518G !?
Навернулся Вариатор поставил механику,или может в моей прошивке кодировку можно поменять?!или просто залить сток с механики?!
Спасибо большое,а в чем у них разница?нужно на блоке глянуть какая у меня?! у нас в Саратове с прошивкой полная .опа нашел в одном месте где зальют прошивку которую принесу Я сам за 10000р жесть решил сам попробовать,вроде с с январем получалось)
Audi a4 b6 1.8TQ АКПП 170ЛС AMB (Американка)
нужна прошивка Евро 2 без 2ЛЗ отключить в прошивке контроль герметичности вентиляции бака и СВВ
8E0909518AF 0003.Bin
Изменено пользователем mr_Diman
Фишки со всего что отключено снять.
За паролем на архив в личку
WinOLS(Audi_A4_1,8_(nocat_nosap_noevap))-366883.rar
Вы сюда деньги зарабатывать пришли??Все ваши сообщения,связаны с вашими коммерческими предложениями.Или не коммерческими?Если есть желание помочь или продать что то человеку,ведь можно самому в личку написать,зачем эта показуха,типа вот файл,а за паролем в личку???
Уважаемый, а кто сказал что пароль платный.
Человек публично попросил помощи, я публично ему помог. Какие проблемы то.
Помогаю людям и одновременно себя показываю. Не все же за даром делается :))))))
Изменено пользователем AFS-TUNING
подскажите новичку,имеется китайский шнурок галето и обычный для ваг кома 409.1, прога чиплодырь, каким лучше шнурком слить прошивку? и какие могут возникнуть проблемы. блок ме 7.5 ,если буду сливать то на столе и согласно схемы взятой с нета.заранее спасибо
и еще вопросик,к кому обратится по поводу тюненой прошивки и какая цена услуг?
У тебя все есть. Проблемы могут возникнуть только с руками.
руки из нужного места,просто первый раз,очкую. Так а каким проводом лучше?
Любым из двух вариантов. Лучше в принудительном буте.
это когда через резистор 10Ком ногу флеша замыкаем на землю?
подскажите ребят прайс на работы,можно и в личку
подскажите как выложить сюда прошивку
