auto diag
Информация о auto diag
    opel
Достижения auto diag
  1. auto diag
    tundra 2007
    Hello all Auto-Bk members Happy new year I'm back to you with new problem . I have tundra V8 year 2007 with sommes faults codes P2441 P2443 P2445 when i use diag to erase it , i can drive for around 150KM befor seen chek engine ligth again i need solution please
  2. Hello dear i try all other ECU but here's my sterring lock ECU did you have pin data ? http://www.ebay.com/itm/10-11-12-13-Lexus-RX-RX350-Power-Steering-Computer-Module-OEM-89650-0E010-/281120739304 Tsobgni Zapfack
  3. thanks a lot dear i'm working on it . i will make you know Tsobgni Zapfack
  4. thanks for your epply I discover the power manegement module last day / but I'm trying to get the rear pin data . if you have oppotunity kindly find it out for me
  5. auto diag
    lexus RX350
    Hello all members this is other probrem with RX 350 All keys open and close doors ; but no sound in the car , on immo light and reflet light on the dash . No signal or light from start - stop butom. Car can not start I bypaas fuse 15A P/Point under the dash and use toyota intelligent tester . This is fault code : B2785 and U1133 explanation no communication with PMN module any help to solve this problem ; where can i locate this module ? Thanks and regards JOE
  6. Hello all auto-bk members this is other probrem with RX 350 All keys open and close doors ; but no sound in the car , on immo light and reflet light on the dash . No signal or light from start - stop butom. Car can not start I bypaas fuse 15A P/Point under the dash and use toyota intelligent tester . This is fault code : B2785 and U1133 explanation no communication with PMN module any help to solve this problem ; where can i locate this module ? Thanks and regards JOE
  7. Hello dear auto-bk members ; Please kindly help to program a new smart key ; all keys are lost and a smart box damage ; i find use one . I nedd your help to virginise ID code box and smart box dump . thanks and regards Joe
  8. for adding new key you can use T300 ; but if you have not key it dificult and you can use professional diag . Toyoya inteligent tester can't program key without old one . Joe
  9. auto diag
    toyota incode
    hello dear could you kindly find me toyota incode ? this is outcode : 10972138 thanks and regard Joe
