Alex P
Информация о Alex P
  • День рождения 12.07.1977
    21144
Контакты
  • Сайт
    http://
  • ICQ
    Омск
289 просмотров профиля
Достижения Alex P
  1. А с A317DB04 пробовал?
  2. Спасибо! А то по диагностике пробую щелкает, а где не пойму.
  3. Где установлено реле блокировки стартера на Самаре с М73?
  4. Есть ли поддержка доп реле стартера в прошивках Самар 317
  5. Access protection The I-Flash module has one level of access protection (access to data both in Reading and Writing): if bit ACCP of FNVAPR0 is programmed at 0, the I-Flash module becomes access protected: data in the I-Flash module can be read only if the current execution is from the IFlash module itself. Protection can be permanently disabled by programming bit PDS0 of FNVAPR1H, in order to analyze rejects. Protection can be permanently enabled again by programming bit PEN0 of FNVAPR1L. The action to disable and enable again Access Protections in a permanent way can be executed a maximum of 16 times. Trying to write into the access protected Flash from internal RAM or external memories will be unsuccessful. Trying to read into the access protected Flash from internal RAM or external memories will output a dummy data (software trap 0x009Bh).
