cubica
Весь контент cubica
  1. Hello, friend, did you find this file, I have need too :( cuby
  2. I have found this (regarding carprog adapter) true or false..can somebody confirm?? Hi , someone can confirm this . On the aux 26pin connector : 1 – Reserved for Debug RX protocol(Tx from carprog) 2 – Reserved for Debug TX protocol(Rx from carprog) We need the GND connected also ? Multi-pin connector 2 12 – Voltage supply, negative, terminal 31 15 – Voltage supply, positive, terminal 30 So to resume in the cable there is just Rx Tx lines and we need to supply the 12V to the radio . Someone used the carprog with this radio and can confirm the cable schema ? Thanks cuby
  3. here is pinout of RNS510 old and new version... cuby
  4. 30 is +12V?? I preasume.. also...my adapter for RNS510 has 5 wires (black is missed in the list) :( cuby
  5. cubica
    CITROEN C5 (2008)
    Hello friends, can someboddy calculate a new one km for this model. C5 2008 year BSI ST95128 Dash S93c76 Here is orig dumps, I need 110000 km. Thx in advance, regards, cubica Citroen C5 bsi and dash 2008y.rar
  6. cubica
    Citroen C5 2008 km change
    Dear friends, can someboddy calculate a newone km from my dumps?? I need 109.000 km. This is C5 2008y dash S93c76 and BSI 95128. thx in advance, sposibo, cubica Citroen C5 bsi and dash 2008y.rar
      • 1
      • Downvote
  7. esli u kogo etii kalk, ja interesen togze. cuby
  8. Thanks friend, but there is an 93C86 :( thx, rgds, cubica
  9. Friends, is anybody have dump for this model 3B0 920805G 110.080.051/006?? year 2001. I have tried ''A'' ''E'', 802, 806, B5 restailing but w/o success :( Board not working, rpm also... The problem was that dash came to me w/o eeprom, I have found into odobase that is 93C86 but now I need the correct dump. Is any know, this board comp in middle, is need to work on the bench??? The car is not here, so I am working on the bench. thanks in advance, sposibo. cubica :)
  10. 1.Lift needles below the start possition ONLY to mark the start possition... Lift them back after!!! This is only so you can put them back in same possition!. 2.Use some plastic or a old credit card!. 3.Put the plastic credit card under the needle so you dont make any scratches 4. Like you see you dont need any special tools to do this.... 5.The axle & feder on the rear side!. 6. Lock the axle and dont damage the feder!. 7.Dont forget the plastic under the needle!. 8.Lock the axle it must be done 100 before you try to remove the needle otherwice you will damage the feder!. 9. Place the needle 12 oclock and lock the axle 100 then pop the needle of with the screwdriver Dont bend with it turn it just like you use to screw whit it!. 10.Removed!. 11.Removed!. 12.All needles removed in 2 minutes!!. 13.Like you see the feder is okey.... 14.To remove the economy needle you dont need to lock the axle... Use the plastic so you dont do any scratches!. 15.Economy needle removed!. rgds, cubica :) Skidanje kazaljki.rar
  11. ELMOS 10417A - Passat B4, Transporter T4 (1994-1997) dashboard driver If dashboard is dead, pointers not work or some others defects persist - 100% you must exchange this IC. rgds, cubica b4 orig.rar
