540 -
Победитель дней
7
Сообщения, опубликованные motorstate
Добавлено VAG Flashdaten / Dataflash - 06.2023
- 1
Добавлена
активация ODIS-E 16.1 - $29
Все руководства собраны на Google Disk.
Добавлено
Nissan Pathfinder Truck 1989-1995
Nissan 1f Series Specifications
Nissan 1F1 1F2 Forklift Trucks Platinum 2 Operator's Manuals
Nissan Atlas F24 (1.15-2t) Catalog
Nissan Atlas F24 Truck Owner's Manual
Nissan Cabstar Ascendant A18 13TJ Operator Manual
Nissan CabStar bd30 Technical Data Sheet
Nissan Cabstar Euro 4 Parts Manual
Nissan Cabstar F24 Owner's Maintenance Manual
Nissan Cabstar NT400 Technical Specifications
Nissan Cabstar RHD Electrical Unit
Nissan Cabstar Schematic Diagrams
Nissan Cabstar Service Manual - Engine Control System Manual
Nissan D01 D02 Forklift Trucks Operator's Manual
Nissan Forklift 1F-Series Diesel 2-3,5 ton Service Guide
Nissan Forklift F04 Series Specifications
Nissan Forklift Model 1F2UP Parts Catalog
Nissan Forklift Operators Daily Checklist Manual
Nissan Forklift Platinum II Operator's Manua for 1F1_1F2
Nissan Forklift Platinum II Series 3,000-8,000 lb Capacities Specifications
Nissan Forklift Platinum SS G04 Series Specifications
Nissan Forklift Platinum TX Series 3,000_3,500_4,000 lb Capacities Specifications
NISSAN Forklift Truck Fault Codes List DTC
Nissan Frontier Pick-up Truck Owner's Manual
Nissan K21 K25 Forklift Truck Engines Service Manual
Nissan KA24DE Truck Engine Electric Wiring Diagrams
Nissan KA24DE Truck Engine Electrical Service Manual
Nissan KA24DE ZD30DD Truck Engines Fuel System Service Manual
Nissan KA24DE ZD30DD Truck Engines Maintenance Manual
Nissan NP300 Pick-up Truck Owner's Manual
Nissan NV200 Compact Cargo Van Owner's Manual
Nissan UD Trucks Quon 8-Litre CW 25 360 Standard Specification
Nissan UD Trucks Doby builders book
Nissan UD Trucks Quon GKB_CWB_GWB Body Installation Manual
Nissan UD Trucks UD2600LP Standard Specification
Nissan UD Trucks (2011-2013) Owners Manual
Nissan UD Trucks Condor 2019 MK_LK_PK_PW_MF_LF_PF Specifications
Nissan UD Trucks Condor MK 11 280 Technical Specifications
Nissan UD Trucks Condor PK 16 250 Specifications
Nissan UD Trucks Engine RE, RF, & RG series RE10, RF8 AND RG8 Service Repair Manual
Nissan UD Trucks GWE370 - Gearbox, Mechanical, Component Description
Nissan UD Trucks GWE370 - Power Steering Pump
Nissan UD Trucks Kuzer Specifications
Nissan UD Trucks Quester GWE440 Technical Specifications
Nissan UD Trucks Quester Owners Manual
Nissan UD Trucks QUESTER Series Owner's Manual
Nissan UD Trucks Quester Technical Specifications
Nissan UD Trucks Quon 6X4 CW33 370 Standard Specifications
Nissan UD Trucks Quon Specifications
Nissan UD Trucks Quoun Cargo Specifications
Nissan UD Trucks Quoun Dump_Mixer Specifications
Nissan UD Trucks Quoun Tractor Specifications
Nissan UD Trucks UD1400_UD1800CS_UD1800HD_MKA371_UD2000_MKB371_UD2300_LKC371_UD2600_PKA371_UD3300_PKC371_PKC371 SWEEPER Body Builder's Book
Nissan UD Trucks UD1800HD_MKA370, UD2000_MKB370, UD2300_LKC370, UD2600_PKA370, UD3300_PKC370 Body Builder's Manual- 1
Добавлена версия Case New Holland Electronic Service Tools (CNH EST) 9.8 Engineering
3 часа назад, roamka69 сказал:
Новое не появилось?
Да, от этого месяца. Ссылка та же.
10.10.2022 в 09:35, motorstate сказал:
Добавлено VAG DataFlash - FlashDaten калибровки ODIS от 09.2022
Вышла новая версия 05.2023
- 1
8 часов назад, blagagro сказал:
Здравствуйте!
Подскажите, а есть возможность выложить на другой ресурс? Или может быть на какой-то торрент сервис?Здравствуйте.
Да, во тторрент магнет ссылка
magnet:?xt=urn:btih:5DC25BE9557721FC860A73A17D0E698042184A4E&tr=http%3A%2F%2Fbt3.t-ru.org%2Fann%3Fmagnet&dn=Xentry%20OpenShell%2003.2023%20XUS%20HHT%20DAS%20WIS%20EPC%20STARFINDER%20VEDIAMO%20MONACO%20(Acronis)%20%5B03.2023%5D
- 1
Добавлено Xentry OpenShell 03.2023 HHT DAS WIS EPC STARFINDER VEDIAMO MONACO (Acronis)
Добавлено
Allison DOC + TCM 2022 (with keygen) - $975 -
2 часа назад, Болтовиков сказал:
А что означает - оно выиграло работу?
Так то, есть два интерфейса, постарше и поновее. Постарше зовётся ECI, помладше зовётся VCI. Оба работают одинаково как с 14 так и с 16-ой версиями изи, правда, по отзывам людей работавших с ними обоими, ECI для старых траков постабильнее, но ECI не работает с UDT.
Кстати, активацией UDT не обладаете?Это исходя из опыта настроек 14-й версии.
8 часов назад, BadRobot сказал:
Перевести можно?
Это имя прибора в диспетчере устройств.
Добавлено
Volvo Premium Tech Tool PTT 2.8.175 + APCI 2023 + DevTool - $299 -
Добавлено
Toyota ISTA J29 4.37 - $50Обновлена цена на ToyoLex 3 и для кейгена на него.
ToyoLex 3 (with keygen) - $395
ToyoLex 3 - $75 -
Добавлено
Iveco EASY 14 - $99
Работает для старых VCI, которые имеют имя в диспетчере устройств - kECI. Если у вас есть имя DMD-ECI - оно выиграло работу. -
Добавлено VAG ODIS - Flashdaten / Dataflash 02.2023
Добавлено VAG DPF 3.26.11
Добавлено
JLR CCF Tools 4.9 — $259
Для Pathfinder, SDD с 2017 по 2023 год.
Функции:- Чтение VBF, поиск по ключевому слову
- Параметры установлены и сохранены
- Данные EEPROM
- Сравнить файлы VBF
- Самодельные скрипты для кодирования по принципу «нажми и играй»
- Загрузка и экспорт VBF по VIN
Добавлено ODIS 16.0 - PоstSetup 160000.402.40 - Win 10/11 x64
22 минуты назад, igor сказал:
с опен портом2 будет работать?
Должно работать.
2 часа назад, ХАО сказал:
Данный менеджер драйвера, как работает с Mitsubishi MUT-III FUSO? Разработчик сказал что нет.
Он работает только с легковыми.
Добавлено
MAN Mantis EPC 698 01.2023 - $199 -
j2534 Менеджер драйверов PassThru для Mitsubishi MUT-III
Добавлено Ford IDS 129.01 + FJDS 129.01
Удаленная установка - Cummins Insite, Calterm, QuickServe, Incal, Inpower
в Программы для диагностики
Добавлено
Cummins Calterm 5.11 + MetaFiles - $155
Cummins Insite Cal Fix v2 - $55
Cummins CalDL - $649
Инструмент для загрузки incal-файлов. он работает независимо от Insite. Если есть проблема в несоответствии даты и программы Insite, необходимо установить Fix v2
Cummins InPower Pro 14 (with keygen) - $1070
Cummins Insite 8.8.1, Calterm 5.8, Etool Holset, Jammer, Nemesis (с обновлениями на 1 год) - $650
Fix v3 for Cummins Incal - $85
Cummins Incal to Cal converter - $25
Программное обеспечение для преобразования любой калибровки Incal в формат Calterm. Хорошо для практики использования Calterm.
Cummins InCal iMod Manager - $45
Утилита для модификации файлов калибровки для устаревших INCAL! Вы можете изменить дату истечения срока действия для каждого файла калибровки. iNCAL M0d сообщит, если есть проблема с вашими файлами или неправильный пароль для редактирования. iNCAL M0d полностью совместим с файлами Insite 8 INCAL.
Cummins PowerSpec 9.1 - $315
Cummins Technician Training - $135
Что внутри
Cummins Heavy Duty Engines + Midrange Trainings - $199
Что внутри
Cummins CM2250 DPF NOX Delete + Video - $99
Позиции более не активны
Cummins Calterm 5.7 + MetaFiles (with keygen)
Cummins PowerSpec 6.0 2015
