sky59 Опубликовано 15 мая, 2010 Опубликовано 15 мая, 2010 Hi friends, I could not find any picture of PCB of any airbag computer. So I attach one. I am going to repair it because it exploded already airbag /seat close to driver/ Another picture shows places where programmer can be connected. I found these by watching PCB routes and measuring resistances. It seems that +5V for programmer has got 1Ohm resistance in series so it can only be used to inform programmer about +5V ? Can anybody please confirm that connector is correctly identified? /BKGD, GND, VFP, +5, RESET/ Please, if anybody knows what should I delete in EEPROM can write it over here? I mean space in EEPROM from 0x??? to 0x??? must be filled with FF. Thank you for the help! I hope my photos will be usefull!
o717ka Опубликовано 15 мая, 2010 Опубликовано 15 мая, 2010 hi, look this 2M5T-14B056-AD.rarПолучение информации...
sky59 Опубликовано 16 мая, 2010 Автор Опубликовано 16 мая, 2010 В 15.05.2010 в 19:43, o717ka сказал: hi, look this 2M5T-14B056-AD.rarПолучение информации... Thank you, but I am not able to connect directly on microprocessor pins...... Am I too old? :-) for this I took macrophoto of PCB to find connector where also manufacturer connects an dit seems I have found it. Tomorrow I am going to read EEPROM with programmer so I will test it but I wanted to be sure.......
sky59 Опубликовано 16 мая, 2010 Автор Опубликовано 16 мая, 2010 В 16.05.2010 в 06:28, o717ka сказал: good luck in a meantime a managed to connect with thin wires to the "connector", I did not add solder I only heat-up from one side PCB and from front I put wires in the vias... tomorrow I take it to work on profi programmer.... can anybody confirm what addresses I should fill up with FF?
sky59 Опубликовано 18 мая, 2010 Автор Опубликовано 18 мая, 2010 В 16.05.2010 в 14:04, o717ka сказал: compare its with my archives I can not read EEPROM with professional programmer! Is microcontroler secured ? What programmer must I use?
sky59 Опубликовано 18 мая, 2010 Автор Опубликовано 18 мая, 2010 В 18.05.2010 в 12:46, o717ka сказал: what is your programmer? I do not remember the name but it is professional that we use in company, so it does only what is allowed by motorola is it normally BDM mode disabled? it is standard 2M5T-14B056-DD
o717ka Опубликовано 18 мая, 2010 Опубликовано 18 мая, 2010 UPA-USB Serial Programmer supports Motorola MC68HC912D60 (mask 1L28M) elrasoft.com
sky59 Опубликовано 18 мая, 2010 Автор Опубликовано 18 мая, 2010 (изменено) В 18.05.2010 в 16:00, o717ka сказал: UPA-USB Serial Programmer supports Motorola MC68HC912D60 (mask 1L28M) elrasoft.com in a meantime I studied some application notes and realized that there IS possibility to read eeprom if processor is protected there are some hardware BDM commands and through these some registers can be written, BDM on chip memory enabled and BDM started..... then we can do what we want are you sure UPA-USB is doing this to overcome stupid motorola protection? or do you know such programmer? because it seems my processor is protected..... see AN and look for hardware commands... :-) AN2104.pdfПолучение информации... Изменено 18 мая, 2010 пользователем sky59
sky59 Опубликовано 19 мая, 2010 Автор Опубликовано 19 мая, 2010 В 18.05.2010 в 19:23, o717ka сказал: works with this processor Finally I used Beeprog programmer from www.elnec.sk Freescale programmer failed..... :-) I attach eeprom, could someone helo to clean it from crash? thank you spasiba /I used to learn russian langauge for 10 yers but I can not write azbuka over here/ crashed.rarПолучение информации...
sky59 Опубликовано 22 мая, 2010 Автор Опубликовано 22 мая, 2010 В 20.05.2010 в 11:46, o717ka сказал: 2M5T-14B056-DD clear.rar пробуй Works, thanx see attached video ABG___focusOK.rarПолучение информации...
