o717ka Опубликовано 23 января, 2011 Поделиться Опубликовано 23 января, 2011 скачать Reset MP9 ResetMP9 is intended to reset the Long-Term Memory of the MP9 ECU, which is required when the MP9 ECU has either trouble codes 530 or 533, which cannot be cleared through the normal procedures. Instructions Make sure you have this problem! And ONLY ever use it on an MP9 ECU. This should be checked using the ResetMP9 utility or VAG-COM. Make sure you can speak to the MP9 with VAG-COM. Then close VAG-COM (completely) and run the ResetMP9 utility. Ссылка на комментарий Поделиться на другие сайты Поделиться
