Смотри инструкцию по эксплуатации! разжевывать тут никто тебе не станет :2126126958458bce9a447b0:
P.A. Soft BMW Scanner 1.3.6 - 1.4.0 тебе поможет изменить пробег по OBDII
Щитки приборов IKE:
BMWTNR____HW_SW_EEPROM-IDNR
3.413.124 04 07 M35080 - 2
3.413.132 04 07 M35080 - 2
3.414.370 05 08 M35080 - 2
6.901.921 05 15 93S66 - E46
6.901 922 05 15 93S66 - E46
6.901.923 05 15 93S66 - E46
6.902.362 07 16 93S66 - E46
6.902.362 09 16 93S66 - E46
6.902.363 07 16 93S66 - E46
6.902.374 07 16 93S66 - E46
6.902.375 09 16 93S66 - E46
6.903.748 08 12 93S66 - TACHO
6.903.794 12 16 93S66 - 1
6.903.804 12 16 93S66 - 1
6.906.110 09 13 93S66 - SW13
6.906.110 12 13 93S66 - SW13
6.906.110 14 13 93S66 - SW13
6.906.118 12 13 93S66 - SW13
6.906.119 12 13 93S66 - SW13
6.906.120 12 13 93S66 - SW13
6.906.122 12 13 93S66 - SW13
6.906.124.12 13 93S66 - SW13
6.906.124 14 13 93S66 - SW13
6.906.126 12 13 93S66 - SW13
6.906.148 12 13 93S66 - SW13
6.906.154 12 13 93S66 -SW13
6.906.889 10 20 M35080 - E46
6.906.890 10 20 M35080 - E46
6.906.897 10 20 M35080 - E46
6.906.901 10 20 M35080 - E46
6.906.991 16 14 M35080 - 1
6.906.992 15 14 M35080 - 1
6.906.992 16 14 M35080 - 1
6.906.998 15 14 M35080 - 1
6.906.999 15 14 M35080 - 1
6.906.999 16 14 M35080 - 1
6.907.015 16 17 M35080 - 1
6.907.018 16 17 M35080 - 1
6.907.021 14 17 M35080 - 1
6.911.287 12 23 M35080 - E46
6.911.315 12 23 M35080 - E46
6.914.873 19 15 M35080 - 1
6.914.874 19 15 M35080 - 1
6.914.879 19 15 M35080 - 1
6.914.884 18 15 M35080 - 1
6.914.885 18 15 M35080 - 1
6.914.885 19 15 M35080 - 1
6.914.905 19 15 M35080 - 1
6.914.908 19 18 M35080 - 1
6.914.913 19 18 M35080 - 1
6.914.930 19 15 M35080 - 1
6.915.237 21 31 M35080 - 2
6.931.244 22 32 M35080 - 2
6.932.907 27 35 M35080 - 2
6.940.589 21 17 M35080 - 1
6.942.546 24 21 M35080 - 1
6.948.237 23 20 M35080 - 1
8.352.207 06 08 93S56 - 1
8.364.005 06 09 93S56 - 1
8.369.051 07 12 93S56 - 1
8.372.354 09 09 93S56 - 1
8.372.354 11 09 93S56 - 3
8.372.354 13 09 93S56 - 3
8.372.357 13 09 93S56 - 3
8.372.359 09 09 93S56 - 3
8.372.359 10 09 93S56 - 3
8.372.359 11 09 93S56 - 3
8.372.359 12 09 93S56 - 3
8.372.359 13 09 93S56 - 3
8.372.359 14 09 93S56 - 3
8.372.359 15 09 93S56 - 3
8.372.361 11 09 93S56 - 3
8.374.336 07 13 93S56 - 3
8.375.669 04 11 93S56 - 4
8.375.675 04 11 93S56 - 4
8.375.895 16 10 93S56 - 3
8.375.898 16 10 93S56 - 3
8.375.900 16 10 93S56 - 3
8.375.902 16 10 93S56 - 3
8.376.192 07 14 93S56 - 5
8.376.701 04 05 93S56 - TACHO
8.376.707 04 05 93S56 - TACHO
8.376.708 04 05 93S56 - TACHO
8.378.983 07 15 93S56- 5
8.380.144 04 07 93S66 - E46
8.380.145 04 07 93S66 - E46
8.380.146 04 07 93S66 - E46
8.381.195 06 15 93S56 - 6
8.381.195 07 15 93S56 - 6
8.381.788 05 07 93S56 - TACHO
8.381.790 05 07 93S56 - TACHO
8.381.806 05 07 93S56 - TACHO
8.381.808 05 07 93S56 - TACHO
8.381.810 05 07 93S56 - TACHO
8.381.812 05 07 93S56 - TACHO
8.386.092 05 13 93S66 - E46
8.386.110 05 13 93S66 - E46
8.387.044 04 11 93S66 - TACHO
8.387.044 05 11 93S66 - TACHO
8.387.044 06 11 93S66 - TACHO
8.387.045 04 11 93S66 - TACHO
8.387.045 05 11 93S66 - TACHO
8.387.045 06 11 93S66 - TACHO
8.387.047 04 11 93S66 - TACHO
8.387.047 06 11 93S66 - TACHO
8.387.063 04 11 93S66 - TACHO
8.387.065 05 11 93S66 - TACHO
8.387.075 04 11 93S66 - TACHO
8.387.075 05 11 93S66 - TACHO
8.387.604 05 14 93S66 - E46
8.387.605 05 14 93S66 - E46
Блок фар LCM:
HW_SW_MCU-IDNR
00 11 HC11P2-1
00 31 HC11P2-2
00 41 HC11PH8--1
00 42 HC11PH8-1
00 43 HC11PH8-1
01 11 HC11PH2-1
01 20 HC11P2-1
01 21 HC11P2-1
01 31 HC11P2-2
01 41 HC11PH8-1
02 42 HC11PH8-1
02 43 HC11PH8-1
04 11 HC11P2-4
04 51 HC912-2
05 11 HC11P2-4
05 51 HC912-2
06 11 HC11P2-4
06 52 HC912-8
06 53 HC912-3
07 11 HC11P2-4
07 20 HC912-9
07 65 HC912-1
07 70 HC912-10
07 76 HC912-11
07 77 HC912-11
08 11 HC11P2-4
08 13 HC11P2-4
08 36 HC912-4
08 40 HC11PH8-2
08 76 HC912-11
09 13 HC11P2-4
09 36 HC912-4
09 40 HC11PH8-2
09 76 HC912-11
10 20 HC11P2-3
10 31 HC11P2-2
10 32 HC11P2-2
10 41 HC11PH8-1
11 41 HC11PH8-1
15 30 HC912-5
16 31 HC912-7
22 35 HC912-6
24 36 HC912-4
25 36 HC912-4
C1 40 HC11PH8-2
C1 41 HC11PH8-1
C1 43 HC11PH8-1
D1 41 HC11PH8-1
D1 42 HC11PH8-1
  • Upvote 1
Возможна изменить(BMW Scanner 1.3.6 - 1.4.0) показания одометра если там стоит M35080?
При читании прога сама предупреждает что ето 50/50 процентов что потом будут проблеммы с касом :2126126958458bce9a447b0: , поетому лучше вручную. :AllSmail (6):
или воще сейчас идёт лом цен на наше рукоделье, возми позвони етим до****бам которие за 30 евро такую работу делают :3_8_14: а если завалят приборку то и спрашывай с них :2126126958458bce9a447b0:
И в прочем вот совсем не давно соседу по дому делал коррекцию можно сказать на халяву и что из этого получилось климатконтроль не включался потом за работал и еще масса проблем повидиму связанных с коррекции пробега на холяву?!!! ладно без предъяв.
смотря какого года авто, там и 93S56 может стоять
SW-11- китаец делает
может стять 93S56, 93S66, 35080
так же может и в CAS2 - 9S12DG256
Какой нах CAS2 в Е39
с 21 апреля уже прошло почти 10 дней,предлогаю закрыть тему!
и что? проблема то до сих пор не решена :post-4:
