VW Passat B5 AVF
Парни, всем привет! Подскажите куда ещё копнуть.... Топливо идет к тамдемному насосу, импульсы на форсы есть, соответственно и прокрутку видит, ошибок нет. С дизелями не особо часто ковыряюсь, по этому зашел в тупик, подозреваю, что перескочил ремень ГРМ, по этому снял ЛОГ 001,004,005 групп, но понять в нем чет не чего не могу, гляньте кто понимает в логах, что по нему можно сказать о синхронизации.
,Group A:,'001,,,,Group B:,'004,,,,Group C:,'005
,,Engine speed,Injected quantity,Spec. Inj. duration,Coolant temp,,Engine speed,Spec start of inj.,Spec inj. duration,Synchro. angle,,Engine speed,Start inj,Start synchro.,Coolant temp
,TIME,790-870,3.0-9.0,3-8 °Ck.,80-110°C,TIME,790-870,4BTDC-2ATDC,3-8 °Ck.,-3..+3°Ck.,TIME,rpm,quantity,,°C
Marker,STAMP, /min, мг/ул, CF,°C,STAMP, /min, °BTDC, CF, CF,STAMP, /min, мг/ул,,°C
,0.71,0,0.0,-35.7,16.2,0.02,0,39.4,-35.7,0.0,0.34,0,6.0,0.0,16.2
,1.81,0,0.0,-35.7,16.2,1.07,0,39.4,-35.7,0.0,1.43,0,6.0,0.0,16.2
,2.90,0,0.0,-35.7,16.2,2.17,0,39.4,-35.7,0.0,2.53,0,6.0,0.0,16.2
,4.09,0,0.0,-35.7,16.2,3.29,0,39.4,-35.7,0.0,3.70,0,6.0,0.0,16.2
,5.29,0,0.0,-35.7,16.2,4.54,0,39.4,-35.7,0.0,4.92,0,6.0,0.0,16.2
,6.41,0,0.0,-35.7,16.2,5.66,0,39.4,-35.7,0.0,6.04,0,6.0,0.0,16.2
,7.53,0,0.0,-35.7,16.2,6.78,0,39.4,-35.7,0.0,7.15,0,6.0,0.0,16.2
,8.64,0,0.0,-35.7,16.2,7.90,0,39.4,-35.7,0.0,8.28,0,6.0,0.0,16.2
,9.72,0,0.0,-35.7,16.2,8.99,0,39.4,-35.7,0.0,9.35,0,6.0,0.0,16.2
,10.93,0,0.0,-35.7,16.2,10.12,0,39.4,-35.7,0.0,10.53,0,6.0,0.0,16.2
,12.05,0,0.0,-35.7,16.2,11.28,0,39.4,-35.7,0.0,11.67,0,6.0,0.0,16.2
,13.19,0,0.0,-35.7,16.2,12.42,0,39.4,-35.7,0.0,12.81,0,6.0,0.0,16.2
,14.26,168,31.8,11.7,16.2,13.57,147,6.5,11.7,-1.7,13.91,168,31.8,1.0,16.2
,15.35,168,31.8,11.7,16.2,14.61,168,6.5,11.7,-1.7,14.98,168,31.8,1.0,16.2
,16.53,168,36.0,12.8,16.2,15.73,147,6.5,12.2,-1.7,16.14,168,34.6,1.0,16.2
,17.75,168,40.9,13.3,16.2,16.96,168,6.5,12.8,-1.7,17.36,147,39.5,1.0,16.2
,18.93,168,45.6,13.8,16.2,18.14,168,6.5,13.3,-1.7,18.53,168,44.2,1.0,16.2
,20.09,168,50.2,14.8,16.2,19.33,168,6.5,14.3,-1.7,19.72,168,48.9,1.0,16.2
,21.23,168,50.8,14.8,16.2,20.46,168,6.5,14.8,-1.7,20.83,168,50.8,1.0,16.2
,22.38,168,50.8,14.8,16.2,21.60,168,6.5,14.8,-1.7,21.99,168,50.8,1.0,16.2
,23.47,168,50.8,14.8,16.2,22.73,168,6.5,14.8,-1.7,23.09,168,50.8,1.0,16.2
,24.68,168,50.8,14.8,16.2,23.87,168,6.5,14.8,-2.2,24.28,168,50.8,1.0,16.2
,25.87,168,50.8,14.8,16.2,25.07,168,6.5,14.8,-1.7,25.47,168,50.8,1.0,16.2
,27.02,168,50.8,14.8,16.2,26.28,168,6.5,14.8,-1.7,26.65,168,50.8,1.0,16.2
,28.17,168,50.8,14.8,16.2,27.41,168,6.5,14.8,-2.2,27.81,168,50.8,1.0,16.2
,29.30,0,0.0,5.6,16.2,28.56,126,6.5,5.6,-1.7,28.92,0,0.0,0.0,16.2
,30.45,0,0.0,5.6,16.2,29.70,0,6.5,5.6,2.8,30.07,0, 31.8,0.0,16.2
,31.64,0,0.0,5.6,16.2,30.85,0,6.5,5.6,2.8,31.24,0, 31.8,0.0,16.2
,32.86,0,0.0,5.6,16.2,32.02,0,6.5,5.6,2.8,32.44,0, 31.8,0.0,16.2
,34.03,0,0.0,5.6,16.2,33.28,0,6.5,5.6,2.8,33.68,0, 31.8,0.0,16.2
,35.16,0,0.0,5.6,16.2,34.39,0,6.5,5.6,2.8,34.75,0, 31.8,0.0,16.2
,36.30,0,0.0,5.6,16.2,35.53,0,6.5,5.6,2.8,35.91,0, 31.8,0.0,16.2
,37.43,0,0.0,5.6,16.2,36.68,0,6.5,5.6,2.8,37.06,0, 31.8,0.0,16.2
,38.62,0,0.0,5.6,16.2,37.83,0,6.5,5.6,2.8,38.22,0, 31.8,0.0,16.2
На очистителе карба завелся :ThanxSmiley:
