Активность
- Последний час
Jshop.cc, non VBV CC, CVV, Ransomware As a Service, loading bank accounts and credit cards, browser stealer, RAT, Payload, Botnet, Keylogger, The New Genesis.Market Marketplace 2025, non-VBV CC stores, list of Cardable Gateway 2D sites, virus, malware, Trojans. OTP/2FA bypass tool, Office 365 corporate logs, payroll, BEC, professional email compromise account shops, bank log sites, hacking and spamming account shops, brute force, cracking, tutorials, methods, guide, valid and legitimate onion sites, online banking and shop services, shell, fullz CC, bank open ups, deposit, pickups, magbo cc invitation code and cracking. You can also request for a particular country's CC/CVV shop you are looking for, and I will get it for you. Dumps with pin, real physical ID cards for UK, Canada, USA, and Australia to be delivered to your house, and fullz info are also available. I'm also a carder and spammer too, and you can also spread my ransomware file online and social media to earn good money from. An Example: - https://imgur.com/a/dCDjxAw Screenshots: https://imgur.com/a/Pe5ZiMz https://imgur.com/a/fey5Fhi https://imgur.com/a/ZmCUewK https://imgur.com/a/FwIGVU7 https://imgur.com/a/KJ4jwr0 https://imgur.com/a/PSAiZbo https://imgur.com/a/hka4f6W https://imgur.com/a/juyk14S https://imgur.com/a/IwWldcW Video: https://www.mediafire.com/file/jzfvs1kn3o2pv49/Screen_Recording_20241011_205250_Chrome2.mp4/file Dark Web Site: http://pasteboxx44wtzbm3ldjkcncls6uggi7mipmdwef5zza6wjqrqrtxdid.onion/paste.php?id=127879 Readily available. Escrow is also accepted. Telegram ID: https://t.me/hXckerman Telegram Group: https://t.me/invitationcodess
- hacking carding
- spamming
(и ещё 3 )
C тегом:
Mmylovelifee присоединился к сообществу
- Сегодня
Здравствуйте.Такая же проблема с ЭБУ.Купили ,поставили ,начали адаптацию пропала N.Ищем дамп ,если сохранился,поделитесь? Буду очень признателен.
ser975 подписался на Разыскивается дамп ТСМ Peugeot 107
ser975 присоединился к сообществу
wrykit изменил фотографию своего профиля
virtus44rus подписался на Valeo V40 ищу FULL FLASH
Доброго времени суток всем!Ищу сток Фулл для записи ктагом на RENAULT FLUENCE 1.6L AT VALEO V40 HW0131R 0644R SW3058R Цена обсуждаема, очень прошу помочь.Блок увалился при записи на связь выходит, но при записи валится ошибка.Писать пробовали Кесом и ПЦМ
Dennks присоединился к сообществу
wrykit подписался на BOSCH Invented for life
можно
Так написали бы батник, а то столько заморочек с командами. 😀
я делал так по инструкции 1. копируем на флешку фат 32 архив загрузочной флешки F_23MM_SWX058.6_230906 2. заходим в ИМ тойота стандартным способом через шторку как на камри, находим раздел update setting 3. снимаем все галочки справа кроме второй 4. выходим на главный экран и вставляем флешку с обновлением, в разделе настройки так жк как на всех тойотах запускаем обновление с флешки вкладка систем- версия по и кнопка упдате и даллее юсб и апдейт 5. ждем пока появится стандартное окошко об окнчании обновления, примерно процесс займет минут 40 - несколько раз гу будет ребутиться, после появления окошка с галочкой об успешном обновлении вынимаем флешку 6. Запускаем Командную строку CMD и далее все команды делаем в ней до самого окончания русификации не закрывая (примечание! Папку прошивки RAV4 ( по возможности сохраняйте в корне диска C,D или другого чтобы в процессе обновления не было в наименовании пути русских символов, только латиница!!!) 7. входим в инженерку и включаем адб. подключаем шнур комп-авто 8. в окне CMD по очереди копируем и вставляем построчно следующие команды, важно!!!!!! каждую строку проверяем, не допускаем дублей! если задублировать или пропустить то гу пойдет под пайку и прошивку софтом через джитаг поэтому делаем крайне внимательно!!!!! 1 блок - подготовка гу и заливка файлов прошивки в гу: итого саксес adb -d root adb -d disable-verity adb -d reboot adb -d root adb -d remount adb -d push p.bin /sdcard adb -d push v.bin /sdcard adb -d push b.bin /sdcard adb -d push s.bin /sdcard 2. блок проливки файлов прошивки: начинаем по умолчанию с раздела Б: ВНИМАТЕЛЬНО ПРОЛИТЬ ВСЕ ; ПУНКТА БЕЗ ДУБЛЯЖА (команды будут проливаться без индикации от 10 сек до 10 мин. ничего не будет происходить . нужно ждать когда пояпится напись о готовности с затраченым временем в секундах и проливать следующую и тд. экран ГУ может потухнуть - это норма - реанимируется после ребута. adb -d shell dd if=/sdcard/b.bin of=/dev/block/by-name/boot_b bs=10000 adb -d shell dd if=/sdcard/v.bin of=/dev/block/by-name/vendor_b bs=10000 adb -d shell dd if=/sdcard/s.bin of=/dev/block/by-name/system_b bs=10000 adb -d shell dd if=/sdcard/p.bin of=/dev/block/by-name/product_b bs=10000 3. после успешной проливки данных 4 файлов делаем двойной ребут следующими командами: adb -d reboot adb -d reboot после первого ребута может отвалиться адб, включаем его в инженерке если так произошло!!!! 4. после этого появляется успешно русский, если не появился, то делаем повторно пункты 1 и 2 но вместо команд из второго блока пишем те котрые ниже в 4 следующими командами: adb -d shell dd if=/sdcard/b.bin of=/dev/block/by-name/boot_a bs=10000 adb -d shell dd if=/sdcard/v.bin of=/dev/block/by-name/vendor_a bs=10000 adb -d shell dd if=/sdcard/s.bin of=/dev/block/by-name/system_a bs=10000 adb -d shell dd if=/sdcard/p.bin of=/dev/block/by-name/product_a bs=10000 после успешной проливки данных 4 файлов делаем двойнеой ребут следующими командами: adb -d reboot adb -d reboot 5. после этого убираем заставку тойота кастом тим, и потом удаляем файлы прошивки из ГУ следующими командами: Видео и удаляем лишнее------------------ adb -d root adb -d remount adb -d push 2228.mp4 /system/media/carbootanimation.avi adb -d reboot adb -d shell rm /sdcard/b.bin adb -d shell rm /sdcard/v.bin adb -d shell rm /sdcard/s.bin adb -d shell rm /sdcard/p.bin adb -d reboot после этого копируем приложения из папки install в адб апп контрол и устанавливаем вручную приложения через app control в ГУ, если машина не видит апп контрол - заходим в ИМ и вручную повторно включаем в ИМ АДБ. CMD можно закрывать после успешной установки всех приложений, делаем стандартный набор действий в ГУ: - ребут/В настройки андройд попасть можно через приложения
спорить не буду...честно не проверял ..но есть опыт от других...что такие ошибки делать не надо....
prommasttablet присоединился к сообществу
miha2780 присоединился к сообществу
regs40 подписался на SID208 Ford tranzit
ну это вы ошибаетесь, пробелы не как не повредят. тем более кому лень команды набирать в ручную, есть программы которые за вас все сделают, так сказать с графическим интерфейсом. по этому и написал выше, что тренируйтесь на старых телефонах, планшетах.
да.. там да пробел в команде поставишь ошибочно шгу уйдет в останов или перезагрузку....там потом только с Z3X Easy Jtag Plus работать
вот упёртый - написано все выше и на других ресурсах.
dm.bors присоединился к сообществу
кибак присоединился к сообществу
- Вчера
Degtyarevas присоединился к сообществу
wrykit подписался на Toyota Techstream 18.00.008 (2.2023) New Latest
Здравствуйте. Не помните как решилась проблема?
ans70 подписался на SID208 Ford tranzit
Подскажите, какой номинал у резистора?
sashkapavlov подписался на PEPS Haval f7x
Огромная благодарность Вячеславу за помощь, ввёл пин в peps во вкладке замены TCU, peps его принял, блок КПП тоже принял пин,авто запустился. Кстати донорский блок от Haval M6, прошивать фуллом не пришлось.
Спасибо огромное!
ID: 6366C2188DF34E9CB309C3530EFA0405 Ver: 12.20.XXX NA: 85c01ebf1ea90acbce201f202077997240002509041757 EU: 7c14bfadb72814f4393a588777df0b0640002509041757 JP: 9f0367f2080d17009525040093d14b74c6d5a451ce9d7f OT: 85aee1c9658ed42bf8340a9de599c40440002509041757
привязать коробку хотите,? или пепс замена?
TECHSTREAM V12.20.024 как получить ключ доступа. Похерил старый с ноутом (сдох). ID 6366C2188DF34E9CB309C3530EFA0405
если вкратце, то примерно так, из архива обновления Головы достаем файл payload.bin, payload.bin это и есть образ системы, только запакованный. распаковываем его, в инете полно программ для работы с ним, получаем на выходе образы диска, примерный список: boot.img: Содержит ядро (kernel) и ramdisk, которые используются для начальной загрузки системы. Именно этот раздел мы будем патчить для рутирования. system.img: Содержит основную операционную систему (MIUI, Android), включая системные файлы и приложения. vendor.img: Хранит специфические для устройства драйверы и библиотеки. vbmeta.img: Используется для проверки целостности других разделов (Verified Boot). recovery.img: Содержит рекавери (например, MIUI Recovery), используемое для восстановления и обновления системы. дальше уже хотите делаете все что хотите с файловой системой, но для полного доступа root нам нужен файл boot.img, boot.img файл аналогично запакован, распаковываем и его, получаем все загрузочные файлы и папки. патчим ADB инициализацию, запаковываем все обратно. далее заливаем оригинальное обновление в головное устройство через USB флешку, потом подключаем ноут к головному устройству через USB кабель (USB A USB A), включаем режим development mode, далее находим в меню включение ADB интерфейса, включаем и АДБ, потом уже качаем драйвера ADB и программу ADB, например с гугловского сайта. все устанавливаем на ноут и работаем, в fastboot заливаем наш патченый образ boot.img, system.img и т.д. перезагружаем устройство, а далее уже через ADB интерфейс загружаем любые программы на головное устройство. прежде чем лезть в головное устройство, потренируйтесь на каком нибудь телефоне или планшете.. а то кирпич получить проще простого если что то лишнего удалите.
Надо прислать новый ИД с нового ПК, на который установил программу.
