P_ART
Весь контент P_ART
  1. halo i read eeprom to change km on vw touran 2003 1.9 diesel . transmission automatic. i use vag can comander 3.6 ( connected to kombi instrument) after i read and save eeprom, i change km, and after i change i read fault codes in car ( i dont know if its old ore by me) becouse this car transmission was change 3 years ago. and its not possible to clean foult code.. and i got this fault code in transmission: Establishment diagnostic session with selected unit .... Diagnostic channel is open. --- electronic control unit identification --- ================ Device N: 1 ================ 02E300041 SW version: 0814 PROGRAMMABLE Coding :20 Part number : 200 Importeur's number :785 Supplier number : 6402 System description : GSG DSG 041 ============================================ 01208 Data Records in Control Unit Altered Status : Permanent error ============================================ pleas help me what to do?? 2003 vw touran.rar
  2. helo i nead help info, mercedec vito 2001 the dashbord is disconnecting when driving if i want to change in to another dashboard but keep old keys , it will work???? ore i nead to do programing on keys ? and ho to program to new dashbord??? and if i wil fail adopt keys can i put back old dashbord and it still works as before???? pazalsta pamagyte
  3. in car servis it was changing glow plugs i fink they will instal good plugs. i know its 2 difrent type of glow plugs ,maybe you can write what kind is nead for whis model.
  4. halo we made new test on 2007 passat , win number -Log-WVWZZZ3CZ7E173184 Saturday,01,June,2013,10:31:37:59305 VCDS Version: Beta 12.10.3 Data version: 20130228 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-016-BKC.lbl Control Module Part Number: 03G 906 021 LR HW: 03G 906 021 AN Component and/or Version: R4 1,9L EDC G000SG 9248 Software Coding: 0000071 Work Shop Code: WSC 05311 000 00000 VCID: 7AFB34153538F0BC17D15E 4 Faults Found: 005658 - Glowplug for Cylinder 1 (Q10) P161A -- 000 -- Open Circuit Freeze Frame: Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 1 Mileage: 149619 km Time Indication: 0 Date: 2000.00.00 Time: 00:55:13 Freeze Frame: RPM: 0 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 11.10 V Bin. Bits: 00001000 Temperature: 1.8°C Bin. Bits: 00110000 005660 - Glowplug for Cylinder 3 (Q12) P161C -- 000 -- Open Circuit Freeze Frame: Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 1 Mileage: 149619 km Time Indication: 0 Date: 2000.00.00 Time: 00:55:13 Freeze Frame: RPM: 0 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 11.10 V Bin. Bits: 00001000 Temperature: 1.8°C Bin. Bits: 00110000 005673 - Powertrain Data Bus P1629 -- 000 -- Missing Message from Auto-Distance Controller Freeze Frame: Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 1 Mileage: 149619 km Time Indication: 0 Date: 2000.00.00 Time: 00:55:13 Freeze Frame: RPM: 0 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 11.10 V Bin. Bits: 00001000 Temperature: 1.8°C Bin. Bits: 00110000 005665 - Engine Coolant Temp Signal P1621 -- 000 -- Short to Ground Freeze Frame: Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 1 Mileage: 149619 km Time Indication: 0 Date: 2000.00.00 Time: 00:55:13 Freeze Frame: RPM: 0 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 11.10 V Bin. Bits: 00001000 Temperature: 1.8°C Bin. Bits: 00110000 Readiness: 0 0 0 0 1 we tested 2 difrent relay ( i put tester to glow plug wire - its 10.v for 1 sekond and after go til 2.2 v for 4 sekonds. ) on passat 2006 year its gos 10 v and after 4.5 v meabe its not inaf vats for glow plugs and she car dont want to start.
  5. P_ART опубликовал тема в VAG AUDI/VW/SEAT/SKODA
    i nead info i read foult codes P161D - Unknown fault code P161C - Glow plug cylinder 3, open circuit- Permanent P161B - Glow plug cylinder 2, open circuit- Permanent P161A - Glow plug cylinder 1,open circuit- Permanent the wires is ok , glow plugs new all 4, glow plug control module-(relay) - when start the engine is shows 10.2 v for a sekond and after 2.2 v. and same tested other relay. the car is not starting. sory for ban english , ploha gavariu na ruskam. spasyba thanks for all info .
  6. спасибо Я привел в порядок мои EEPROM повреждены и теперь все хорошо
  7. открыл EEPROM (повреждены) и там написано 1U1 034J A4 VDO V22SKX 0371871
  8. но мой был :1U1 034J A4 VDO V22SKX 0371871 будет ли он работать
  9. имею ключи (шутка), но мне нужно EEPROM, или вы можете разобраться в который добавил EEPROM исправить. или скажите мне, какой файл нужен, спасибо
  10. Привет. Мой русский не является совершенным. запись в блоге EEPROM неправильно, поэтому нужно хорошее EEPROM 2000 Skoda Octavia 1.6 бензин. я загрузил : 1U1919034S A4-KOMBIINSTR. VDO V22 старый поврежденный EEPROM присоединение skoda.bin
  11. Здравствуйте, я купил тахометр Pro, и 21 кабеля без Фиск, может быть, вы знаете, как подключить? но она должна быть как на картинке vw t4 1997 tacho pro 2008( golf 3, mb c class ) Мой русский язык очень беден, спасибо
