nabelautoscan
  1. Hello everyone, Here is the Original Stock Flash File for Nissan Almera, fully tested and unmodified. It is ready for repairs, comparison, or remapping. ECU Information: • Make: NISSAN • Model: ALMERA II (N16) • Engine: 2.2 Di (Diesel) • Power: 110 HP / 81 kW • ECU Manufacturer: BOSCH • ECU Type: EDC15M+1-5.3 • Bosch HW: 0281010141 • Bosch SW: 1037354353 (Short ID: 35435) • OEM Number: 23710-5M300 • Memory Chip: AM29F400BT (Flash 512KB) Technical Notes: • Useful for unbricking ECUs caused by bad flashing. • Perfect as a base file for Chiptuning / Stage 1 or system deletes. Best regards! NISSAN ALMERA 2.2DI 110HP 0281010141 354353 Original.rar
  2. Hello everyone, I am sharing a verified stock (original) flash file from my personal database for a Renault Clio. I hope this helps anyone working on a similar vehicle or looking for a clean backup. Here are the full specifications of the vehicle and ECU: • Make / Model: Renault Clio 2 • Engine: 1.2L 8V (8 Valves) • ECU Model: Siemens / Continental EMS3132 • Network Communication: Equipped with CAN-bus • Options: Original Air Conditioning (Clim / AC) • File Type: Original Flash (Stock) File Password: No Password / Free for everyone. Please find the attached file below. Don't forget to press Thanks and Reputation buttons if this file helps you! Clio 1.2 v8-EMS3132 Avec Can bus-Clim Original.rar
  3. Marque, modèle et année de fabrication : Opel Astra H 2006 | Cylindrée : 1,6 L | Carburant : 105 ch | Boîte de vitesses : Automatic | Fabricant du calculateur : MT35E 2.3 | Méthode de lecture du bootloader : Kess ODB Chine | Tâche technique : Optimisation pour essence 95 (consommation maximale) ; création d'un firmware pour Kess. Le véhicule a été flashé pour la norme Euro 2 (selon le propriétaire), le firmware n'est donc plus d'origine. Fichiers d'origine, identifiants et autres : Fichiers joints . Identifiants du programme de bootloader : Matériel : FFFT | Logiciel : POP3805 | Moteur : Z16XEP | Version matérielle : MT35E 2.3 | Mise à jour logicielle : A0500002 | Installation : DELCO0100 Opel Astra H 1,6 L Carburant 105 ch Boite Automat 2006 Kess V2 OBD2.rar
