Опубликовано 17 июля, 201016 г. comment_98916 Enginuity is a free Engine Control Unit (ECU) editor used for tuning Fuel, Timing, Boost and all other ECU controlled parameters by virtual any vehicle manufacturer Enginuity provides many features normally only seen in commercial software applications. The main capabilities are: Platform agnostic: Enginuity is written in Java making it easier to support tuning on various operating systems. Currently Windows and Linux are supported. Subaru and Mitsubishi support: Support for many Subaru and Mitsubiti ROM versions via plug-in ECU definition data files. ECU definitions can be upgraded independantly of the actual tuning software. Multiple maps: The ability to load, modify and save one or more ROM files Intuitive user interface: Simple, easy to use user interface which presents the various ROM maps within a tree view grouped by function e.g. Boost, Fuel, Timing are each groups collating a number of related maps. Tuning by User Level: This is a tuning safety related capability which restricts (write) access to certain maps based on User Level e.g. beginner, intermediate, advanced. User level may be dynamically switched at any time. Intelligent map data display: All data within maps are intelligently displayed using the appropriate unit of measure e.g. RPM, Boost (PSI/Bar - absolute or relative), Temperature (degrees F or C). Additionally map data is colour coded greatly reducing the time taken to understand and tune a map. 3D graphing: Map table data may be displayed in 3D as an additional map visualisation aid. Map tuning assistant: A detailed description of each map is available to the tuner from the map properties page. Map comparision: This allows maps from the same or different ECUs to be easily compared. Map copy & paste: ROMs can be quickly tuned using the map copy and paste capability. Map smoothing: This allows tuners to interpolate map data values greatly reducing the time taken to alter maps. Realtime data logging and post analysis tool: This includes the ability to overlay data logs on to actual maps as an aid when fine tuning. скачать EnginuitySetup0.4.0b Изменено 17 июля, 201016 г. пользователем o717ka Ссылка на комментарий https://www.auto-bk.ru/forum/topic/11255-enginuity/ Поделиться на другие сайты Поделиться в Facebook Поделиться в X Поделиться в Pinterest Поделиться Поделиться сообщением
Опубликовано 19 июля, 201016 г. comment_99168 А по русски, хотя-бы в 2 словах - слабо? Ссылка на комментарий https://www.auto-bk.ru/forum/topic/11255-enginuity/#findComment-99168 Поделиться на другие сайты Поделиться в Facebook Поделиться в X Поделиться в Pinterest Поделиться Поделиться сообщением
Опубликовано 19 июля, 201016 г. comment_99170 А по русски, хотя-бы в 2 словах - слабо? переводчиком воспользоваться слабо? Ссылка на комментарий https://www.auto-bk.ru/forum/topic/11255-enginuity/#findComment-99170 Поделиться на другие сайты Поделиться в Facebook Поделиться в X Поделиться в Pinterest Поделиться Поделиться сообщением
Опубликовано 19 июля, 201016 г. comment_99172 Так лишние заморочки всё же... Ссылка на комментарий https://www.auto-bk.ru/forum/topic/11255-enginuity/#findComment-99172 Поделиться на другие сайты Поделиться в Facebook Поделиться в X Поделиться в Pinterest Поделиться Поделиться сообщением
Опубликовано 19 июля, 201016 г. comment_99173 стандартные технические термины и слова, которые если не знаешь то с этим софтом ловить вам не чего. грубо говоря кому нужно тот поймет что за софт и для чего. Ссылка на комментарий https://www.auto-bk.ru/forum/topic/11255-enginuity/#findComment-99173 Поделиться на другие сайты Поделиться в Facebook Поделиться в X Поделиться в Pinterest Поделиться Поделиться сообщением
Опубликовано 19 июля, 201016 г. comment_99183 Enginuity (ECU) редактор используется для настройки топлива, зажигания, Boost и все другие (ECU) параметры Ссылка на комментарий https://www.auto-bk.ru/forum/topic/11255-enginuity/#findComment-99183 Поделиться на другие сайты Поделиться в Facebook Поделиться в X Поделиться в Pinterest Поделиться Поделиться сообщением
Опубликовано 20 июля, 201016 г. Автор comment_99262 А по русски, хотя-бы в 2 словах - слабо? вот прошивка от субарика, открой в этой проге и посмотри, сразу станет понятно STG1 MY05 LGT MT rev1.rar Изменено 20 июля, 201016 г. пользователем o717ka Ссылка на комментарий https://www.auto-bk.ru/forum/topic/11255-enginuity/#findComment-99262 Поделиться на другие сайты Поделиться в Facebook Поделиться в X Поделиться в Pinterest Поделиться Поделиться сообщением
Опубликовано 20 июля, 201016 г. comment_99309 Вот теперь пацаны для меня всё понятно, по человечески,...и без всяких ...обид. Спасибо. Ссылка на комментарий https://www.auto-bk.ru/forum/topic/11255-enginuity/#findComment-99309 Поделиться на другие сайты Поделиться в Facebook Поделиться в X Поделиться в Pinterest Поделиться Поделиться сообщением
Опубликовано 20 июля, 201016 г. Автор comment_99313 в проге даже маска ошибок есть, и основные калибры ( около100 ) Ссылка на комментарий https://www.auto-bk.ru/forum/topic/11255-enginuity/#findComment-99313 Поделиться на другие сайты Поделиться в Facebook Поделиться в X Поделиться в Pinterest Поделиться Поделиться сообщением
Опубликовано 20 июля, 201016 г. comment_99315 она только по субару? Ссылка на комментарий https://www.auto-bk.ru/forum/topic/11255-enginuity/#findComment-99315 Поделиться на другие сайты Поделиться в Facebook Поделиться в X Поделиться в Pinterest Поделиться Поделиться сообщением
Опубликовано 20 июля, 201016 г. Автор comment_99318 совершенно не хотите читать.... http://translate.goo...315&sl=en&tl=ru Изменено 20 июля, 201016 г. пользователем o717ka Ссылка на комментарий https://www.auto-bk.ru/forum/topic/11255-enginuity/#findComment-99318 Поделиться на другие сайты Поделиться в Facebook Поделиться в X Поделиться в Pinterest Поделиться Поделиться сообщением
Опубликовано 25 июля, 201016 г. comment_100083 Отличная прога,респект! Ссылка на комментарий https://www.auto-bk.ru/forum/topic/11255-enginuity/#findComment-100083 Поделиться на другие сайты Поделиться в Facebook Поделиться в X Поделиться в Pinterest Поделиться Поделиться сообщением
Опубликовано 16 августа, 201015 г. comment_103491 Вот считал файл калибровок Галетой. Вопрос можно ли этой прогой Enginuity редактироать этот файл. Ссылка на комментарий https://www.auto-bk.ru/forum/topic/11255-enginuity/#findComment-103491 Поделиться на другие сайты Поделиться в Facebook Поделиться в X Поделиться в Pinterest Поделиться Поделиться сообщением
Опубликовано 18 ноября, 201015 г. comment_124667 Аналогичная ситуация по галлете. Просветите кто в курсе. Чем можно калибры из Галеты править ? Да и по проге, это вроде бета как я понял. Где deffenition файлы брать? Изменено 18 ноября, 201015 г. пользователем Алексей ACV Ссылка на комментарий https://www.auto-bk.ru/forum/topic/11255-enginuity/#findComment-124667 Поделиться на другие сайты Поделиться в Facebook Поделиться в X Поделиться в Pinterest Поделиться Поделиться сообщением
