hyundai getz ECU flashing
can anyone post a guide on how to tune the 2009 getz 1.6 ECU (in the picture) including all software and hardware and maps needed, thanks
this is a picture of my ECU
Where contents of the block of management?(ECU)
sorry radick16 i can't understand you, what do you mean?
1. Try to understand at once))
2. What equipment do you have for reading flashing tuning?
3.To do tuning you need to read the original version of software, according to your picture it is TFG6N62.
4. I'll give you one of the variant of necessary equipment http://www.almisoft.ru/combiloader_M797_OBD.htm
5.There is the description in HELP how to read the content of Flash or to read with any kind of programming order supporting this kind of chip.
1-ok :)
2-i was going to make an L-line adabter like the one in the attached picture to connect the ECU to my computer
3-i know that, but do i have to open my ECU and add the two 5 K ohm resistors like the second picture or can i read and flash my ECU without opening it?
4-do you have any links to adapters and software in english, i don't know Russian and all software in the forum is in Russian.
5-could you please put a link
6-do u have any good firmware for the 2009 1.6 getz manual transmission?
7-if a read my car original software could anyone here help me in tweaking it?
thanks
read with your adapter using two resistors like in your photo. If you can read this software, I'll try to help you.
thanks alot, do you have any software in english, i can't read Russian and all programs i found here are in Russian.
  • 2 года спустя...
:tormoz: Thanks
