Опубликовано 11 апреля, 201213 г. Hi there, I'm noobie in this forum, and I own a Niva 2123, since 2005, since then I have a problem with hot water from my cooling sistem, during the town trips. When I go outside the town, my water temperature is OK 90ooC. So I need your help, to try to solve my problem, since I discovered my problem I changed my radiator, my cooling liquid, and also my cooling pump, but the problem remains, recently I discovered that my fans start a little late, after the temperature rise up around 1100 o C. Thank you in advance.
Опубликовано 11 апреля, 201213 г. Автор Hi there, I'm noobie in this forum, and I own a Niva 2123, since 2005, since then I have a problem with hot water from my cooling sistem, during the town trips. When I go outside the town, my water temperature is OK 90 C. So I need your help, to try to solve my problem, since I discovered my problem I changed my radiator, my cooling liquid, and also my cooling pump, but the problem remains, recently I discovered that my fans start a little late, after the temperature rise up around 110 C. Thank you in advance. last edit ...
