Mitsubishi Outlander 2009 обучить брелок
Всем привет,Парни подскажите как прописать кнопки ЦЗ на ключе на
Mitsubishi Outlander 2009,ключ второй прописал а с кнопками ни как не получается ,Ключ обычный с двумя кнопками с светодиодом посередине ,Спасибо
https://www.auto-bk.ru/forum/topic/56251-mitsubishi-outlander-2009-%D0%BE%D0%B1%D1%83%D1%87%D0%B8%D1%82%D1%8C-%D0%B1%D1%80%D0%B5%D0%BB%D0%BE%D0%BA/
Задай вопрос GOOGLE типа "mitsubishi outlander 2009 remote programming" и изучай.
Procedure
1. Ensure ignition is switched off.
2. Short pins 1 to ground of the DLC with a wire link.
3. Within 10 seconds press the HAZARD switch 6 times.
4. Doors should lock and unlock to confirm programming mode.
5. Press & release the LOCK button of the remote.
6. Within 10 sec: Press the LOCK button of the remote twice.
7. Doors should lock and unlock to confirm registration of remote.
8. If programming additional remotes, within 1 minute. Repeat steps 5 & 6 for each remote.
9. Doors should lock and unlock to confirm registration of each remote.
10. Remove wire link to exit programming mode.
Notes: a. All existing remotes will be erased when the programming mode is entered and must be re-programmed
back in as part of the procedure.
b. Ensure all remotes are added within 1 minute of the entering the program mode.
c. A maximum of 4 remotes can be programmed.
если прокатит
у дилеров мутом 600 р
всем спасибо , обучил мпв
