November 30, 200817 yr comment_2423 T - CR16 Programmer заполни профиль T___CR16_Programmer.rar Edited February 11, 200917 yr by Slavik k Link to comment https://www.auto-bk.ru/forum/topic/699-t-cr16-programmer/ Share on other sites Share on Facebook Share on X Share on Pinterest More sharing options... Share this post
November 30, 200817 yr comment_2462 Похоже, что эта софтина работает со своим адаптером. Link to comment https://www.auto-bk.ru/forum/topic/699-t-cr16-programmer/#findComment-2462 Share on other sites Share on Facebook Share on X Share on Pinterest More sharing options... Share this post
December 1, 200817 yr comment_2526 Похоже, что эта софтина работает со своим адаптером. Я купил айрбек тулс у него как опция идет ср16 но там ком порт а эта софтина просит USB заполни профиль Edited February 11, 200917 yr by Slavik k Link to comment https://www.auto-bk.ru/forum/topic/699-t-cr16-programmer/#findComment-2526 Share on other sites Share on Facebook Share on X Share on Pinterest More sharing options... Share this post
December 6, 200817 yr comment_2981 interface ???? заполни профиль Edited February 11, 200917 yr by Slavik k Link to comment https://www.auto-bk.ru/forum/topic/699-t-cr16-programmer/#findComment-2981 Share on other sites Share on Facebook Share on X Share on Pinterest More sharing options... Share this post
December 6, 200817 yr comment_2988 T-Box device More info http://tmw.netlook.pl/mainen.php заполни профиль Edited February 11, 200917 yr by Slavik k Link to comment https://www.auto-bk.ru/forum/topic/699-t-cr16-programmer/#findComment-2988 Share on other sites Share on Facebook Share on X Share on Pinterest More sharing options... Share this post
February 11, 200917 yr comment_8226 Do not open the T-Box device. - Do not try to read the MCU, it’s protected. - Be careful while trying to connect T-Box device with any other hardware. TMW electronic takes no responsibility for the damage the device may cause! - If it's possible - always use external power supply (9-15V AC/DC)! - The voltage controll dip switch is scaled for the 100mA output current! You can increase the power consumption using additional resistors connected to the DB25 sock. - 100mA is the maximal output current value the device can deliver! Это цитата из хелпа к проге. Нужен девайс Link to comment https://www.auto-bk.ru/forum/topic/699-t-cr16-programmer/#findComment-8226 Share on other sites Share on Facebook Share on X Share on Pinterest More sharing options... Share this post
