Pedrox
Весь контент Pedrox
  1. О чем ты думаешь сейчас?
  2. Дубли лежат в блоках LCM EWS EGS.
  3. I can put it back to orig. car, but owner of this car want to sell this radio . ( have buyed new one with GPS).
  4. Hello All, I have on Bench carradio from Mercedes Benz Sprinter - Sound made by Becker, inside eeprom 24c08. After feew time cca 15sec show on Display PROD, and soud ids off. I try it switch off like by model with 24c04.... BE6xxx but not work. Can somebody help me disabke this PROD? or how to adapted to Car? Thank you in advance for help sound5_MB_sprinter24c08ori.rar
  5. I use for this Hotairgun, I clean SPI eeprom before reading on desk with Isopropanol and glassfibre pen. .... Be careful for smal parts of small parts (bullets) of solder...
  6. Better to remove cluster, remove needles by this dash ist easy, not so horrible like by X5. some time depend of MY is there 35080V6...
  7. Great, That was like a magic..., thanks a lot
  8. Hello all, I have trouble with Mercedes A kl 140, with ESP, there is fault.. ..Stering angle sensor not initialised,(readed with X-431 and the same fault readed with Strar diagosis). by ¨testing this module comunicate this sensor and show by turning sterring whell continousli angle from full testing area (- xx % to +xx%) without problem, but Fault is till current and can´t by clear. Where can be and how to solve this problem. Thank you in advance for help
  9. Pedrox
    bmw-530d
    On youre picture is not LCM module ....
  10. Problem solved, after clear second mileage in BCU all work OK
  11. BSI is posible to reprogram with Peugeot diagnostic, if exist newer sw for this unit (on line or from data DVD). In ecu is stored Nr of atemps to clear DTS and if is cleared with Peugeot diagnostic, is posible that is there ODO value. By this car is posible to read stored faults ioncl mileage in different units from "Faults diary".....
  12. Pedrox
    Landrover Rangerover 1999
    After modifi km value in dashboard By Landrover Rangerover (28c16) show display on dashboard odometer error. Have somebody experience with them? Is there other electronic what is neccesary to program (like by discovery)? how to solve this error?
  13. Hello, I need exchange ECU EDC16c34 from Peugeot 206 1.4 hdi, old is damaged and I haven´t choice to use dump from old ECU. How to clear used ECU? I have security code from the car and from the new used ecu too. Thank you in advance for help
  14. Pedrox
    BMW 730 1989
    ODO is stored in small blackbox inside lightbrown connectíng connector. You need special equipment for it, or make simulator for them....
  15. Connection you have in help menu - click on contens and go down to connecting information for HC08 MCUs - uuprog.pdf then is necessary make autobaud rate and after tri read MCU.... you need connect IRQ, PTA0, RESET , GND, make bridge between 60 and 55 connect UCH to power suply .
  16. pin26 +12v, pin51 - GND, pin54 - K,...... its connectoíon for VW51, I think taht for VW52 is the same...
  17. UPA-USB read it 100%, lift up Reset On MCU, make bridge between pin 60and 55
  18. LCM memory is only active if is in Dashboard 0km
