Thank you Alex, but this will not solve all the problems.
I found a way to fix this. :
Indeed, the dump is ok, but it is a problem with air bag controller: More info can be found at: http://www.ross-tech.com/vag-com/vw_issues.html
In this case, the Bug was not activated interface VAG-COM, 402.3 in later versions, including HEX + CAN stop the problem from a simple scan, but the fact that I accessed with another interface, and I read the content .
Rewrite controller in a dump "clear", does not solve the problem, that just comes from there, from accessing writing / reading dump in question, so do not solve anything.
In the end i solved the problem without off module on the car and to program directly MC.
Write a clear dump, acces module with vag-airbag and select MC correspondent, read eeprom, according to this, switch automatically in edit mode, implicitly at this stage to change state automatically MC module, leaving the status of memory error. At this time disconnect interlock on the car.
Scanned with VAG-COM, everything seems to be okay, implied no longer appear on any errors or dash on BC.
The archive attached to you all the tools that are needed.
A good night;)
airbag_repair_vw.rar
