lfas
Весь контент lfas
  1. thanks to MR grigolitv : the keygen here but where is the keygen for 2q2013 MR grigolitv : LOL
  2. hi all it's time for the keygen Mr Grigolitv for any auto-tech' members > who can share the keygen.? :AllSmail (26):
  3. lfas
    Ford Etis 10.2012
    торрент-файл Crack!_Ford_e-TIS_11.2011 sry /here торрент-файл magnet:?xt=urn:btih:064501e65f7afad711c62f39f829a200d5e901bd&dn=ford%20etis%202012.iso
  4. hello all I have a problem with my interfac "unknown" Das-Xentry 11.12 C3 in the register apply the patch ************************* Xentry Blacklist Fix FULL_BIN_FIXED_PARTD cal.ini for xentry modified for "Das" everything works fine, but "Xentry" displays this error help!!!
  5. почему бы не поделиться Keygen, чтобы все члены выгодно?
  6. llData 10.51 Full Complete - Domestic/Asian/Europe 3Q2011 | 02.2012 | EN | Win All | 48xDVD9 | iSZ | ~269 GB Alldata contains a full description of repair and maintenance for cars of American manufacture, as well as Asian and European vehicle production produced for the American market. Alldata 10.51 will help to repair not only American cars, but it will renovate and European and Asian foreign cars, since many nodes in the cars are identical, despite the assembly for different markets. The program provides detailed information on repair, which describes the features of the device separate mechanisms, norms of various parameters (volumes of refueling capacities, wheel alignment, etc.), the diagnostic and repair equipment and special tools, the description of works on assembly, disassembly, adjustment, repair and diagnostics, information about the location of components and tools, etc. The program Alldata 10.51, you can not only repair but also to engage in troubleshooting electronic components car. To do this, you have the following information: location of the diagnostic connector, detailed tables decoding fault codes indicating the possible causes, symptoms, and the consistency checks to fix the problem, description of the read blocks of current parameters with an indication of normative values, work with channel adaptation, etc . This version is the portable version and can be run from an external hard drive, unlike the previous version of this Alldata 10.51 added more drives, now the total number of 48 disk. AllData 10.51 • The most comprehensive information for 1982 to present vehicles, updated quarterly • OEM images, diagrams and diagnostic flow charts • Parts and labor information • Maintenance schedules • Manufacturer TSBs and Recalls • Integrated estimating software • OEM wiring diagrams with connector, ground, power distribution and splice information • A2Z Component Search - the fastest route available to component information Automotive repair shops that use the ALLDATA 10.51 system have a clear differentiation from other repair facilities. ALLDATA-equipped shops can provide their customers with the most accurate repair estimates and proof of diagnostic and repair procedures. ALLDATA also includes factory-correct maintenance schedules that itemize additionally needed services. Moreover, ALLDATA helps shops build consumer confidence and loyalty. AllData 10.51 Contents List: Daignosis and Repair All Diagnostic Trouble Codes(DTC) Relays and Modules Sensors and Switches Maintenance Engine, Cooling and Exhaust Powertrain Management Transmission and Drivetrain Brakes and Traction Control Starting and Charging Power and Ground Distribution Steering and Suspension Heating and Air Conditioning Restraint Systems Accessories and Optional Equipment Body and Frame Cruise Control Instrument Panel, Gauses and Warning Indicators Lighting and Horns Windows and Glass Wiper and Washer Systems Parts and Labour Popular Information Diagnostic Trouble Codes DTC Technical Service Bulletins Specifications Locations Diagrams Service Precautions Technician Safety Information Vehicle Damage Warnings Vehicle Identification Tools and Equipment System Diagnosis Five-Step Troubleshooting Troubleshooting Precautions Troubleshooting Tests General Troubleshooting Power Relay Test AllData 10.51 Models List: - USA (Domestic 1-10) - Model's 1960-1981 (Emission 2002) - Asian (Import 1-19) - Europe (Import 20-37) Full list of models available on each disc (total 48 disc's), also look in the archives AllData.10.50_48xDVD_How.to.Install_Run.From.HD_Manual.Info.rar and/or in the txt-file ALLDATA_3Q2011_Full_Complect_DVD_Contain.txt. These files are on each file-exchanger in the section Download. Install notes: - Place all ISZ-image files in one folder on your hard drive (eg.: AllData.10.50); - Before you install, carefully examine the installation instructions! All the detailed instructions found in the archives AllData.10.50_48xDVD_How.to.Install_Run.From.HD_Manual.Info.rar and AllData_10.50_3Q11_Install-Updates-Fixes_Cr4ck.rar. 1. Burn or mount the Image AllData_10.50_3Q11_Install-Updates-Fixes_Cr4ck or AllData.10.50_Install_Disk with your favorite Tool (se bottom **). 2. Start Setup and install. 3. After installation is complete, copy the files from Crack-folder in a folder with a installed program's. 4. Enjoy! ** Alcohol 120%, DAEMON Tools or UltraISO - the best Tools for mount or convert and burn ISZ-images *** The archive Support_Utilities contain more tools, patches and fixes for some crash bugs. this is it ad 10. 51.rar ad 10. 51.rar
  7. alldata 10.40 (2011).torrent اخر اصدارات البرنامج العملاق القوى فى صيانة جميع أنواع السيارات alldata 2011 Professional repair shops need current, factory-correct information to meet the complex repair demands of today's automotive industry. Alldata 10.40 shops have fast access to the industry's best information for vehicles from 1982 to present including TSBs, maintenance schedules, manufacturer recall information, OE solutions, and factory images and diagrams. Alldata DVD, the leading computer-based diagnostic, repair and estimating information system, can help you boost shop performance and build customer loyalty as you efficiently repair more makes and reduce comebacks. • The most comprehensive information for 1982 to present vehicles, updated quarterly • OEM images, diagrams and diagnostic flow charts • Parts and labor information • Maintenance schedules • Manufacturer TSBs and Recalls • Integrated estimating software • OEM wiring diagrams with connector, ground, power distribution and splice information • A2Z™ Component Search - the fastest route available to component information Whether you measure productivity by the number of vehicles repaired in a day, the variety of vehicles you're able to work on, or the time spent on diagnosis and repair, using the right information and shop management tools is vital to the success of your business. ALLDATA can help you succeed in every way. Automotive repair shops that use the ALLDATA system have a clear differentiation from other repair facilities. ALLDATA-equipped shops can provide their customers with the most accurate repair estimates and proof of diagnostic and repair procedures. ALLDATA also includes factory-correct maintenance schedules that itemize additionally needed services. Moreover, ALLDATA helps shops build consumer confidence and loyalty. ad 10. 40.rar
