al-31f
Весь контент al-31f
  1. Без проблем запишет : 03.05.2016 10:47:33 Message SELECTED DEVICE: CHIPSOFT J2534 ISO/CAN 03.05.2016 10:47:33 Message API VERSION: 04.04 03.05.2016 10:47:33 Message DLL VERSION: CHIPSOFT J2534 Library FW: 0.993 Oct 21 2015 12:36:42 03.05.2016 10:47:33 Message FIRMWARE VERSION: CHIPSOFT adapter v. 0.996 HW: FFFFFFFF SN: AD6E164CB584EE76 03.05.2016 10:47:33 Message SELECTED ECU: ECU/Toyota/Prado/3.0 V6/DENSO 32BH384K 76F0040GD 368kb K-LINE 03.05.2016 10:47:38 Message API VERSION: 04.04 03.05.2016 10:47:38 Message DLL VERSION: CHIPSOFT J2534 Library FW: 0.993 Oct 21 2015 12:36:42 03.05.2016 10:47:38 Message FIRMWARE VERSION: CHIPSOFT adapter v. 0.996 HW: FFFFFFFF SN: AD6E164CB584EE76 03.05.2016 10:47:38 Message INITIALIZATION 03.05.2016 10:47:39 Message READ ECU INFO: 03.05.2016 10:47:40 Message ID CALIB DATA: 36059000 03.05.2016 10:47:40 Message SW: 89663-60590 03.05.2016 10:47:40 Message HW: 89661-60C10 10.05.2016 17:46:58 Message WRITE FIRMWARE FILE NAME = C:\Documents and Settings\Admin\Рабочий стол\89663-60590.bin 10.05.2016 17:47:02 Message INITIALIZATION 10.05.2016 17:47:02 Message API VERSION: 04.04 10.05.2016 17:47:02 Message DLL VERSION: CHIPSOFT J2534 Library FW: 0.993 Oct 21 2015 12:36:42 10.05.2016 17:47:02 Message FIRMWARE VERSION: CHIPSOFT adapter v. 0.996 HW: FFFFFFFF SN: AD6E164CB584EE76 10.05.2016 17:47:37 Message AUTHENTICATION 10.05.2016 17:47:38 Message SW: 89663-60590-A 10.05.2016 17:47:38 Message CHECK PASSWORD 10.05.2016 17:47:56 Message MCU TYPE: 40 10.05.2016 17:47:56 Message ALGORITHM ID № 0x03 10.05.2016 17:47:56 Message PROGRAMMING SESSION START 10.05.2016 17:47:56 Message START ADDRESS: 0x000000 10.05.2016 17:47:56 Message FINISH ADDRESS: 0x07BFFF 10.05.2016 17:47:56 Message CHECK BLOCK № 01 10.05.2016 17:47:56 Message ERASE BLOCK № 01 10.05.2016 17:47:56 Message WRITE BLOCK № 01 10.05.2016 17:49:18 Message VERIFY BLOCK № 01 10.05.2016 17:50:59 Message CHECK BLOCK № 02 10.05.2016 17:50:59 Message ERASE BLOCK № 02 10.05.2016 17:51:00 Message WRITE BLOCK № 02 10.05.2016 18:00:11 Message VERIFY BLOCK № 02 10.05.2016 18:11:33 Message TOTAL WRITE BLOCK № 02 10.05.2016 18:11:33 Message FIRMWARE WRITE SUCCESSFULLY
  2. Провода проверены, датчик новый, ставишь другой ЭБУ, скорость появляется, в родном повреждений не видно, а ЭБУ стоит не копейки.
  3. Отключите, пожалуйста, ошибку по датчику скорости . VAZ21214-1_7L8V_M7N20V33_02612065421037368235MP7_0H_0.bin
  4. al-31f ответил al-31f тема в Mazda, Ford, Lincoln
    В первом посту написан. Нашел отсутствующее реле на вентилятор, ошибка ушла, но вентиляторы молотят после запуска сразу.Снимаешь разъем с датчика-выключателя по низкому давлению хладагента в системе кондиционирования, вентиляторы начинают работать штатно, датчик звонится накоротко, в Форскане и Автокоме значения давления не нашел, пока так.
  5. al-31f ответил al-31f тема в Mazda, Ford, Lincoln
    Спасибо.
  6. al-31f ответил al-31f тема в Mazda, Ford, Lincoln
    Не много не тот , модельный год 2008 ETis качается, но будет только к вечеру )))
  7. al-31f опубликовал тема в Mazda, Ford, Lincoln
    Ford Escape 2007 года 2,3 (146) АТ 1FMCU93Z48KA11966 постоянно крутится вентилятор, ошибка P0480 - неисправность эл. цепи управления вентилятором, помогите схемой ? Есть на ней БУВ, где стоит ?
  8. А vin разве не надо прописывать?
  9. Всем кто откликнулся, спасибо !
  10. Подскажите пин. Peugeot 206 2008 г. VF32BKFWA72792109 95160_BSI_206.bin
  11. На Opel Meriva B стоит именно ЭГУР.
  12. Кто может по удаленке через OP сконфигурировать BCM после замены, EEprom перепаян, машина заводится, не работают дворники, магнитола и т.д. В личку.
  13. Galletoй V54 делал. PSA IAW 6LPx2_6KPB_ST10F280_ST10F296.pdf PSA IAW 6LPx1_ST10F280.pdf
  14. Кто делает хороший тюн на дизельных Audi ? Машина A4 2010 г. 2.0 143 л. с. Сток будет вечером . Кто делает хороший тюн на дизельные Audi? Блок предположительно edc17cp20 или edc17cp14.
  15. Здравствуйте, на автомобиле имеется такой баг :иногда обороты на холостом ходе могут прыгать от 400 до 1000, бывает и до 5000 об. Ошибок нет, дроссель блестит, как у кота, адаптирован Techstream, форсунки промыты, коррекции минимальны, свечи заменили на новые, иридиевые, denso, родной пробег 75 т. км. В гараже может два-три часа стоять, обороты чуть подымаются при включении кондиционера. Может неделю ездить без этого, появляется произвольно, приезжает в гараж, ошибок нет, холостые стабильны. Видео https://yadi.sk/i/ViWWS9ATvR5FZ Подскажите, куда копать ?
  16. Сигналки нет ? http://www.chiptuner.ru/content/fw_china/ И EEPROM там есть.
  17. АЦП гуляло?
  18. Может к визиту в сервис ?
  19. Так в раздел диагностики надо, если в прошивке проблема обратись к автору.
  20. На классических нет канала дд. Ты ж сам знаешь )))
  21. Писать http://www.auto-bk.ru/forum/topic/63850-toyota-flasher-lexus-flasher-scion-flasher-obd2/
  22. P1610 - Lock Mode,unregistered key used 5 times, BCM or ECM is malfunctioning P1612 - Chain of ECM-IMME,Comm impossible between ECM and BCM. К специалисту.
