VCM2 Интересует информация по данному прибору, работает с Лендровер , Ягуар?
не знаю что за прибор, но если интересует который реально работает включая программирование то пиши в личку,
Реально работает
ну если про оригинал, то слов нет пашет, ну и цена соответственно, http://www.motorcraf...il&menuIndex=16
Software:
The IDS software must be downloaded and installed on a PC meeting the minimum specifications posted here. Use of the IDS software requires as software license subscription available under IDS Software Licensing. The IDS software license includes time based access to the IDS software, software updates and calibration files. The IDS DVD containing IDS Software and Calibration files was discontinued in 2012. IDS Software and calibration files are only available to download online. The Ford IDS software includes vehicle coverage for Ford, Lincoln and Mercury vehicles only.
Hardware: VCM1.jpg VCM
The Vehicle Communication Module (VCM) communicates with Ford vehicles through the 16-pin diagnostic link connector. This device is used by the IDS software and is the core of vehicle diagnostics to read trouble codes, re-program (flash), and view vehicle data. The VCM is no longer available through Rotunda however; previously purchased VCMs are still supported. VCM2.jpg VCM II
The VCM II was introduced in 2012. The IDS software supports both the VCM and the VCM II. The VCM II is designed as a direct replacement for the original VCM.
VMM1.jpg VMM
The Vehicle Measurement Module (VMM) handles electronic and transducer based measurements. The VMM connected to a laptop offers the following functionality: Ignition System Test; Fuel Pressure Test; Fuel Leak-down Test; Injector Flow Test; Secondary Ignition; Current Probe Functionality; Oscilloscope; Digital Multi-Meter.
И всё же, кто то пробовал VCM 2 с ягуаром и лендровером?
(http://www.drewtech.com/ )
MongoosePro® Jaguar-Land Rover (JLR) - сам к этому присматриваюсь вместо VCM IDS.
Изменено пользователем leon163
Реально работает
Я так понимаю у вас он есть вы им работаете
VCM 2 не работает с JLR - теперь только и исключительно MongoosePro JLR или Cardaq
и то и то в РФ есть
Изменено пользователем aglinsky
А VCM II работает с IDS версий например V72; V80; V82? Или клянчить будет свой софт?
Оригинальный VCM стоит порядка 2200$ а VCM2 1400$ на EBAY
С китайским клоном VCM у меня чеето не особо клеится.-(
Как это VCM2 не работает с JLR? Когда у меня при инсталяции JLR 130 автоматически ставится драйвер для VCM2 ?
Дак есть тут люди которые им реально пользовались? А то в нете достаточно мало инфы. Например какая минимальная нужна версия IDS
UP Темы
НУ НАПИшИТЕ УЖЕ КТО ЧТО ЗНАЕТ?
