obdstart
Информация о obdstart
752 просмотра профиля
Достижения obdstart
  1. Opcom 1.39 or 1.45 or 1.59 or 1.60 is firmware version for PIC18F458 chip (.hex or .bin file) Any version of opcom software have own version of firmware: Software Firmware v100219 ------ v1.39 v120309 ------ v1.45 v131223 ------ v1.59 v150406 ------ v1.60 Example: You use installed software v120309 with own firmware v1.45, If you update firmware to 1.59 or 1.60 and stil use v120309a software then you does NOT get any better work of your opcom interface. You need also update software to higher proper version of firmware. Info: Most olders opcom interfaces have PCB v5 version with original PIC18F458 and can do update firmware. Newest opcom interfaces have PCB v6 with chinese fake PIC18F458 or PIC18F4580 or only "Opcom" chip and can NOT do update firmware, because is chip read/write protected.
  2. дурак, есть язык змеи, если вы не соответствуете программное обеспечение, то не скачать
  3. So mr. "Liga052" maybe for you is "хрень", but if you have some better version for chinese clones, then put here for free
  4. 1) You need reprogram USB FTDI with .ept file 2) You need reprogram AT MEGA with .bin or .hex firmware
  5. New version VCDS 12.12.0 (32 and 64bit) for chinese clones. https://mega.co.nz/#!0BBiAQLZ!uBtOouN81MQHnF4hOVIcTsWcfFm37woLGOgR4ryIpBo Password: 999obdstart Enjoy !
  6. Use Autocom CDP+ with wurth WoW 5.00.3 or 5.00.4 software. Good work all modules + key programing + actuator test + read about ~30 parameters of motor ECU. FreeLander is 2000.г. (older car) so...no too much electronics modules inside and not full and good diagnostics like on newer cars from 2006.г. ---->
  7. Аплекс: Do you test software on reprogramed diagbox interface?
  8. НET ета банально набивание постов !! I want to say: Any version of OPCOM software have OWN firmware device. Example: You can NOT USE new software 131223C to work WITH chinese interface software 100219a (firmwire 1.39 inside of interface). You must have proper firmware (dump) and REPROGRAM interface for new 131223C version OK?
  9. Example: OP-COM China clone ( op-com 100219a aka "08/2010") use fw 1.39 - do not use other firmwear! OP-COM softwares from 2011 use fw1.44 OP-COM softwares from 2012 used fw 1.45 and the softwear released at the END of that year used fw1.47 OP-COM softwares from 2014 used fw1.59
  10. Yes, shareware is here: http://www.ross-tech.com/vcds-lite/download/ and size is ~1,68 Mb My version is Full & Activated and size is ~3,47Mb... So mr. "Clever-052" what do you think, have some difference???
  11. EcuSafe v2.0.0. Cracked for clean/remove DPF/EGR/AD-BLUE Turn off antivirus softvare - no virus ! Run file on "Loader.exe" file No password - Free Ecu Safe v2.0.0.zip
