THC
Модератор
Весь контент THC
  1. AT команды модуля Bluetooth Diagun (все команды заканчиваются вводом \r\n): Команда / Ответ / Параметры 1. Test AT / OK / - 2. Reset AT+RESET / OK / - 3. Get firmware version AT+VERSION? / +VERSION:<Param> OK Пример: AT+VERSION?\r\n +VERSION:2.0-20100601 OK 4. Restore default AT+ORGL / OK Default state: Slave mode, pin code :1234, device name: H-C-2010-06-01 ,Baud 38400bits/s. 5. Get module address AT+ADDR? / +ADDR:<Param> OK Bluetooth address: NAP: UAP : LAP Пример: AT+ADDR?\r\n +ADDR:1234:56:abcdef OK 6. Set/Check module name AT+NAME=<Param> / OK / Param: Bluetooth module name (Default :HC-05) AT+NAME? / +NAME:<Param> OK (/FAIL) Пример: AT+NAME=HC-05\r\n set the module name to “HC-05” OK AT+NAME=ITeadStudio\r\n OK AT+NAME?\r\n +NAME: ITeadStudio OK 7. Get the Bluetooth device name AT+RNAME?<Param1> / 1. +NAME:<Param2> OK 2. FAIL / Param1,Param 2 : the address of Bluetooth device Пример: (Device address 00:02:72:od:22:24,name:ITead) AT+RNAME? 0002,72,od2224\r\n +RNAME:ITead OK 8. Set/Check module mode AT+ROLE=<Param> / OK / Param: 0- Slave 1-Master 2-Slave-Loop AT+ ROLE? / +ROLE:<Param> OK 9. Set/Check device class AT+CLASS=<Param> / OK / Param: Device Class AT+ CLASS? / 1. +CLASS:<Param> OK 2. FAIL 10. Set/Check GIAC (General Inquire Access Code) AT+IAC=<Param> / 1.OK 2. FAIL / Param: GIAC (Default : 9e8b33) AT+IAC / +IAC:<Param> OK Пример: AT+IAC=9e8b3f\r\n OK AT+IAC?\r\n +IAC: 9e8b3f OK 11. Set/Check — Query access patterns AT+INQM=<Param>,<Param2>, <Param3> / 1.OK 2. FAIL / Param: 0——inquiry_mode_standard 1——inquiry_mode_rssi Param2: Maximum number of Bluetooth devices to respond to Param3: Timeout (1-48 : 1.28s to 61.44s) AT+ INQM? / +INQM:<Param>,<Param2>, <Param3> OK Пример: AT+INQM=1,9,48\r\n OK AT+INQM\r\n +INQM:1, 9, 48 OK 12. Set/Check PIN code AT+PSWD=<Param> / OK / Param: PIN code (Default 1234) AT+ PSWD? / + PSWD :<Param> OK 13. Set/Check serial parameter AT+UART=<Param>,<Param2>,<Param3> / OK / Param1: Baud Param2: Stop bit Param3: Parity AT+ UART? / +UART=<Param>,<Param2>, <Param3> OK Пример: AT+UART=115200,1,2,\r\n OK AT+UART? +UART:115200,1,2 OK 14. Set/Check connect mode AT+CMODE=<Param> / OK / Param: 0 – connect fixed address 1 – connect any address 2 – slave-Loop AT+ CMODE? / + CMODE:<Param> OK 15. Set/Check fixed address AT+BIND=<Param> / OK / Param: Fixed address (Default 00:00:00:00:00:00) AT+ BIND? / + BIND:<Param> OK Пример: AT+BIND=1234,56,abcdef\r\n OK AT+BIND?\r\n +BIND:1234:56:abcdef OK 16. Set/Check LED I/O AT+POLAR=<Param1,<Param2> / OK / Param1: 0- PIO8 low drive LED 1- PIO8 high drive LED Param2: 0- PIO9 low drive LED 1- PIO9 high drive LED AT+ POLAR? / + POLAR=<Param1>,<Param2> OK 17. Set PIO output AT+PIO=<Param1>,<Param2> / OK / Param1: PIO number Param2: PIO level 0- low 1- high Пример: 1. PIO10 output high level AT+PI0=10,1\r\n OK 18. Set/Check – scan parameter AT+IPSCAN=<Param1>,<Param2>,<Param3>,<Param4> / OK / Param1: Query time interval Param2:Query duration Param3:Paging interval Param4:Call duration AT+IPSCAN? / +IPSCAN:<Param1>,<Param2>,<Param3>,<Param4> OK Пример: AT+IPSCAN =1234,500,1200,250\r\n OK AT+IPSCAN? +IPSCAN:1234,500,1200,250 19. Set/Check – SHIFF parameter AT+SNIFF=<Param1>,<Param2>,<Param3>,<Param4> / OK / Param1: Max time Param2: Min time Param3: Retry time Param4: Time out AT+ SNIFF? / +SNIFF:<Param1>,<Param2>,<Param3>,<Param4> OK 20. Set/Check security mode AT+SENM=<Param1>,<Param2> / 1. OK 2. FAIL Param1: 0——sec_mode0+off 1——sec_mode1+non_secure 2——sec_mode2_service 3——sec_mode3_link 4——sec_mode_unknown Param2: 0——hci_enc_mode_off 1——hci_enc_mode_pt_to_pt 2——hci_enc_mode_pt_to_pt_and_bcast AT+ SENM? / + SENM:<Param1>,<Param2> OK 21. Delete Authenticated Device AT+PMSAD=<Param> / OK / Param: Authenticated Device Address Пример: AT+PMSAD =1234,56,abcdef\r\n OK 22. Delete All Authenticated Device AT+ RMAAD / OK 23. Search Authenticated Device AT+FSAD=<Param> / 1. OK 2. FAIL / Param: Device address 24. Get Authenticated Device Count AT+ADCN? / +ADCN:<Param> OK / Param: Device Count 25. Most Recently Used Authenticated Device AT+MRAD? / + MRAD:<Param> OK / Param: Recently Authenticated Device Address 26. Get the module working state AT+ STATE? / + STATE:<Param> OK / Param: “INITIALIZED” “READY” “PAIRABLE” “PAIRED” “INQUIRING” “CONNECTING” “CONNECTED” “DISCONNECTED” “NUKNOW” 27. Initialize the SPP profile lib AT+INIT / 1. OK 2. FAIL 28. Inquiry Bluetooth Device AT+INQ / +INQ: <Param1>, <Param2>, <Param3> OK / Param1:Address Param2:Device Class Param3:RSSI Signal strength Пример: AT+INIT\r\n OK AT+IAC=9e8b33\r\n OK AT+CLASS=0\r\n AT+INQM=1,9,48\r\n At+INQ\r\n +INQ:2:72:D2224,3E0104,FFBC +INQ:1234:56:0,1F1F,FFC1 +INQ:1234:56:0,1F1F,FFC0 +INQ:1234:56:0,1F1F,FFC1 +INQ:2:72:D2224,3F0104,FFAD +INQ:1234:56:0,1F1F,FFBE +INQ:1234:56:0,1F1F,FFC2 +INQ:1234:56:0,1F1F,FFBE +INQ:2:72:D2224,3F0104,FFBC OK 28. Cancel Inquiring Bluetooth Device AT+ INQC / OK 29. Equipment Matching AT+PAIR=<Param1>,<Param2> / 1. OK 2. FAIL / Param1:Device Address Param2:Time out 30. Connect Device AT+LINK=<Param> / 1. OK 2. FAIL / Param:Device Address Пример: AT+FSAD=1234,56,abcdef\r\n OK AT+LINK=1234,56,abcdef\r\n OK 31. Disconnect AT+DISC / 1. +DISC:SUCCESS OK 2. +DISC:LINK_LOSS OK 3. +DISC:NO_SLC OK 4. +DISC:TIMEOUT OK 5. +DISC:ERROR OK / Param:Device Address 32. Energy-saving mode AT+ENSNIFF=<Param> / OK / Param:Device Address 33. Exerts Energy-saving mode AT+ EXSNIFF =<Param> / OK / Param:Device Address
  2. да, возможно, ну нужна либо DeJaVu либо abritus оригинал, с опцией AN034
  3. если коробка не официальная - меняешь номер смартбокса и качаешь обновы, которые есть.
  4. у меня нет - пиши в куплю-продажу
  5. Неки: HAVANNA W221 MEHACO W221 W164 W204 W212 W207 DONAU AMAZONAS NEVADA PALERMO SPANIEN не прочитать ничем!
  6. ставь CAN-фильтр в замок и делай приборку (внутри микруха 24С16)
  7. пока что только заявлено, они ж его только 20 июня выпустили. кстати, какая стиралка лучше будет - для Энигмы или Codiprog к DiagProg3 ?
  8. помимо щитка, замка EZS, мозгов ECU дубли есть в гейтвее CGW, модуле давления в шинах TPM, блоке айрбегов AB (моточасы), плюс чем ты будешь активные сервисы Assyst Plus править ? star есть ? твой процессор нек в замке может прочитать программатор от ELNEC.
  9. сначала радио сними, а то потом будешь код для магнитолы ещё считать
  10. в EZS процессор 9S12DT128, после 10/2006 - процессор NEC столик к нему для программатора:
  11. 380VOLT, mpx333, cfljdybr вы чего издеваетесь? 1. Копируешь программу DiskRW на карту памяти ДИАГУНА!!! 2. Запускаешь DiskRW с карточки памяти ДИАГУНА!!! понятно что не на винде XP, плевать на каком языке у тебя оболочка DiagShow запускается и какие программы на русском! вы вообще читаете о чём вас спрашивают ?!!! нажми Пуск-Настройка-Панель управления- WinCE version посмотри в окошке - видишь WinCE version написано ? вот эти циферки и сообщи !!!
  12. разгадан кем? китайцами? скажите, серийник связан с UUID КПК или нет?
  13. как блок иммо мог умереть после правки микросхемы?
  14. скинь лучше дамп своего флеша. у тебя при загрузке что пишет BSP V1.8 OS 2.5 или OS 2.2 ? винда какой версии Пуск-Настройка-Панель управления- WinCE version ? русский язык в системе присутствует или нет? Backup флеша: 1. Копируешь программу DiskRW на карту памяти 2. Запускаешь DiskRW с карточки памяти 3. Выбираешь вкладку Read/Write Operation: Read Disc Store: MSFlash Offset: 0 Output: \Storage Card\MSFlash 4. Жмешь Read Создается файлик MSFlash_0_xxxxx.img - это твой backup флеша.
  15. парни, ну сколько можно сопли жевать? сколько можно выпрашивать обновления на Диагуны серийный номер Diagun98054XXXXX00 ? пора браться за дело! покупаем JTAG дебаггер SAMSUNG S3C2440 ARM9 Computer Board по типу такого: или этого: USB ARM JTAG adapter ARM7/9 Cortex debug for Keil Ulink ставим дебаггер: noicedebugger реверсируем DiagShow.exe и узнаём с каких адресов он серийник тянет. потом делаем патч либо для DiagShow (чтобы любой серийник работал) или в прошивке меняем серийник на тот, для которого есть обновления. делов то!!! кто за то, чтобы узнать маленький китайский секрет хранения серийника в прошивке? :AllSmail (6):
  16. to MUT у тебя кстати какая версия операционки OS 2.x ? Версия 2.2 или 2.5 ?
  17. Pin JTAG T7-TDO T6-TCK T5-TMS T4-TDI Pin diagnostic T11-GDN T2- +3.3v power T40,T39 USB T4-TDI-JTAG T5-TMS-JTAG T6-TCK-JTAG T7-TDO-JTAG T9-Rx rs232(sp3232) +/- 15v - PC COM port T10-Tx rs232(sp3232) T38,T37 ?USB2?
  18. твой 5ый гольф на вистеоне китаец Тахой 2008 посчитал, никакой загадки там нет.
  19. по ВСЕМ не будет. пишите какие 8 криптомасок аудиков интересуют - модель, год, номера щитка.
  20. B1231 - краш на Фордах и Маздах, видимо не догоняешь...
  21. да, fly
  22. отличия в коррекции от старого кузова никакого - внутри по прежнему еепром 93C66, ты цену на смотку какую озвучил? тоже старую? стрелы дергать надо, смотри тему по мазде 6 там стрелы такие же. если движок 2,0 л - стрелы можешь не снимать. Если 1,6 л - снимать и очень аккуратно. клиент правильно спрашивал - если сломаешь стрелки или ось вытянешь - будут дергаться. но хуже будет если дамп снесёшь - машина не заведется (в еепром ключи лежат!). либо делай приблудой через ОБД.
  23. а в чём проблема с аудиками то не пойму ? да хоть 10 криптомасок будет - будет 10 алгоритмов (с адресами и ключами шифрования) и при известном пробеге и повторяемости данных номер алгоритма вычисляется без проблем. если надо люди сами напишут программку под эти алгоритмы если руками считать лень будет. детский сад тут вы развели со своими аудиками - нет с ними никаких проблем.
  24. хорошо, если что - пусть к вам обращаются, будете быстро раскриптовывать, потом люди будут править, а вы снова закриптовывать. действительно, кому всё это нужно было.
  25. не помогло - те же ошибки: B1231 Right Seat B10A6 Main Light Switch
