KIMI
Весь контент KIMI
  1. I hope that my translator works.. I give the orders dump with this manual, have only of 90cv .. I hope that it helps with something.
  2. Откройте блок, найти небольшой 5P08 памяти, перепрограммировать с вложенным файлом, выбрав SGSThompson 95P08. Это устройство блокирует зажигание выключается после этого обновил внутренней памяти, а затем отсоединить панель, чтобы разблокировать, а также резки проволоки 820 или 821, не больше блокироваться......
  3. Can you read dump of immo? And said good the kalina that better you order the code of mistake
  4. Hello, way tries this. I hope that it can use as help
  5. Hello, this file not this one well-read well.
  6. This one where processor. It takes the dumps orig to compare Regards.
  7. Hello, it is your you have two eprom of 27C010 that has yellow stickers, You have that dessoldar and to read info ... despues have to burden to 29F010 ... very importantly remember where this HHH and the LLL.th ... this way as this one foto_HHH this one in the izquerda and the this LLLth in the right. Regards P.S. if this one written evil in English I write it in Spanish
  8. Hello very good days, I Have a doubt in the map modified of this car, Aver if someone can look where this mistake ... car is OK only one throws very much black smoke .. please if someone can say to him if the file this one modified well or not. Thank you
  9. I cannot send you in personnel, This flood You can do photo of sheet that goes in the auto body with the numbers of vastidor, code of painting, etc
  10. If, you have to do cloock. Does this go eprom 29f010 (32plcc)? Then tendras that desoldar eprom and to burden other one with dump cloock, to return to connect the uce, to put alone contact and to wait 1 minute. Despues to turn his own dump and to running. (Even it is possible to re-codify)
  11. Thank you friend, Voy to try to do again ... possible slightly not done well, like always with the hurry. Of all it forms thank you very much, as that I make again you dire since it was the thing. Regards.
  12. Not, probe this dump that I order now ... but I need one that this verified. Thank you.
  13. If, it is possible and complicated enough
  14. If .. before I throw it already of this form, This goes 27C512 ... I and well-read and turned To burden the overturned one to 29FXXX, mount again to the car I gave contact 1minuto despues and burdened his originally. The light of picture I extinguish it seems as the key recognizes ... the scanner does not give me ningun mistake, nevertheless I enter the values of immo and it gives me that "I" "activate" this one I put the dumps of this ecu that and used.
  15. It takes .. I have this aver if it costs you
  16. Excuse!! Give the orders dump equibocado. What I order you polubak77 this one correctly :AllSmail (25):
  17. yes, what is ruslanei and cleaned ... there are two ways to clean
  18. Control the images to see him. Thanks Safir2.rar
  19. KIMI
    renault clio ll,1.2i
    Hello. I need the assistance of immo-off, the key was lost renault clio II and three days I have been trying to cancel immo box ... the light was extinguished but the scanner says this immo active, ask if anyone had made this car to advise me where to put my hands in front of a renault clio gracias.Es hand ll 1.2i safir2
  20. If this one well, one sees that you have worked with calculator. It takes your clean this. clear.rar
